[OpenDroneMap-users] Orthorectified Imagery using separate coordinates file
ben at calvin-robotics.com ben at calvin-robotics.com
Sat Jun 13 05:21:56 PDT 2015
Ok great, I can just write a script that writes it to the EXIF data of each image. I'll have a look at exiftool.
Ben Nortierben at calvin-robotics.com
+27 (73) 128 7235
On Sat, Jun 13, 2015 at 1:23 PM, Stephen Mather <stephen at smathermather.com>
wrote:
> Yes, Simon's solution is a good one.
> Cheers,
> Best,
> Steve
> On Jun 12, 2015 4:43 PM, "Simon" <s_mailinglist at geraschs.de> wrote:
>> Hi Ben,
>> no I think it is not possible at the moment.
>> But exiftool is capable of reading in a gpx file and writing the
>> positions to the EXIF tags.
>> Just have a look at that neat post:
>> http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html
>> I will test that solution probably Monday or Tuesday...
>> Regards,
>> Simon
>> On 06/12/2015 12:51 PM, ben at calvin-robotics.com wrote:
>> > Hi
>> > Firstly, this project is fantastic, thanks, I’m really looking forward
>> > to seeing how it grows.
>> > My question relates to using a separate GPS log file for the location
>> > of the photos, as opposed to using the EXIF GPS data. This would be
>> > the case if you want to use the more accurate drone GPS data, or if
>> > the images aren’t tagged with GPS location.
>> > Is this possible with OpenDroneMap?
>> > Thanks in advance
>> > Ben Nortier
>> > Ben Nortier
>> > +27 (73) 128 7235
>> > _______________________________________________
>> > OpenDroneMap-users mailing list
>> > OpenDroneMap-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150613/9ed58794/attachment.html>
More information about the OpenDroneMap-users mailing list
