[mapserver-users] Weird behavior of mapcache_seed and mapcache
Jiří Danielka jezza1211 at gmail.com
Fri Oct 20 12:40:43 PDT 2017
I have a question about Mapcache. I have installed Mapcache 1.6 and
Mapserver 7.0.6. I created configuration file (You can see below this text)
and I generated tiles throught mapcache_seed. I have tiles in folder but I
have problem with it. If I send first request to Mapcache with generated
dataset(which was generated by mapcache_seed) Mapcache again execute
Mapserver and I feel big delay. It look like regeneration of tiles. If I
send same request the second time, I work ok a Mapcache don't execute
Mapserver and I get tiles very fast. What am I doing wrong ?
Thank you
George from Czechia
Configuration file, which I use it:
<mapcache mode="combined_mirror">
    <cache name="disk" type="disk" >
        <base>/opt/data/share/maps/mapcache/</base>
        <symlink_blank/>
    </cache>
    <source name="zdroj" type="wms">
        <getmap>
            <params>
             <MAP>/opt/data/share/maps/mapserver/main.map</MAP>
              <FORMAT>image/png</FORMAT>
                <transparent>true</transparent>
                <layers>all</layers>
           </params>
        </getmap>
        <http>
            <url>http://172.17.0.1:8085/mapserver?</url>
        </http>
    </source>
    <format name="PNG_BEST" type ="PNG">
    </format>
    <format name="jpeg_nastaveni" type ="JPEG">
        <quality>95</quality>
        <photometric>RGB</photometric>
    </format>
    <tileset name="mirror">
        <source>zdroj</source>
        <cache >disk</cache>
        <grid>gridRP</grid>
        <format>PNG_BEST</format>
        <metatile>5 5</metatile>
        <metabuffer>10</metabuffer>
    </tileset>
    <grid name="gridRP">
        <extent>-20037508.3427892480 -20037508.3427892480
20037508.3427892480 20037508.3427892480</extent>
        <srs>EPSG:3857</srs>
        <units>m</units>
        <size>256 256</size>
        <resolutions>156412 78206 39103 19551 9776 4888 2444 1222 610.984
305.492 152.746 76.373 38.187 19.093 9.547 4.773 2.387 1.193 0.596
0.298</resolutions>
    </grid>
    <service type="wms" enabled="true">
        <full_wms>error</full_wms>
        <format allow_client_override="true">PNG_BEST</format>
    </service>
    <service type="wmts" enabled="true"/>
    <service type="tms" enabled="true"/>
    <service type="kml" enabled="true"/>
    <service type="gmaps" enabled="true"/>
    <service type="ve" enabled="true"/>
    <errors>report</errors>
    <lock_dir>/tmp</lock_dir>
</mapcache>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171020/1f54f2e3/attachment.html>
