[OpenDroneMap-users] Orthorectified Imagery using separate coordinates file
Stephen Mather stephen at smathermather.com
Sat Jun 13 05:36:06 PDT 2015
Also check out geotag_from_gpx in Mapillary's repo of python tools:
https://github.com/mapillary/mapillary_tools/blob/master/python/README.md
Cheers,
Best,
Steve
On Jun 13, 2015 8:21 AM, <ben at calvin-robotics.com> wrote:
> Ok great, I can just write a script that writes it to the EXIF data of
> each image. I'll have a look at exiftool.
> Ben Nortier
> +27 (73) 128 7235
> On Sat, Jun 13, 2015 at 1:23 PM, Stephen Mather <stephen at smathermather.com
> > wrote:
>> Yes, Simon's solution is a good one.
>> Cheers,
>> Best,
>> Steve
>> On Jun 12, 2015 4:43 PM, "Simon" <s_mailinglist at geraschs.de> wrote:
>>> Hi Ben,
>>> no I think it is not possible at the moment.
>>> But exiftool is capable of reading in a gpx file and writing the
>>> positions to the EXIF tags.
>>> Just have a look at that neat post:
>>> http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html
>>> I will test that solution probably Monday or Tuesday...
>>> Regards,
>>> Simon
>>> On 06/12/2015 12:51 PM, ben at calvin-robotics.com wrote:
>>> > Hi
>>> > Firstly, this project is fantastic, thanks, I’m really looking forward
>>> > to seeing how it grows.
>>> > My question relates to using a separate GPS log file for the location
>>> > of the photos, as opposed to using the EXIF GPS data. This would be
>>> > the case if you want to use the more accurate drone GPS data, or if
>>> > the images aren’t tagged with GPS location.
>>> > Is this possible with OpenDroneMap?
>>> > Thanks in advance
>>> > Ben Nortier
>>> > Ben Nortier
>>> > +27 (73) 128 7235
>>> > _______________________________________________
>>> > OpenDroneMap-users mailing list
>>> > OpenDroneMap-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150613/2f1f5d14/attachment.html>
More information about the OpenDroneMap-users mailing list
