[mapserver-users] On-the-fly field calculation in a GetFeatureInfo request
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Mar 17 01:06:53 PDT 2017
I#m naot very good in js.... sth like
<script type="text/javascript">
document.write("<td>"[sqm_field_in_geodata]/10000" ha</td>);
</script>
Jörg
Am 16.03.2017 um 18:58 schrieb Patrice:
> Could you point me in the right direction for the solutions you
> proposed? I like the idea of do calculations client-side with
> javascript, however, I didn't figure out how to fetch the value withina
> <script> tag in the template.
> On 2017-03-16 03:50, Jörg Thomsen (WhereGroup) wrote:
>> Hello Patrice,
>> I would prefer to save the data in a database using a view to create the
>> additional field (I haven't tried, but I think even spatialite is
>> possible as mapserver-deatasource?)
>> Another way would be to use scripting
>> - calculate the value with javascript within the template-html or
>> - use server-side processing within the template
>> Regards, Jörg
>> Am 16.03.2017 um 03:25 schrieb Abrabacabra:
>>> Hello,
>>> Is it possible to do numeric calculations with the result of a
>>> GetFeatureInfo? Some layers have an area field in square meters but I
>>> want to display it to the user in acres or hectares. It would be nice
>>> not having to create a second attribute column in my source layer just
>>> for that.
>>> I am using an html template at layer level to output the results of the
>>> query.
>>> Mapserver 7.0.4
>>> Thank you,
>>> Patrice
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Viele Grüße,
>> Jörg Thomsen
Viele Grüße,
Jörg Thomsen
FOSS Academy Winterschule 2017
20.-24.03.2017 in Bonn
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
