[mapserver-users] wms projection wrong
Eugenio Trumpy
frippe12573 at hotmail.com
Wed Mar 8 04:13:20 PST 2017
here the link to the screenshot I did:
https://ibb.co/eHqzQa
[https://image.ibb.co/dsxPrF/Screenshot_from_2017_03_08_11_54_59.png]<https://ibb.co/eHqzQa>
Screenshot from 2017 03 08 11 54 59<https://ibb.co/eHqzQa>
ibb.co
Image Screenshot from 2017 03 08 11 54 59 hosted in imgbb.com
Here below the layer definition:
LAYER
NAME "OSM_basemap"
TYPE RASTER
STATUS DEFAULT
CONNECTION "http://ows.terrestris.de/osm-gray/service" #"http://irs.gis-lab.info/?layers=osm&"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "OSM-WMS"
"wms_server_version" "1.0.0"
"wms_format" "image/png"
END
END
this give a wrong reprojection for me;
and this is the one loaded as shp file:
LAYER
NAME 'countries'
TYPE POLYGON
DATA 'countries.shp'
METADATA
'wms_title' 'countries'
"DESCRIPTION" "Confini nazionali"
"RESULT_FIELDS" "NAME, AREA_KM2"
"RESULT_HEADERS" "Nazione, Area in kmq"
END
STATUS DEFAULT
#TRANSPARENCY 100
OPACITY 100
MINSCALEDENOM 1500000
TEMPLATE void
#PROJECTION
#'proj=longlat'
#'ellps=WGS84'
#'datum=WGS84'
#'no_defs'
#END
PROJECTION
"init=epsg:4326"
END
CLASS
NAME 'Limite nazionale'
STYLE
SYMBOL 0
OUTLINECOLOR 255 255 130
# COLOR 148 116 176
END #style
END #class
END #layer
I think this work fine since the other layer in the mapfile, although in different epsg, are well overlapped.
I'm testing the mapfile by using pmapper version4.
Eugenio
Da: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Inviato: mercoledì 8 marzo 2017 12.16
A: Eugenio Trumpy; mapserver-users at lists.osgeo.org
Oggetto: Re: wms projection wrong
I do not see any screenshot in your message. This mailing list has rather strict limits for the size of the message so perhaps it has been dropped. It might be better to put your image into some image service and add a link to the mail.
You must also add more information. Write at least LAYER definitions and tell how did you test the layer and how do you know that the OSM layer is right.
-Jukka Rahkonen-
Dear all,
I installed mapserver7.0.4 on ubuntu 16.04 for a test.
I used ppa to install php_mapscript module.
Everything seems to be working, however I got an issue
on the map. As you can see on the screenshot attached
the 2 layers boundaries mismatch.
The base map is from OSM is in EPSG:4326 (WMS layer),
european countries is a shp file in the same epsg.
I guess is something related to the WMS layer projection, doesn't it?
This is very strange,
it didn't happen in mapserver 6.4.1 in ubuntu 14.04.
Of course I'm testing the same mapfile.
Any hints on that?
Eugenio
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170308/6c3b0dce/attachment-0001.html>
