[mapserver-users] Issue with label content for UNION layers
Julian Hollingbery
julian at northtech.dk
Tue Dec 10 02:39:20 PST 2019
Hi list,
I’m seeing a strange phenomenon regarding label content for a layer with connectiontype UNION.
A WMS request to the parent layer (including the UNION layer) produces the result I’d expect, but the same request directly to the UNION layer labels all features with the same label.
Correct:
http://172.30.229.42//fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE<http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=danske_stednavne&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
Wrong:
http://172.30.229.42//fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE<http://172.30.229.42/fcgi-bin/mapserv.fcgi?map=/mapserver/config/mapfiler/WMS/Danske_Stednavne/Danske_Stednavne_test.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=588000.0,6042000.0,888000.0,6342000.0&CRS=EPSG:25832&WIDTH=500&HEIGHT=500&LAYERS=landskabsform&STYLES=&FORMAT=image/png&TRANSPARENT=FALSE>
The reponses can be seen here: https://www.dropbox.com/sh/121shf8djnx3b3d/AAAApGTLfcuga_mXWDaWFsKQa?dl=0
Any thoughts?
Best Regards,
Julian
MAP
NAME "danske_stednavne"
EXTENT 120000 5900000 1000000 6500000
MAXSIZE 10000
OUTPUTFORMAT
NAME "png24"
DRIVER "AGG/PNG"
MIMETYPE "image/png; mode=24bit"
EXTENSION "png"
IMAGEMODE "RGB"
FORMATOPTION INTERLACE=OFF
END
PROJECTION
"init=epsg:25832"
END
DEBUG 0
CONFIG "ON_MISSING_DATA" "LOG"
FONTSET "fonts/fontset.txt"
WEB
METADATA
"wms_srs" "EPSG:25832 EPSG:4326 EPSG:4258 EPSG:25833 EPSG:32632 EPSG:32633 EPSG:4093 EPSG:4094 EPSG:4095 EPSG:4096 EPSG:3395 EPSG:3857"
END
END
LAYER
NAME "landskabsform"
TEMPLATE "blank.html"
LABELITEM skrivemaade
STATUS DEFAULT
TYPE polygon
CONNECTIONTYPE UNION
CONNECTION "oer_store,oer_mellem"
METADATA
"wms_srs" "epsg:25832"
END
PROJECTION
"init=epsg:25832"
END
STYLEITEM "AUTO"
# Define an empty class that will be filled at runtime from the color and
# styles read from each source layer.
CLASS
END
END #LAYER
LAYER
NAME "oer_store"
INCLUDE "./danske_stednavne_post_include.map"
DATA "geometri from stednavne_nohist_l1_wms.oer_store using unique objectid using srid=25832"
TYPE polygon
STATUS OFF
LABELITEM "skrivemaade"
METADATA
END
PROJECTION
"init=epsg:25832"
END
CLASS
STYLE
OUTLINECOLOR 91 91 91
WIDTH 1
END #STYLE
LABEL
COLOR 0 0 0
FONT "verdana"
TYPE truetype
SIZE 12
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME "oer_mellem"
DATA "geometri from stednavne_nohist_l1_wms.oer_mellem using unique objectid using srid=25832"
TYPE polygon
STATUS OFF
METADATA
END
PROJECTION
"init=epsg:25832"
END
CLASS
STYLE
WIDTH 1
END #STYLE
LABEL
COLOR 0 0 0
FONT "verdana"
TYPE truetype
SIZE 10
END #LABEL
END #CLASS
END #LAYER
END #MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191210/84ee78c4/attachment-0001.html>
