[mapserver-users] DEM
Jean-Christophe Malapert
jcmalapert at gmail.com
Thu Mar 29 07:36:34 PDT 2018
I have a DEM with the following information:
PROJCS["SimpleCylindrical Moon",
GEOGCS["GCS_Moon",
DATUM["D_Moon",
SPHEROID["Moon",1737400,0]],
PRIMEM["Reference_Meridian",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Equirectangular"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",0],
PARAMETER["standard_parallel_1",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-5458203.076000000350177,2729101.538000000175089)
Pixel Size = (118.450587586805568,-118.450587586805568)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-5458203.076, 2729101.538) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-5458203.076,-2729101.538) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 5458203.076, 2729101.538) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 5458203.076,-2729101.538) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Band 1 Block=92160x1 Type=Int16, ColorInterp=Gray
NoData Value=-32768
Offset: 0, Scale:0.5
>From my understanding of the DEM information, each pixel value must be
multiplied by 0.5. If I want to access to my DEM through the WCS protocol,
how can I say to mapserver to multiply each value by 0.5 so that my client
displays the right values ? If it is not possible, is there a way to have
this information in the getCapabilities ?
Thanks a lot,
Jean-Christophe
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20180329/130e2666/attachment-0001.html>
