[mapserver-users] On-the-fly field calculation in a GetFeatureInfo request
Patrice
abrabacabra at openmailbox.org
Thu Mar 16 10:58:33 PDT 2017
Could you point me in the right direction for the solutions you
proposed? I like the idea of do calculations client-side with
javascript, however, I didn't figure out how to fetch the value withina
<script> tag in the template.
On 2017-03-16 03:50, Jörg Thomsen (WhereGroup) wrote:
> Hello Patrice,
> I would prefer to save the data in a database using a view to create the
> additional field (I haven't tried, but I think even spatialite is
> possible as mapserver-deatasource?)
> Another way would be to use scripting
> - calculate the value with javascript within the template-html or
> - use server-side processing within the template
> Regards, Jörg
> Am 16.03.2017 um 03:25 schrieb Abrabacabra:
>> Hello,
>> Is it possible to do numeric calculations with the result of a
>> GetFeatureInfo? Some layers have an area field in square meters but I
>> want to display it to the user in acres or hectares. It would be nice
>> not having to create a second attribute column in my source layer just
>> for that.
>> I am using an html template at layer level to output the results of the
>> query.
>> Mapserver 7.0.4
>> Thank you,
>> Patrice
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Viele Grüße,
> Jörg Thomsen
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170316/991abb32/attachment.html>
