[OpenDroneMap-users] Error with gcp_list georeferencing
Stephen Mather stephen at smathermather.com
Fri Nov 13 18:31:01 PST 2015
Hi Simon,
This can happen if the coordinates are too near the edges, but it looks
like you have a lot of images. Can you / have you tried with the latest
branch?: https://github.com/OpenDroneMap/OpenDroneMap/commits/python-port
I know with the default (soon to be replaced) branch there have been issues
with larger datasets not getting completely processed, which would result
in a model that does not contain enough of your ground control. This has
been fixed in the python-port branch.
Thanks,
Best,
Steve
On Sun, Nov 8, 2015 at 7:01 AM, Simon <s_mailinglist at geraschs.de> wrote:
> Hello guys,
> I'm trying out the georeferencing model and encountered an error:
> "Less than 3 GCPs have correspondences in the generated model."
> To my understanding I loaded the coordinates correctly and checked it
> twice.
> What can I do?
> odm_georeferencing_log at pastebin:
> http://pastebin.com/dBmJU3A1
> I tried to load a GCP file with significantly less GCP positions but the
> outcome was the same error message.
> Processing the same dataset with GPS Tags embedded in the EXIF Tags
> works fine...
> Regards from Salzburg,
> Simon
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20151113/7e429f9b/attachment.html>
More information about the OpenDroneMap-users mailing list
