[OpenDroneMap-users] Bundler error
Ivan Ma ivanma72 at gmail.com
Sun Jun 14 13:04:58 PDT 2015
Hey Steve,
It's not one of the sample datasets provided. I took some images with my
smartphone camera (HTC One M8), added the smartphone name CCD sensor info,
and ran it to see what would happen. The weird thing is, I ran ODM using
the caliterra dataset and everything seemed fine. Maybe it's something to
do with the images taken by my phone?
Specs: LInux Mint 17.1 64-bit, i5-2430M, 6GB RAM
Thanks,
Ivan
On Sat, Jun 6, 2015 at 9:20 PM, Stephen Mather <stephen at smathermather.com>
wrote:
> Hi Ivan,
> Which dataset, and what are the specifications of the machine you are
> running on?
> Thanks,
> Best,
> Steve
> On Sat, Jun 6, 2015 at 7:26 PM, Ivan Ma <ivanma72 at gmail.com> wrote:
>> Getting this error trying to get some sample pictures stitched:
>> quitting cause:
>> "/home/ivanma/Documents/MDP/odm_test/../OpenDroneMap/bin/bundler"
>> "/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/list.txt"
>> --options_file
>> "/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/options.txt"
>> > bundle/out
>> returned with code 256
>> The contents of out:
>> [OnInit] Running program
>> Loading images from file
>> '/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/list.txt'
>> [BundlerApp::OnInit] Processing options...
>> [BundlerApp::OnInit] Loading frame...
>> [BundlerApp::OnInit] Loading images...
>> [LoadMatchTable] Loading matches
>> [LoadMatchTable] Error opening file matches.init.txt for reading
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150614/9b8f28d0/attachment.html>
More information about the OpenDroneMap-users mailing list
