[mapserver-users] Fwd: MapServer 7 arithmetic expressions do not work on STYLE attributes?
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Jun 16 02:09:50 PDT 2022
Adding a link to the same question asked earlier in gis.stackexchange: https://gis.stackexchange.com/questions/433659/mapserver-7-arithmetic-expressions-do-not-work-on-style-attributes/433664#433664.
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Andi p3 Domi
Lähetetty: torstai 16. kesäkuuta 2022 12.05
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Fwd: MapServer 7 arithmetic expressions do not work on STYLE attributes?
I am trying to port my code from MapServer 5 (Oracle) to MapServer 7 (PostgreSQL), but I am encountering an issue when trying to apply arithmetic expressions in the style class. So previously in MapServer 5 I would have something like:
DATA "geom from (select pk, geom, size from sizes_of_thing) USING srid 3788 version 11g"
CLASS
    MAXSCALEDENOM 5001
    STYLE
        COLOR [size*2]
Which worked perfectly fine: But if I convert it to MapServer 7 and PostgreSQL like:
DATA "geom from (select pk, geom, size from sizes_of_thing sot) USING unique pk USING srid=3788"
CLASS
    STYLE
        COLOR [size*2]
Throws an error such as:
msPostGISLayerWhichShapes(): Error (ERROR:  column "size*2" does not exist
By any chance are these expressions not supported anymore in MapServer 7/PostGIS or am I doing something wrong?
What I have tried so far is to write something like
SIZE [size]*2
SIZE ([size]*2)
create an expression like:
EXPRESSION ("size2" "[size]*2")
And use it in something like:
SIZE [size2]
create a validation variable such as:
VALIDATION
"size2" '[size]*2'
and then
SIZE [size2]
But it seems like none of them work.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220616/f868557a/attachment.htm>
More information about the MapServer-users mailing list
