[OpenDroneMap-dev] OpenMPI
Stephen Mather stephen at smathermather.com
Fri May 8 18:34:20 PDT 2015
Shared, or the messy part of passing data around...
Looking at the portions of the toolchain:
resize -- easily can be massively parallelized (also not a bottleneck)
keypoints -- same, but is a slow process now
match -- harder to parallelize without *a priori* knowledge of likely
matches
bundler -- currently not fully parallelized and a major bottleneck
cmvs/pmvs -- CMVS chops the scene into bite-sized chunks, making PMVS work
within smaller, reassembleable scene chunks. Ideal for distribution
meshing -- not sure, but fast to run relative to rest of toolchain
texturing -- not sure, but fast to run relative to rest of toolchain
georeferencing -- not sure, but fast to run relative to rest of toolchain
orthophoto -- not sure, but fast to run relative to rest of toolchain
match is probably the hardest part to efficiently parallize without shared
storage, but with some a priori knowledge of likely matching images (e.g.
exif geolocation), something clever might be done to overcome this
limitation.
Cheers,
Best,
Steve
On Mon, Apr 27, 2015 at 6:38 PM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> On 04/27/2015 09:18 AM, Bales, Donald J. wrote:
> > All,
> > Forgive me if you feel this inquiry is misplaced, but I was wondering if
> OpenDroneMap has an OpenMPI implementation, or if you know of any OpenMPI
> implementation for image processing?  If not, is there any interest in the
> OpenDroneMap community to create an OpenMPI implementation so one can
> leverage high performance computing platforms?
> > Sincerely,
> > Donald J. Bales
> > (630) 776-0071
> We have been talking about converting the current Perl master script to
> something in Python (possibly flask based). At that point there would be
> good places to hook in an MPI library for python.
> The tricky part is going to be an efficient means of distributing the
> data. If you have a compute cluster this shouldn't be an issue (assuming
> you have some sort of shared storage). If you use Amazon it might mean
> you have all your nodes reads from the same S3, etc.
> Thanks,
> Alex
> OpenDroneMap-dev mailing list
> OpenDroneMap-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20150508/3501aeeb/attachment.html>
More information about the OpenDroneMap-dev mailing list
