[mapserver-users] Polygon border with marker line symbol
Anton Bakker anton.bakker at geocat.net
Thu Oct 12 01:22:22 PDT 2017
Hi Lars,
The fill of the square was set to true, but I guess that is what happens when you only set the OUTLINECOLOR and a SYMBOL on a polygon type style.
In any case setting the type of the polygon layer to LINE did the trick. I was not aware this was possible, but it does make sense. Thanks for the quick answer!
Kind regards,
Anton
> On 11 Oct 2017, at 18:50, lars.schylberg at blixtmail.se wrote:
> Hi,
> I guess that your symbol definition of square says filled false,  it should be be filled true. Do another symbol.
> Next thing is that if You would like to do fancy borders symbols along a polygon you could set LAYER - TYPE  to line.
> The syntax becomes easier.  Last thing is to get the symbols to rotate with the line you should set gap to a negative value.
> I made a small example to show this.  Save this to line-with-squares.map and run it with:
> /Lars S.
> _________________
> MAP
>   SIZE 1000 1000
>   IMAGETYPE png24
>   EXTENT -30 -10 60 30
>   UNITS DD
> SYMBOL
>     NAME "square_filled"
>     TYPE VECTOR
>     POINTS
>         0 0
>         0 1
>         1 1
>         1 0
>         0 0
>     END
>     FILLED TRUE
> END
> LAYER  # Simple polygon
>   STATUS DEFAULT
>   TYPE LINE
>   FEATURE
>     POINTS
>       5 25
>       25 20
>       45 20
>       35 15
>       50 0
>       0 5
>       5 25
>     END # Points
>   END # Feature
>   CLASS
>         NAME "Symboltest"
>         STYLE
>             SYMBOL "square_filled"
>             COLOR 255 0 0
>             SIZE 12
>             INITIALGAP 15
>             GAP -30
>             OUTLINECOLOR 0 0 0
>             WIDTH 2.0
>         END  #STYLE
>     END # CLASS
> END # LAYER
> END # MAP
> -----Originalmeddelande-----
> Från: "Anton Bakker" <anton.bakker at geocat.net <mailto:anton.bakker at geocat.net>>
> Till: mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> Datum: 2017-10-11 17:45
> Ämne: [mapserver-users] Polygon border with marker line symbol
> Hi list,
> I am trying to create the following symbology in MapServer, a marker line symbol on the border of a polygon, see the following ArcMap screenshot (https://i.imgur.com/9qN16tx.png <https://i.imgur.com/9qN16tx.png>).
> I tried the two following options, but could not manage to recreate the above symbology:
> 1. Renders with marker fill on polygon (https://i.imgur.com/sFFznbq.png <https://i.imgur.com/sFFznbq.png>):
> CLASS
>    NAME "countries_europe"
>    STYLE
>      ANTIALIAS TRUE
>      COLOR 204 204 204
>    END
>    STYLE
>      ANTIALIAS TRUE
>      GAP 30
>      OUTLINECOLOR 0 0 0
>      COLOR 255 0 0
>      SIZE 6
>      SYMBOL 'square'
>      WIDTH 1.0
>    END
>  END
> 2. Renders with marker line symbol on polygon border (https://i.imgur.com/Qwrw8wP.png <https://i.imgur.com/Qwrw8wP.png>), but the marker is missing the fill:
> CLASS
>    STYLE
>      ANTIALIAS TRUE
>      COLOR 204 204 204
>    END
>    STYLE
>      ANTIALIAS TRUE
>      GAP 30
>      OUTLINECOLOR 0 0 0
>      SIZE 6
>      SYMBOL 'square'
>      WIDTH 1.0
>    END
>  END
> Does anyone know whether it is possible to achieve this symbology? It seems the only way to set a picture line symbol on the border of a polygon is to only set the outlinecolor, but then there is no way to set the fill color for the marker. I could not find any any information about this in the documentation or the mailing list.
> Thanks and kind regards,
> Anton Bakker
> software developer at geocat <http://www.geocat.net/>
> tel. +31 318 416 664
> https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171012/662324e9/attachment.html>
