[OpenDroneMap-users] ODM textured mesh
Stephen Mather stephen at smathermather.com
Sat Jun 27 14:06:39 PDT 2015
If I did everything correctly, you can just use this version:
https://github.com/OpenDroneMap/OpenDroneMap/pull/122
Will verify the changes Monday.
Cheers,
Best,
Steve
On Sat, Jun 27, 2015 at 4:53 PM, Stephen Mather
<stephen at smathermather.com> wrote:
> Hi Bruno,
> Try the texturing changes that come with Gerald's pull request here,
> through read the dialog, because a couple of changes will be needed
> before use.
> https://github.com/OpenDroneMap/OpenDroneMap/pull/113
> This will be merged soon, and I think will be worth testing for your dataset.
> Also, see recent posts on upcoming changes from Mapillary and
> Spotscale contributions.
> Cheers,
> Best,
> Steve
> On Sat, Jun 27, 2015 at 2:33 PM, Bruno Oliveira
> <bruno.manata.oliveira at gmail.com> wrote:
>> Hello, i tried out the ODM textured mesh code and got his,
>> http://postimg.org/image/di0jme5tv/
>> is this normal? Or am I doing something wrong?
>> I notice lots of texture transition problems, and poor alignment (although
>> the poor alignment is due to the terrain itself which is quite repetitive).
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
