[mapserver-users] Lost the transparency after a SO Update
Andrea Peri
aperi2007 at gmail.com
Mon Sep 30 07:56:01 PDT 2019
this is the class I use
The transparenc is used if RGBA hex.
COLOR "#e1cc4f7f"
CLASS
NAME ' '
GROUP 'avorio'
MAXSCALEDENOM 5000000
MINSCALEDENOM 1
STYLE
COLOR "#e1cc4f7f"
ANTIALIAS false
MINSCALEDENOM 1
END
STYLE
WIDTH 2.0
OUTLINECOLOR "#e1cc4f"
ANTIALIAS false
MINSCALEDENOM 1
END
END
Il giorno lun 30 set 2019 alle ore 15:31 Seth G <sethg at geographika.co.uk>
ha scritto:
> Hi Andrea,
> Do you have a cut-down Mapfile to reproduce this?
> Are you using the COMPOSITE block to set OPACITY?
> https://mapserver.org/mapfile/composite.html#parameters
> Setting OPACITY on the layer directly is deprecated since 7.0
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Mon, Sep 30, 2019, at 2:49 PM, Andrea Peri wrote:
> Hi,
> seem the issue is due to a more recent trunk of mapserver.
> I try with an older trunk version and it work . The transparency is ok.
> So the issue is in the last trunk.
> A.
> Il giorno lun 30 set 2019 alle ore 14:14 Andrea Peri <aperi2007 at gmail.com>
> ha scritto:
> Hi,
> After update the Linux Debian to last Burst version , and recompile gdal
> and mapserver, I see the mapserver was no more capable to produce png
> images with transparency.
> I guess there is some library wrong.
> I try also to set gdal to recmpile using the internal version of png but
> don't seem to have any result.
> Any help is welcome.
> Thx,
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190930/66b4abfc/attachment-0001.html>
