[mapserver-users] Lost the transparency after a SO Update
Seth G
sethg at geographika.co.uk
Mon Sep 30 06:30:38 PDT 2019
Hi Andrea,
Do you have a cut-down Mapfile to reproduce this?
Are you using the COMPOSITE block to set OPACITY?
https://mapserver.org/mapfile/composite.html#parameters
Setting OPACITY on the layer directly is deprecated since 7.0
Seth
web:http://geographika.co.uk
twitter: @geographika
On Mon, Sep 30, 2019, at 2:49 PM, Andrea Peri wrote:
> Hi,
> seem the issue is due to a more recent trunk of mapserver.
> I try with an older trunk version and it work . The transparency is ok.
> So the issue is in the last trunk.
> A.
> Il giorno lun 30 set 2019 alle ore 14:14 Andrea Peri <aperi2007 at gmail.com> ha scritto:
>> Hi,
>> After update the Linux Debian to last Burst version , and recompile gdal and mapserver, I see the mapserver was no more capable to produce png images with transparency.
>> I guess there is some library wrong.
>> I try also to set gdal to recmpile using the internal version of png but don't seem to have any result.
>> Any help is welcome.
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190930/45d18dee/attachment.html>
