[mapserver-users] Rendering TrueType labels.
Lime, Steve D (MNIT) steve.lime at state.mn.us
Wed Feb 27 12:14:42 PST 2019
Can you post some visuals (and/or layer snippets) that demonstrate each case? That would help... It's not clear if this a result of layer compositing or strictly related to label matching/caching.
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Marek Bak
Sent: Wednesday, February 27, 2019 10:01 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Rendering TrueType labels.
Hello All,
Can anyone explain how the rendering engine works? For example I have
four layers:
case1. Polygon
case2. Point which is presented as symbol (circle) with truetype label
case3. Polygon which is more detailed version of layers case1
case4. Point which is presented as symbol (circle) with truetype label
which is more detailed version of layers case2
The problem is that composition (shadownig) during rendering (default
src-over compop) works only for Polygon and Symbol. The label is
preserved and final tile has one Symbol but with two labels. Is there
any way to disable that behaviour?
Regards,
Marek
mapserver-users mailing list
https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=02%7C01%7Csteve.lime%40state.mn.us%7C72f1427468e142a36f7c08d69cce0cee%7Ceb14b04624c445198f26b89c2159828c%7C0%7C1%7C636868806132112515&sdata=7k2h8mhQApfceAbqTKs5eCf7XS8Ms3GbBj7Jc0wrX68%3D&reserved=0
