[OpenDroneMap-users] laptop recommendation
Stephen Mather stephen at smathermather.com
Sun Apr 12 10:44:04 PDT 2015
In that case Fred,
Go with a "Desktop Replacement" type laptop, and you'll do OK.
Cheers,
Best,
Steve
On Apr 12, 2015 1:27 PM, "Frederic Muller" <fred at cm17.com> wrote:
> On 04/13/2015 12:12 AM, Alex Mandel wrote:
> > On 04/12/2015 05:48 AM, Frederic Muller wrote:
> >> Hi!
> >> I was thinking to add a laptop to my hexacopter which purpose is to do
> >> orthophoto. Do you have any recommendation regarding the CPU/RAM/HDD and
> >> Video for such a dedicated machine?
> >> What do you guys run ODM on?
> >> Thanks a lot.
> >> Fred
> > My recommendation is to not use a laptop. I'm also confused about your
> > wording, you want to fly the laptop or just use the laptop to
> > post-process the images. Is the reason for a laptop so you can see
> > results in the field? That's unrealistic unless you subsample to a very
> > small set of photos.
> > A desktop, server, or virtualized server will in almost all cases
> > provide faster results. In the case of virtualized you can also only pay
> > a few cents an hour when you use it.
> > CPU seems to matter the most right now so Intel i7 or 2600v3 cpu, solid
> > state disks never hurt. At this time ODM does not appear to need huge
> > amounts of RAM. It also does not yet leverage any GPU offloading, though
> > there has been discussion of it.
> > -Alex
> Sorry for the confusion. The "system" (read hexacopter + computer) will
> be used in a remote area with no internet access. The plan is to use
> Mission Planner for the mission planning and ODM for the image
> post-processing. A desktop does not seem the best solution in our case
> as infrastructure is very bad too (unreliable electricity sources, etc).
> We are thinking to have a casing with everything inside for easy of
> transportation and protection.
> Thanks for the other details as those will help.
> Fred
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150412/8c8fda23/attachment.html>
More information about the OpenDroneMap-users mailing list
