[mapserver-users] Gallery: running mapserver in docker on kubernetes
Wouter Visscher wouter.visscher at gmail.com
Thu Aug 29 04:13:11 PDT 2019
For us it was/still is a learning curve regarding the vsicurl settings for
both vector and raster datasources. To improve on this we needed to learn
how to manipulatie the data and see how it interacts with gdal and
mapserver on level of the code.
Regarding the performance we 'solved' it (for our specific use-case) with
merging the rasterfiles, building new pyramides, and so on. So less files
are requested.
It's true that vsicurl does cache some data 25mb by default.
On Thu, 29 Aug 2019, 12:32 Yves Jacolin, <yves.jacolin at camptocamp.com>
wrote:
> Hello,
> We are also using Kubernetes/Openshift to deploy our application
> (MapServer based or not). For MapServer, we are also using visicurl for
> S3-hosted files. We saw some drawback when displaying maps on low scale as
> too much files should be read. Visicurl seems copy the files in the
> container. We need to check this to confirm, but probably someone have a
> better understanding of how visicurl and visis3 work.
> Y.
> Le jeu. 29 août 2019 à 09:56, Wouter Visscher <wouter.visscher at gmail.com>
> a écrit :
>> Hi all,
>> I'm working for the Dutch NSDI www.pdok.nl, where we have around 200
>> datasets ranging from the larger ones like address, buildings, cadastral
>> parcels and smaller ones like hikingtrails, natura2000, and so on. Our
>> platform is used a lot in the Netherlands, both by the public and private
>> sector, last year we hit 12 billion requests. To be able to handle that
>> amount of traffic we are now in a transition, moving from a private cloud
>> solution to the public cloud. With this change, we needed to refactor our
>> software stack.
>> Through some experimentation, and on the job 'training' we are now
>> running the following setup:
>> A minio.io (S3) blobstore, containing geopackages with the vector data
>> and geotiff's for the rasters.
>> Our mapserver configurations connects to these files with /vsicurl/. Our
>> mapservers are in docker containers that we run on kubernetes.
>> With this setup we are able to create a scalable infrastructure from
>> which we can push WMS/WFS/WMTS interfaces to the web.
>> If people are interested in how we deploy our mapserver software stacks I
>> would be happy to share our k8s deployment setup/configurations.
>> Wouter Visscher
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Yves Jacolin
> Training and support manager - Team Manager
> Camptocamp
> Tel (France) : +33 4 58 48 20 43
> Tel (Switzerland) : +41 21 619 10 43
> Mob. : +33 6 18 75 42 21
> email : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190829/7f5b7735/attachment-0001.html>
