[OpenLayers-Commits] r10885 - in sandbox/elemoine/kinetic: examples
	lib lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Handler
    commits-20090109 at openlayers.org
    Wed Nov 10 15:55:05 EST 2010
Author: erilem
Date: 2010-11-10 12:55:05 -0800 (Wed, 10 Nov 2010)
New Revision: 10885
Added:
   sandbox/elemoine/kinetic/examples/kinetic.html
   sandbox/elemoine/kinetic/lib/OpenLayers/Kinetic.js
   sandbox/elemoine/kinetic/lib/OpenLayers.js
   sandbox/elemoine/kinetic/lib/OpenLayers/Control/DragPan.js
   sandbox/elemoine/kinetic/lib/OpenLayers/Handler/Drag.js
first Kinetic Dragging bits
Added: sandbox/elemoine/kinetic/examples/kinetic.html
--- sandbox/elemoine/kinetic/examples/kinetic.html	                        (rev 0)
+++ sandbox/elemoine/kinetic/examples/kinetic.html	2010-11-10 20:55:05 UTC (rev 10885)
@@ -0,0 +1,68 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+  <head>
+    <title>OpenLayers Kinetic Scrolling Example</title>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
+    <link rel="stylesheet" href="style.css" type="text/css" />
+    <style type="text/css">
+        #map {
+            width: 100%;
+            height: 100%;
+    </style>
+    <script src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        var map, layer;
+        function init(){
+            map = new OpenLayers.Map({
+                div: "map",
+                resolutions: [0.087890625, 0.0439453125, 0.02197265625, 0.010986328125],
+                panDuration: 100,
+                controls: [
+                    new OpenLayers.Control.Navigation(
+                        {dragPanOptions: {kineticDragging: true}}
+            layer = new OpenLayers.Layer.TileCache("TileCache Layer",
+                ["http://c0.tilecache.osgeo.org/wms-c/cache/",
+                 "http://c1.tilecache.osgeo.org/wms-c/cache/",
+                 "http://c2.tilecache.osgeo.org/wms-c/cache/",
+                 "http://c3.tilecache.osgeo.org/wms-c/cache/",
+                 "http://c4.tilecache.osgeo.org/wms-c/cache/"],
+                "basic",
+                    serverResolutions: [0.703125, 0.3515625, 0.17578125, 0.087890625,
+                                        0.0439453125, 0.02197265625, 0.010986328125,
+                                        0.0054931640625, 0.00274658203125, 0.001373291015625,
+                                        0.0006866455078125, 0.00034332275390625, 0.000171661376953125,
+                                        0.0000858306884765625, 0.00004291534423828125, 0.000021457672119140625],
+                    buffer: 4
+            map.addLayer(layer);
+            map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+    </script>
+  </head>
+  <body onload="init()">
+      <h1 id="title">TileCache Example</h1>
+      <div id="tags">
+          tile, cache, tilecache, wmsc, wms-c
+      </div>
+      <p id="shortdesc">
+        Demonstrates a TileCache layer that loads tiles from from a web
+        accessible disk-based cache only.
+      </p>
+    <div id="map" class="smallmap"></div>
+    <div id="docs">
+        This layer should be used for web accessible disk-based caches only.
+        It is not used to request new tiles from TileCache.  Note that you
+        should specify resolutions explicitly on this layer so that they match
+        your TileCache configuration.
+    </div>
+  </body>
+</html>
Modified: sandbox/elemoine/kinetic/lib/OpenLayers/Control/DragPan.js
--- sandbox/elemoine/kinetic/lib/OpenLayers/Control/DragPan.js	2010-11-10 19:11:40 UTC (rev 10884)
+++ sandbox/elemoine/kinetic/lib/OpenLayers/Control/DragPan.js	2010-11-10 20:55:05 UTC (rev 10885)
@@ -43,8 +43,15 @@
      *     mouse cursor leaves the map viewport. Default is false.
     documentDrag: false,
+     * APIProperty: kineticDragging
+     * {Boolean} Set to true to enable "kinetic scrolling" (a.k.a "inertia
+     *     scrolling" when dragging. Default is false.
+    kineticDragging: false,
      * Method: draw
      * Creates a Drag handler, using <panMap> and
      * <panMapDone> as callbacks.
@@ -55,7 +62,8 @@
                 "done": this.panMapDone
                 interval: this.interval,
-                documentDrag: this.documentDrag
+                documentDrag: this.documentDrag,
+                kineticDragging: this.kineticDragging
@@ -66,12 +74,12 @@
     * Parameters:
     * xy - {<OpenLayers.Pixel>} Pixel of the mouse position
-    panMap: function(xy) {
+    panMap: function(xy, animate) {
         this.panned = true;
         this.map.pan(
             this.handler.last.x - xy.x,
             this.handler.last.y - xy.y,
-            {dragging: this.handler.dragging, animate: false}
+            {dragging: this.handler.dragging, animate: !!animate}
@@ -83,9 +91,15 @@
      * Parameters:
-    panMapDone: function(xy) {
+    panMapDone: function(xy, delta) {
         if(this.panned) {
             this.panMap(xy);
+            // we receive a delta if kineticDragging is set
+            if(delta) {
+                this.handler.last.x = xy.x;
+                this.handler.last.y = xy.y;
+                this.panMap(xy.add(delta.x, delta.y), true);
             this.panned = false;
Modified: sandbox/elemoine/kinetic/lib/OpenLayers/Handler/Drag.js
--- sandbox/elemoine/kinetic/lib/OpenLayers/Handler/Drag.js	2010-11-10 19:11:40 UTC (rev 10884)
+++ sandbox/elemoine/kinetic/lib/OpenLayers/Handler/Drag.js	2010-11-10 20:55:05 UTC (rev 10885)
@@ -100,6 +100,13 @@
     documentEvents: null,
      * Constructor: OpenLayers.Handler.Drag
      * Returns OpenLayers.Handler.Drag
@@ -120,6 +127,16 @@
+    setMap: function(map) {
+        OpenLayers.Handler.prototype.setMap.apply(this, arguments);
+        if(this.kineticDragging) {
+            this.kinetic = new OpenLayers.Kinetic({map: map});
      * The four methods below (down, move, up, and out) are used by subclasses
      *     to do their own processing related to these mouse events.
