[OpenDroneMap-users] Error with gcp_list georeferencing
Simon s_mailinglist at geraschs.de
Wed Nov 18 01:29:33 PST 2015
Hello Steve,
I used the latest python branch for the test (pulled and tested again on
17. Nov).
The Orthophoto and PointCloud are not clipped at all.
When processing with GPS Tags embedded into the EXIF Info the result is
very promising but with an error of approx 5m for every GCP.
A shot in the dark:
Does ODM mixing up the WGS84 coordinates in the EXIF Tags with my UTM
GCP file?
Actual workflow:
Run the whole project with: --odm_georeferencing-useGcp false
Attach GCP file and start again with:
--odm_georeferencing-useGcp true --start-with odm_georeferencing
Regards, Simon
On 11/14/2015 03:31 AM, Stephen Mather wrote:
> Hi Simon,
> This can happen if the coordinates are too near the edges, but it
> looks like you have a lot of images. Can you / have you tried with the
> latest
> branch?: https://github.com/OpenDroneMap/OpenDroneMap/commits/python-port
> I know with the default (soon to be replaced) branch there have been
> issues with larger datasets not getting completely processed, which
> would result in a model that does not contain enough of your ground
> control. This has been fixed in the python-port branch.
> Thanks,
> Best,
> Steve
> On Sun, Nov 8, 2015 at 7:01 AM, Simon <s_mailinglist at geraschs.de
> <mailto:s_mailinglist at geraschs.de>> wrote:
>     Hello guys,
>     I'm trying out the georeferencing model and encountered an error:
>     "Less than 3 GCPs have correspondences in the generated model."
>     To my understanding I loaded the coordinates correctly and checked
>     it twice.
>     What can I do?
>     odm_georeferencing_log at pastebin:
>     http://pastebin.com/dBmJU3A1
>     I tried to load a GCP file with significantly less GCP positions
>     but the
>     outcome was the same error message.
>     Processing the same dataset with GPS Tags embedded in the EXIF Tags
>     works fine...
>     Regards from Salzburg,
>     Simon
>     _______________________________________________
>     OpenDroneMap-users mailing list
>     OpenDroneMap-users at lists.osgeo.org
>     <mailto:OpenDroneMap-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
