[mapserver-users] Issue with label content for UNION layers
Steve Lime
sdlime at gmail.com
Tue Dec 10 19:56:47 PST 2019
What version?
On Tuesday, December 10, 2019, Julian Hollingbery <julian at northtech.dk>
wrote:
> Hi list,
> I’m seeing a strange phenomenon regarding label content for a layer with
> connectiontype UNION.
> A WMS request to the parent layer (including the UNION layer) produces the
> result I’d expect, but the same request directly to the UNION layer labels
> all features with the same label.
> Correct:
> http://172.30.229.42//fcgi-bin/mapserv.fcgi?map=/
> mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_
> Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=
> GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:
> 25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&
> STYLES=&FORMAT=image/png&TRANSPARENT=FALSE
> <http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
> Wrong:
> 25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&
> <http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
> The reponses can be seen here: https://www.dropbox.com/sh/
> 121shf8djnx3b3d/AAAApGTLfcuga_mXWDaWFsKQa?dl=0
> Any thoughts?
> Best Regards,
> Julian
> MAP
> NAME "danske_stednavne"
> EXTENT 120000 5900000 1000000 6500000
> MAXSIZE 10000
> OUTPUTFORMAT
> NAME "png24"
> DRIVER "AGG/PNG"
> MIMETYPE "image/png; mode=24bit"
> EXTENSION "png"
> IMAGEMODE "RGB"
> FORMATOPTION INTERLACE=OFF
> END
> PROJECTION
> "init=epsg:25832"
> END
> DEBUG 0
> CONFIG "ON_MISSING_DATA" "LOG"
> FONTSET "fonts/fontset.txt"
> WEB
> METADATA
> "wms_srs" "EPSG:25832 EPSG:4326 EPSG:4258 EPSG:25833
> EPSG:32632 EPSG:32633 EPSG:4093 EPSG:4094 EPSG:4095 EPSG:4096 EPSG:3395
> EPSG:3857"
> END
> END
> LAYER
> NAME "landskabsform"
> TEMPLATE "blank.html"
> LABELITEM skrivemaade
> STATUS DEFAULT
> TYPE polygon
> CONNECTIONTYPE UNION
> CONNECTION "oer_store,oer_mellem"
> METADATA
> "wms_srs" "epsg:25832"
> END
> PROJECTION
> "init=epsg:25832"
> END
> STYLEITEM "AUTO"
> # Define an empty class that will be filled at runtime from the
> color and
> # styles read from each source layer.
> CLASS
> END
> END #LAYER
> LAYER
> NAME "oer_store"
> INCLUDE "./danske_stednavne_post_include.map"
> DATA "geometri from stednavne_nohist_l1_wms.oer_store using
> unique objectid using srid=25832"
> TYPE polygon
> STATUS OFF
> LABELITEM "skrivemaade"
> METADATA
> END
> PROJECTION
> "init=epsg:25832"
> END
> CLASS
> STYLE
> OUTLINECOLOR 91 91 91
> WIDTH 1
> END #STYLE
> LABEL
> COLOR 0 0 0
> FONT "verdana"
> TYPE truetype
> SIZE 12
> END #LABEL
> END #CLASS
> END #LAYER
> LAYER
> NAME "oer_mellem"
> DATA "geometri from stednavne_nohist_l1_wms.oer_mellem using
> TYPE polygon
> STATUS OFF
> METADATA
> END
> PROJECTION
> "init=epsg:25832"
> END
> CLASS
> STYLE
> WIDTH 1
> END #STYLE
> LABEL
> COLOR 0 0 0
> FONT "verdana"
> TYPE truetype
> SIZE 10
> END #LABEL
> END #CLASS
> END #LAYER
> END #MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191210/915cb2ae/attachment.html>
