[mapserver-users] Using a CRS not indexed by the IOGP
Jean-Christophe Malapert
jcmalapert at gmail.com
Tue Nov 13 01:37:05 PST 2018
Hello,
I got the same problem with Mars planet with IAU2000 namespace. I have
modified the mapserver code to make it works (I have still a couple of
tests to check everything is fine).
However, CRS, EPSG and AUTO namespaces are defined by OGC. So, if you
define a new one:
- 1/ I am not sure it is compatible with OGC standards
- 2/ I am not sure clients will understand this new namespace
In my case, I have also written the client.
If you are interested, I can share my current development about the
mapserver code.
Regards,
Jean-Christophe
Le lun. 12 nov. 2018 à 17:38, Luís Moreira de Sousa <
luis.de.sousa at protonmail.ch> a écrit :
> Dear all,
> I am developing a WMS with layers defined in a CRS that is not indexed by
> the IOGP. This CRS is defined within a specific PROJ namespace (e.g.
> init=namespace:001, just like others.extra or esri.extra) and is used
> correctly both by PROJ and GDAL. However, if I add this namescape to the
> "wms_srs" parameter in the mapfile, any request will be met with the
> following error message:
> msWMSLoadGetMapParams(): WMS server error. Unsupported SRS namespace (only
> EPSG and AUTO currently supported).
> I find this strange, is it only possible to use the CRSs indexed by the
> IOGP? Is there any way to convince MapServer to accept any other namespaces
> available in the PROJ database?
> I am awere I may create a fake IOGP index, but this is likely to create a
> good deal of confusion among users. I would rather make it clear this is a
> specific CRS.
> Thank you.
> Bowlespark 8
> 6701 DN Wageningen
> The Netherlands
> Phone: +31 628 544 755
> Email: luis.de.sousa at protonmail.ch
> RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
> URL: https://ldesousa.github.io
> Sent with ProtonMail <https://protonmail.com> Secure Email.
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20181113/348b68ff/attachment.html>
