[OpenDroneMap-dev] refactor 'run.pl' to a python class definition ahead of Open MPI integration
Daryl Van Dyke vandyke.geospatial at gmail.com
Fri May 8 19:04:09 PDT 2015
Hi -
Long time listener, first time caller...
I have been thinking about a python class that leverage OpenDroneMap since
the first time I looked at the perl driver.  I don't know perl, but could
discern the general pattern.
I'd like to start a pseudocode class definition diagram  for what it might
look like.  I see it as an object of -model- which would be initialized
from an initial set of images.  The sequential steps of the perl script
would become methods, with the ability to keep track of which results are
associated with (result from) which parameter configs.
If I wanted to take a stab at this - could I open a wiki page on GitHub?  I
don't want to appear dis-respectful as a newcomer, but perl is a barrier
for me and I see many benefits to transitioning the driver to python 2.7.
Daryl
On May 8, 2015 8:34 PM, "Stephen Mather" <stephen at smathermather.com> wrote:
> Shared, or the messy part of passing data around...
> Looking at the portions of the toolchain:
> resize -- easily can be massively parallelized (also not a bottleneck)
> keypoints -- same, but is a slow process now
> match -- harder to parallelize without *a priori* knowledge of likely
> matches
> bundler -- currently not fully parallelized and a major bottleneck
> cmvs/pmvs -- CMVS chops the scene into bite-sized chunks, making PMVS work
> within smaller, reassembleable scene chunks. Ideal for distribution
> meshing -- not sure, but fast to run relative to rest of toolchain
> texturing -- not sure, but fast to run relative to rest of toolchain
> georeferencing -- not sure, but fast to run relative to rest of toolchain
> orthophoto -- not sure, but fast to run relative to rest of toolchain
> match is probably the hardest part to efficiently parallize without shared
> storage, but with some a priori knowledge of likely matching images (e.g.
> exif geolocation), something clever might be done to overcome this
> limitation.
> Cheers,
> Best,
> Steve
> On Mon, Apr 27, 2015 at 6:38 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
>> On 04/27/2015 09:18 AM, Bales, Donald J. wrote:
>> > All,
>> > Forgive me if you feel this inquiry is misplaced, but I was wondering
>> if OpenDroneMap has an OpenMPI implementation, or if you know of any
>> OpenMPI implementation for image processing?  If not, is there any interest
>> in the OpenDroneMap community to create an OpenMPI implementation so one
>> can leverage high performance computing platforms?
>> > Sincerely,
>> > Donald J. Bales
>> > (630) 776-0071
>> We have been talking about converting the current Perl master script to
>> something in Python (possibly flask based). At that point there would be
>> good places to hook in an MPI library for python.
>> The tricky part is going to be an efficient means of distributing the
>> data. If you have a compute cluster this shouldn't be an issue (assuming
>> you have some sort of shared storage). If you use Amazon it might mean
>> you have all your nodes reads from the same S3, etc.
>> Thanks,
>> Alex
>> OpenDroneMap-dev mailing list
>> OpenDroneMap-dev at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20150508/3eda4128/attachment.html>
More information about the OpenDroneMap-dev mailing list
