[mapserver-users] Lost the transparency after a SO Update
Seth G
sethg at geographika.co.uk
Mon Sep 30 08:26:08 PDT 2019
Actually that does remind me of a recent issue I had when updating from 7.2 to 7.4. I have the following diff:
STYLE
# add an almost fully translucent colour
# setting the aa value to 00 in the rrggbbaa setting causes any masked layers to no
# longer display
COLOR "#FFFFFF01"
END
The above no longer worked and I updated to:
STYLE
# add an almost fully translucent colour - if no colour then no MASK
COLOR "#ffffff"
OPACITY 1
END
web:http://geographika.co.uk
twitter: @geographika
On Mon, Sep 30, 2019, at 4:56 PM, Andrea Peri wrote:
> Hi,
> this is the class I use
> The transparenc is used if RGBA hex.
> COLOR "#e1cc4f7f"
> CLASS
> NAME ' '
> GROUP 'avorio'
> MAXSCALEDENOM 5000000
> MINSCALEDENOM 1
> STYLE
> COLOR "#e1cc4f7f"
> ANTIALIAS false
> MINSCALEDENOM 1
> END
> STYLE
> WIDTH 2.0
> OUTLINECOLOR "#e1cc4f"
> ANTIALIAS false
> MINSCALEDENOM 1
> END
> END
> Il giorno lun 30 set 2019 alle ore 15:31 Seth G <sethg at geographika.co.uk> ha scritto:
>> __
>> Hi Andrea,
>> Do you have a cut-down Mapfile to reproduce this?
>> Are you using the COMPOSITE block to set OPACITY?
>> https://mapserver.org/mapfile/composite.html#parameters
>> Setting OPACITY on the layer directly is deprecated since 7.0
>> Seth
>> On Mon, Sep 30, 2019, at 2:49 PM, Andrea Peri wrote:
>>> Hi,
>>> seem the issue is due to a more recent trunk of mapserver.
>>> I try with an older trunk version and it work . The transparency is ok.
>>> So the issue is in the last trunk.
>>> A.
>>> Il giorno lun 30 set 2019 alle ore 14:14 Andrea Peri <aperi2007 at gmail.com> ha scritto:
>>>> Hi,
>>>> After update the Linux Debian to last Burst version , and recompile gdal and mapserver, I see the mapserver was no more capable to produce png images with transparency.
>>>> I guess there is some library wrong.
>>>> I try also to set gdal to recmpile using the internal version of png but don't seem to have any result.
>>>> Any help is welcome.
>>>> Thx,
>>>> Andrea Peri
>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190930/9fb0a06e/attachment.html>
