[mapserver-users] Understanding MapServer Memory Usage with WMS raster layers
Peter Schmitt
pschmitt at gmail.com
Fri Oct 27 15:39:21 PDT 2017
On Fri, Oct 27, 2017 at 1:23 PM, <lars.schylberg at blixtmail.se> wrote:
> Looking at the text just below these rows:
> https://github.com/mapserver/mapserver/blob/66309eebb7ba0dc70469efeb40f865
> a8e88fafbd/mappool.c#L62-L65
> I see that there is an option that is not documented:
> CLOSE CONNECTION=NORMAL
> Shouldn't that option be described in the manual page for LAYER, even if
> it is the default behavior ?
I noticed that too... What's the process to update the docs? Do I submit a
pull request to https://github.com/mapserver/docs ?
Even helped me realize another potential source of memory growth in
MapServer when reading imagery with /vsicurl/ and CLOSE_CONNECTION=DEFER:
The config VSI_CACHE is per file handle!
> The default size of caching for each file is 25 MB, and
> can be controlled with the VSI_CACHE_SIZE configuration option (value in
bytes).
> Content in that cache is discarded when the file handle is closed.
http://gdal.org/gdal_virtual_file_systems.html#gdal_virtual_file_systems_vsicache
https://lists.osgeo.org/pipermail/gdal-dev/2017-October/047497.html
This thread explains a lot of confusion I had in the past couple of days
trying to understand high memory use in MapServer.
Cheers,
Pete
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171027/6c92f418/attachment.html>
