[mapserver-users] mapserver 4.8.3 errorsing libgd 2.0.16 (or higher) from ....
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Tue Mar 6 11:54:27 PST 2018
I would agree on the updating. We aren’t patching 4 or 5 anymore. Oldest version I’d recommend it 6.4.x…
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dan Little
Sent: Tuesday, March 06, 2018 1:47 PM
To: DamienZINS <damien.zins at intitek.fr>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] mapserver 4.8.3 errorsing libgd 2.0.16 (or higher) from ....
Have you installed the headers for GD? And depending on the complexity of your Mapfiles, it might be a good time to move to a newer version of MapServer. There have been a number of significant improvements since 4.8.3.
On Tue, Mar 6, 2018 at 4:26 AM, DamienZINS <damien.zins at intitek.fr<mailto:damien.zins at intitek.fr>> wrote:
Hi
I must translate a SOLARIS version in CENTOS 7 OS version
Above i put all versions sourve that i use
In the file configure from mapserver 4.8.3, for me $IS_GD2 will be never
true
then compilation stop with
configure: error: Could not find gd.h or libgd.a/libgd.so in
/gmao/old/install. Make sure GD 2.0.16 or higher is compiled before calling
configure. You may also get this error if you didn't specify the appropriate
location for one of GD's dependencies (freetype, libpng, libjpeg or
libiconv).
Somebody know why ?
ac_cv_lib_gd_gdFontCacheSetup=no
fi
rm -f conftest.err conftest.$ac_objext \
conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
echo "$as_me:$LINENO: result: $ac_cv_lib_gd_gdFontCacheSetup" >&5
echo "${ECHO_T}$ac_cv_lib_gd_gdFontCacheSetup" >&6
if test $ac_cv_lib_gd_gdFontCacheSetup = yes; then
IS_GD2="true"
fi
GD_NEED_ICONV_LIB="$ICONV_LIB"
fi
if test -n "$GD_INCLUDE" -a -n "$GD_LIBDIR" -a "$IS_GD2" = "true"; then
GD_INC=-I$GD_INCLUDE
GD_LIB="-L$GD_LIBDIR -lgd"
GD_XTRA_LIBS="$GD_XTRA_LIBS $GD_NEED_ICONV_LIB"
echo "$as_me:$LINENO: result: using libgd 2.0.16 (or higher)
from $GD_LIB $GD_XTRA_LIBS" >&5
echo "${ECHO_T} using libgd 2.0.16 (or higher) from $GD_LIB
$GD_XTRA_LIBS" >&6
informations CentOS :
[root at localhost mapserver-4.8.3]# cat /etc/redhat-release
CentOS Linux release 7.4.1708 (Core)
informations versions sources compiled :
[root at localhost old]# grep installation install.log
>>>>>>>>>> installation de freetype-2.8 <<<<<<<<<<
>>>>>>>>>> installation de zlib-1.2.11 <<<<<<<<<<
>>>>>>>>>> installation de libpng-1.6.32 <<<<<<<<<<
>>>>>>>>>> installation de proj-4.9.3 <<<<<<<<<<
>>>>>>>>>> installation de jpegsrc.v9b <<<<<<<<<<
>>>>>>>>>> installation de libiconv-1.15 <<<<<<<<<<
>>>>>>>>>> installation de libgd-2.2.5 <<<<<<<<<<
>>>>>>>>>> installation de gdal-2.2.1 <<<<<<<<<<
>>>>>>>>>> installation de apr-1.6.2 <<<<<<<<<<
>>>>>>>>>> installation de apr-util-1.6.0 <<<<<<<<<<
>>>>>>>>>> installation de pcre-8.41 <<<<<<<<<<
>>>>>>>>>> installation de httpd-2.4.27 <<<<<<<<<<
>>>>>>>>>> installation de tomcat-connectors-1.2.42-src <<<<<<<<<<
>>>>>>>>>> installation de php-4.4.2 <<<<<<<<<<
checking for Oracle (OCI8) support using ORACLE_HOME installation... no
| distribution in the file LICENSE. By continuing this installation |
| the installation process at this point. |
>>>>>>>>>> installation de mapserver-4.8.3 <<<<<<<<<<
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180306/024d48a8/attachment-0001.html>
