[mapserver-users] Getting all endpoints on a single MapServer instance
Jonathan Moules
jonathan-lists at lightpear.com
Sat Oct 13 07:33:24 PDT 2018
I figure it's reasonable to assume that not all services end up in the
catalogues (for lots of reasons) - I'm already looking in lots of
catalogues - so I was hoping there was another way to get the other
endpoints if you already had at least one map on that server.
But if it can't be done, then it can't be done.
Thanks again,
Jonathan
On 2018-10-08 15:53, Lime, Steve D (MNIT) wrote:
> Correct, MapServer doesn't provide this capability. You'd have to uses a catalog services or write something custom.
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Passmore, James H.
> Sent: Monday, October 08, 2018 5:00 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Getting all endpoints on a single MapServer instance
>> Is there a way to get all the endpoints (maps) that are available from a given server?
> I hope not, each service should be isolated from another.
> To find different services from a single provider you should search some metadata catalogue, perhaps:
> http://mcc.jrc.ec.europa.eu/emis/dev.py?N=42&O=277&titre_page=Catalogue%20Service%20(CSW)&titre_chap=Data%20access
> James
> Today's Topics:
> 1. Getting all endpoints on a single MapServerinstance
> (Jonathan Moules)
> Message: 1
> Date: Sat, 6 Oct 2018 20:08:45 +0100
> From: Jonathan Moules <jonathan-lists at lightpear.com>
> Subject: [mapserver-users] Getting all endpoints on a single MapServer
> instance
> Message-ID: <92a837a1-0334-a0e3-6757-bdee4bc223f9 at lightpear.com>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Hi List,
> Or put another way, take this example where these two URL's both use different map files, and so have different layers (one is pointing to "wms_4km_modisa-bbp.map", the other to "wms_9km_seawifs-pp.map"):
> http://gmis.jrc.ec.europa.eu/cgi-bin/mapserv?map=/srv/www/htdocs/wms/wms_4km_modisa-bbp.map&service=wms&request=getcapabilities
> http://gmis.jrc.ec.europa.eu/cgi-bin/mapserv?map=/srv/www/htdocs/wms/wms_9km_seawifs-pp.map&service=wms&request=getcapabilities
> If I only knew one of those URL's, would it be possible for me to figure out the other one, ideally via a GET request?
> Thanks,
> Jonathan
> ________________________________
> This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
