[mapserver-users] mapserver 4.8.3 errorsing libgd 2.0.16 (or higher) from ....
Dan Little
theduckylittle at gmail.com
Tue Mar 6 11:46:39 PST 2018
Have you installed the headers for GD? And depending on the complexity of
your Mapfiles, it might be a good time to move to a newer version of
MapServer. There have been a number of significant improvements since
4.8.3.
On Tue, Mar 6, 2018 at 4:26 AM, DamienZINS <damien.zins at intitek.fr> wrote:
> Hi
> I must translate a SOLARIS version in CENTOS 7 OS version
> Above i put all versions sourve that i use
> In the file configure from mapserver 4.8.3, for me $IS_GD2 will be never
> true
> then compilation stop with
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /gmao/old/install. Make sure GD 2.0.16 or higher is compiled before
> calling
> configure. You may also get this error if you didn't specify the
> appropriate
> location for one of GD's dependencies (freetype, libpng, libjpeg or
> libiconv).
> Somebody know why ?
> ac_cv_lib_gd_gdFontCacheSetup=no
> fi
> rm -f conftest.err conftest.$ac_objext \
> conftest$ac_exeext conftest.$ac_ext
> LIBS=$ac_check_lib_save_LIBS
> fi
> echo "$as_me:$LINENO: result: $ac_cv_lib_gd_gdFontCacheSetup" >&5
> echo "${ECHO_T}$ac_cv_lib_gd_gdFontCacheSetup" >&6
> if test $ac_cv_lib_gd_gdFontCacheSetup = yes; then
> IS_GD2="true"
> fi
> GD_NEED_ICONV_LIB="$ICONV_LIB"
> fi
> if test -n "$GD_INCLUDE" -a -n "$GD_LIBDIR" -a "$IS_GD2" = "true"; then
> GD_INC=-I$GD_INCLUDE
> GD_LIB="-L$GD_LIBDIR -lgd"
> GD_XTRA_LIBS="$GD_XTRA_LIBS $GD_NEED_ICONV_LIB"
> echo "$as_me:$LINENO: result: using libgd 2.0.16 (or higher)
> from $GD_LIB $GD_XTRA_LIBS" >&5
> echo "${ECHO_T} using libgd 2.0.16 (or higher) from $GD_LIB
> $GD_XTRA_LIBS" >&6
> informations CentOS :
> [root at localhost mapserver-4.8.3]# cat /etc/redhat-release
> CentOS Linux release 7.4.1708 (Core)
> informations versions sources compiled :
> [root at localhost old]# grep installation install.log
> >>>>>>>>>> installation de freetype-2.8 <<<<<<<<<<
> >>>>>>>>>> installation de zlib-1.2.11 <<<<<<<<<<
> >>>>>>>>>> installation de libpng-1.6.32 <<<<<<<<<<
> >>>>>>>>>> installation de proj-4.9.3 <<<<<<<<<<
> >>>>>>>>>> installation de jpegsrc.v9b <<<<<<<<<<
> >>>>>>>>>> installation de libiconv-1.15 <<<<<<<<<<
> >>>>>>>>>> installation de libgd-2.2.5 <<<<<<<<<<
> >>>>>>>>>> installation de gdal-2.2.1 <<<<<<<<<<
> >>>>>>>>>> installation de apr-1.6.2 <<<<<<<<<<
> >>>>>>>>>> installation de apr-util-1.6.0 <<<<<<<<<<
> >>>>>>>>>> installation de pcre-8.41 <<<<<<<<<<
> >>>>>>>>>> installation de httpd-2.4.27 <<<<<<<<<<
> >>>>>>>>>> installation de tomcat-connectors-1.2.42-src <<<<<<<<<<
> >>>>>>>>>> installation de php-4.4.2 <<<<<<<<<<
> checking for Oracle (OCI8) support using ORACLE_HOME installation... no
> | distribution in the file LICENSE. By continuing this installation |
> | the installation process at this point. |
> >>>>>>>>>> installation de mapserver-4.8.3 <<<<<<<<<<
> Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-
> f4226646.html
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180306/2b08755f/attachment.html>