@@ -192,6 +209,9 @@
             this.started = true;
             this.start = evt.xy;
             this.last = evt.xy;
+                this.kinetic.begin();
             OpenLayers.Element.addClass(
                 this.map.viewPortDiv, "olDragDown"
@@ -224,19 +244,24 @@
      * {Boolean} Let the event propagate.
     mousemove: function (evt) {
-        if (this.started && !this.timeoutId && (evt.xy.x != this.last.x || evt.xy.y != this.last.y)) {
+        if(this.started && !this.timeoutId && (evt.xy.x != this.last.x || evt.xy.y != this.last.y)) {
+                this.kinetic.update(evt.xy);
             if(this.documentDrag === true && this.documentEvents) {
                 if(evt.element === document) {
                     this.adjustXY(evt);
-                    // do setEvent manually because the documentEvents are not
-                    // registered with the map
+                    // do setEvent manually because the documentEvents are
+                    // not registered with the map
                     this.setEvent(evt);
                 } else {
                     this.destroyDocumentEvents();
             if (this.interval > 0) {
-                this.timeoutId = setTimeout(OpenLayers.Function.bind(this.removeTimeout, this), this.interval);
+                this.timeoutId = setTimeout(
+                    OpenLayers.Function.bind(this.removeTimeout, this),
+                    this.interval);
             this.dragging = true;
             this.move(evt);
@@ -283,7 +308,11 @@
             this.up(evt);
             this.callback("up", [evt.xy]);
             if(dragged) {
-                this.callback("done", [evt.xy]);
+                var delta;
+                    delta = this.kinetic.end(evt.xy);
+                this.callback("done", [evt.xy, delta]);
             document.onselectstart = this.oldOnselectstart;
Added: sandbox/elemoine/kinetic/lib/OpenLayers/Kinetic.js
--- sandbox/elemoine/kinetic/lib/OpenLayers/Kinetic.js	                        (rev 0)
+++ sandbox/elemoine/kinetic/lib/OpenLayers/Kinetic.js	2010-11-10 20:55:05 UTC (rev 10885)
@@ -0,0 +1,92 @@
+OpenLayers.Kinetic = OpenLayers.Class({
+    map: null,
+     * In most cases changing the threshold isn't needed.
+     * px/ms
+    threshold: 0,
+    points: undefined,
+    initialize: function(options) {
+        OpenLayers.Util.extend(this, options);
+    begin: function() {
+        this.points = [];
+    update: function(xy) {
+        this.points.unshift({xy: xy, tick: new Date().getTime()});
+        if(this.points.length > 100) {
+            this.points.pop();
+    end: function(xy) {
+        var map = this.map;
+        // FIXME map.panTween isn't set yet
+        //if(!map || !map.panTween ||
+           //map.panTween.easing != OpenLayers.Easing.Linear.easeOut) {
+            //return;
+        var last, now = new Date().getTime();
+        for(var i=0, points=this.points, l=points.length, point; i<l; i++) {
+            point = points[i];
+            if(now - point.tick > 200) { // FIXME 200
+                break;
+            last = point;
+        if(!last) {
+            return;
+        var time = new Date().getTime() - last.tick;
+        var dist = Math.sqrt(Math.pow(xy.x - last.xy.x, 2) +
+                             Math.pow(xy.y - last.xy.y, 2));
+        var speed = dist / time;
+        if(speed == 0 || speed < this.threshold) {
+            return;
+        var theta = Math.asin((xy.y - last.xy.y) / dist);
+        if(last.xy.x <= xy.x) {
+            theta = Math.PI - theta;
+        return this.getDelta(speed, xy, theta);
+    getDelta: function(speed, curr, theta) {
+        var dist = speed * 10; /*this.map.panTween.INTERVAL */
+        var vect = {x: Math.cos(theta) * -dist,
+                    y: Math.sin(theta) * dist};
+        // the following calculation corresponds to Linear.easeOut
+        //return {x: vect.x * this.map.panDuration,
+                //y: vect.y * this.map.panDuration};
+        return {x: vect.x / (-Math.pow(2, -10 * 1/this.map.panDuration) + 1),
+                y: vect.y / (-Math.pow(2, -10 * 1/this.map.panDuration) + 1)};
+    CLASS_NAME: "OpenLayers.Kinetic"
Modified: sandbox/elemoine/kinetic/lib/OpenLayers.js
--- sandbox/elemoine/kinetic/lib/OpenLayers.js	2010-11-10 19:11:40 UTC (rev 10884)
+++ sandbox/elemoine/kinetic/lib/OpenLayers.js	2010-11-10 20:55:05 UTC (rev 10885)
@@ -82,6 +82,7 @@
             "OpenLayers/BaseTypes/Size.js",
             "OpenLayers/Console.js",
             "OpenLayers/Tween.js",
+            "OpenLayers/Kinetic.js",
             "Rico/Corner.js",
             "Rico/Color.js",
             "OpenLayers/Ajax.js",
More information about the Commits
