[OpenDroneMap-users] Bundler error
Stephen Mather stephen at smathermather.com
Sun Jun 14 14:06:14 PDT 2015
The optics for cameras on phones are not great. That could easily be the
issue. Try the branch referenced in pull request #50. It uses OpenSfM which
is better for cameras on smart phones.
Cheers,
Best,
Steve
On Jun 14, 2015 4:04 PM, "Ivan Ma" <ivanma72 at gmail.com> wrote:
> Hey Steve,
> It's not one of the sample datasets provided. I took some images with my
> smartphone camera (HTC One M8), added the smartphone name CCD sensor info,
> and ran it to see what would happen. The weird thing is, I ran ODM using
> the caliterra dataset and everything seemed fine. Maybe it's something to
> do with the images taken by my phone?
> Specs: LInux Mint 17.1 64-bit, i5-2430M, 6GB RAM
> Thanks,
> Ivan
> On Sat, Jun 6, 2015 at 9:20 PM, Stephen Mather <stephen at smathermather.com>
> wrote:
>> Hi Ivan,
>> Which dataset, and what are the specifications of the machine you are
>> running on?
>> Thanks,
>> Best,
>> Steve
>> On Sat, Jun 6, 2015 at 7:26 PM, Ivan Ma <ivanma72 at gmail.com> wrote:
>>> Getting this error trying to get some sample pictures stitched:
>>> quitting cause:
>>> "/home/ivanma/Documents/MDP/odm_test/../OpenDroneMap/bin/bundler"
>>> "/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/list.txt"
>>> --options_file
>>> "/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/options.txt"
>>> > bundle/out
>>> returned with code 256
>>> The contents of out:
>>> [OnInit] Running program
>>> Loading images from file
>>> '/home/ivanma/Documents/MDP/odm_test/reconstruction-with-image-size-2400/list.txt'
>>> [BundlerApp::OnInit] Processing options...
>>> [BundlerApp::OnInit] Loading frame...
>>> [BundlerApp::OnInit] Loading images...
>>> [LoadMatchTable] Loading matches
>>> [LoadMatchTable] Error opening file matches.init.txt for reading
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150614/db1bd0be/attachment.html>
More information about the OpenDroneMap-users mailing list
