[mapserver-users] Using a CRS not indexed by the IOGP
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Nov 13 07:33:11 PST 2018
Hi Jean-Christophe,
to which OGC standard are you refereing to, regarding the namespaces CRS, EPSG and AUTO?
Thank you.
Email: luis.de.sousa at protonmail.ch
RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
URL: https://ldesousa.github.io
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Tuesday, November 13, 2018 10:37 AM, Jean-Christophe Malapert <jcmalapert at gmail.com> wrote:
> Hello,
> I got the same problem with Mars planet with IAU2000 namespace. I have modified the mapserver code to make it works (I have still a couple of tests to check everything is fine).
> However, CRS, EPSG and AUTO namespaces are defined by OGC. So, if you define a new one:
> - 1/ I am not sure it is compatible with OGC standards
> - 2/ I am not sure clients will understand this new namespace
> In my case, I have also written the client.
> If you are interested, I can share my current development about the mapserver code.
> Regards,
> Jean-Christophe
> Le lun. 12 nov. 2018 à 17:38, Luís Moreira de Sousa <luis.de.sousa at protonmail.ch> a écrit :
>> Dear all,
>> I am developing a WMS with layers defined in a CRS that is not indexed by the IOGP. This CRS is defined within a specific PROJ namespace (e.g. init=namespace:001, just like others.extra or esri.extra) and is used correctly both by PROJ and GDAL. However, if I add this namescape to the "wms_srs" parameter in the mapfile, any request will be met with the following error message:
>> msWMSLoadGetMapParams(): WMS server error. Unsupported SRS namespace (only EPSG and AUTO currently supported).
>> I find this strange, is it only possible to use the CRSs indexed by the IOGP? Is there any way to convince MapServer to accept any other namespaces available in the PROJ database?
>> I am awere I may create a fake IOGP index, but this is likely to create a good deal of confusion among users. I would rather make it clear this is a specific CRS.
>> Thank you.
>> Bowlespark 8
>> 6701 DN Wageningen
>> The Netherlands
>> Phone: +31 628 544 755
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20181113/a03d5afb/attachment.html>
