[mapserver-users] OGR Attributes
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Mar 21 12:19:36 PDT 2017
You can also check the MapServer source and see that those parameters in
the document match what is exposed through the source:
https://github.com/DMS-Aus/MapServer/blob/master/mapogr.cpp#L1493-L1515
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-03-21 3:54 PM, Jeff McKenna wrote:
> Hi Flavio!
> The section you are referring to is specially for accessing label styles
> through MapScript
> (http://mapserver.org/input/vector/ogr.html#accessing-ogr-styleitemauto-label-styles-through-mapscript).
>  So I have now tested and confirmed that with MapServer 7.0.4 (MS4W
> 3.2.1) I can access the "OGR:LabelText" style, on a MapInfo .TAB file,
> through PHP MapScript as follows:
>   // open map
>   $oMap = ms_newMapObj( "D:/ms4w/apps/ogr-demos/nfld_demo/test.map" );
>   //get layer
>   $oLayer = $oMap->getLayerByName("Map_Labels");
>   //get styles
>   $status = $oLayer->open();
>   $status = $oLayer->whichShapes($oMap->extent);
>   while ($oShape = $oLayer->nextShape())
>     //echo $oShape->index ."<br>\n";
>     echo $oShape->getValue($oLayer,"OGR:LabelText");
>     echo "\n";
>   $oLayer->close();
> My mapfile layer is as follows:
>   LAYER
>     NAME "Map_Labels"
>     TYPE POINT
>     STATUS ON
>     CONNECTIONTYPE OGR
>     CONNECTION "data/nfld/Map_Labels.TAB"
>     STYLEITEM "AUTO"
>     CLASS
>       NAME "Map_Labels"
>     END
>     PROCESSING "GETSHAPE_STYLE_ITEMS=all"
>   END # Layer
> -jeff
