[mapserver-users] Lost the transparency after a SO Update
Andrea Peri
aperi2007 at gmail.com
Mon Sep 30 08:36:30 PDT 2019
The "#ffffff01" sintax was dismissed ?
The 7.4.2 docs don't report this.
------ from https://www.mapserver.org/mapfile/style.html
RGBA value (adding translucence): “#rrggbbaa”. To specify a
semi-translucent magenta, the following is used:
COLOR "#FF00FFCC"
I try this sintax with OPACITY.
Thx,
A.
Il giorno lun 30 set 2019 alle ore 17:26 Seth G <sethg at geographika.co.uk>
ha scritto:
> Actually that does remind me of a recent issue I had when updating from
> 7.2 to 7.4. I have the following diff:
> STYLE
> # add an almost fully translucent colour
> # setting the aa value to 00 in the rrggbbaa setting causes
> any masked layers to no
> # longer display
> COLOR "#FFFFFF01"
> END
> The above no longer worked and I updated to:
> STYLE
> # add an almost fully translucent colour - if no colour then
> no MASK
> COLOR "#ffffff"
> OPACITY 1
> END
> web:http://geographika.co.uk
> twitter: @geographika
> On Mon, Sep 30, 2019, at 4:56 PM, Andrea Peri wrote:
> Hi,
> this is the class I use
> The transparenc is used if RGBA hex.
> COLOR "#e1cc4f7f"
> CLASS
> NAME ' '
> GROUP 'avorio'
> MAXSCALEDENOM 5000000
> MINSCALEDENOM 1
> STYLE
> COLOR "#e1cc4f7f"
> ANTIALIAS false
> MINSCALEDENOM 1
> END
> STYLE
> WIDTH 2.0
> OUTLINECOLOR "#e1cc4f"
> ANTIALIAS false
> MINSCALEDENOM 1
> END
> END
> Il giorno lun 30 set 2019 alle ore 15:31 Seth G <sethg at geographika.co.uk>
> ha scritto:
> Hi Andrea,
> Do you have a cut-down Mapfile to reproduce this?
> Are you using the COMPOSITE block to set OPACITY?
> https://mapserver.org/mapfile/composite.html#parameters
> Setting OPACITY on the layer directly is deprecated since 7.0
> Seth
> On Mon, Sep 30, 2019, at 2:49 PM, Andrea Peri wrote:
> Hi,
> seem the issue is due to a more recent trunk of mapserver.
> I try with an older trunk version and it work . The transparency is ok.
> So the issue is in the last trunk.
> A.
> Il giorno lun 30 set 2019 alle ore 14:14 Andrea Peri <aperi2007 at gmail.com>
> ha scritto:
> Hi,
> After update the Linux Debian to last Burst version , and recompile gdal
> and mapserver, I see the mapserver was no more capable to produce png
> images with transparency.
> I guess there is some library wrong.
> I try also to set gdal to recmpile using the internal version of png but
> don't seem to have any result.
> Any help is welcome.
> Thx,
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20190930/4d2b4a54/attachment.html>
