[mapserver-users] Create a tileindex for WFS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Apr 12 08:07:53 PDT 2021
Since you are using MS4W here are some specific steps for your PostGIS
query/speed testing (I am adding this now to the documentation on
mapserver.org also) :
- add into your MAP-level of your mapfile:
CONFIG "CPL_DEBUG" "ON"
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
DEBUG 5
- add into your PostGIS LAYER of your mapfile:
DEBUG 5
- now use a WFS client such as QGIS and add your WFS PostGIS layer
- open "/ms4w/tmp/ms_error.txt" in Notepad++
- search for "msPostGISLayerWhichShapes query:"
- that line should list the long exact query sent from MapServer to the
PostreSQL instance, it may look like:
[Mon Apr 12 11:27:34 2021].207000 msPostGISLayerWhichShapes query:
SELECT
"gid"::text,"area"::text,"perimeter"::text,"province_"::text,"province_i"::text,"status"::text,"name"::text,"name_e"::text,"name_f"::text,"reg_code"::text,"poly_featu"::text,"island"::text,"island_e"::text,"island_f"::text,ST_AsBinary(("geom"),'NDR')
as geom,"gid"::text FROM province WHERE "geom" &&
ST_GeomFromText('POLYGON((-5814679.36987815
-1504714.04276694,-5814679.36987815 4439806.52253364,5943763.33635122
4439806.52253364,5943763.33635122 -1504714.04276694,-5814679.36987815
-1504714.04276694))',3978) LIMIT 2 OFFSET 0
- now connect to that database through psql.exe
psql -U postgres -p 5432 -d mydb
- using that error file line, grab everything from "SELECT", and inside
your database prompt, start the command with "EXPLAIN ANALYZE" and then
paste your full query, such as:
mydb=# EXPLAIN ANALYZE SELECT
-1504714.04276694))',3978) LIMIT 2 OFFSET 0;
- the response will tell you how long that query took, such as:
Execution time: 0.293 ms
Hope that helps you a little more,
Thank-you for using MS4W.
"MS4W: open doors as well as windows"
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-04-12 9:00 a.m., mathias cunault via mapserver-users wrote:
> Hello,
> In a PostgreSQL 13 database, I have 3 materialized views with 2578,
> 22013 and 62500 rows.
> I am using MS4W 4.0.3 to generate a WFS based on these 3 views.
> The aim is for users to display these WFS in QGIS.
> I have other lightweight views in PostgreSQL that can be easily
> displayed, but these 3 materialized views seem to be too heavy to
> display because some messages say that Downloading the layer entities
> has failed or partially failed.
> I wonder if using a tileindex was a good idea to speed up the display.
> Before going further in the developments, I would like your opinion
> about two things :
> * I have to cut my views in "slices" before create a tileIndex for
> each one.
> * The tileindex can be stored in postgis database.
> Am I right?
> If not is there a better solution ?
> Thanks for your help
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
