[OpenLayers-Commits] r11883 - in trunk/openlayers: lib/OpenLayers/Protocol tests/Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 7 02:49:40 EDT 2011
Author: erilem
Date: 2011-04-06 23:49:38 -0700 (Wed, 06 Apr 2011)
New Revision: 11883
   trunk/openlayers/lib/OpenLayers/Protocol/HTTP.js
   trunk/openlayers/tests/Protocol/HTTP.html
Protocol.HTTP.read should not write params into the protocol's options object, p=etdube,me r=me (closes #3237)
Modified: trunk/openlayers/lib/OpenLayers/Protocol/HTTP.js
--- trunk/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-04-06 22:06:31 UTC (rev 11882)
+++ trunk/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-04-07 06:49:38 UTC (rev 11883)
@@ -175,9 +175,10 @@
     read: function(options) {
         OpenLayers.Protocol.prototype.read.apply(this, arguments);
-        options = OpenLayers.Util.applyDefaults(options, this.options);
+        options = options || {};
         options.params = OpenLayers.Util.applyDefaults(
             options.params, this.options.params);
+        options = OpenLayers.Util.applyDefaults(options, this.options);
         if (options.filter && this.filterToParams) {
             options.params = this.filterToParams(
                 options.filter, options.params
Modified: trunk/openlayers/tests/Protocol/HTTP.html
--- trunk/openlayers/tests/Protocol/HTTP.html	2011-04-06 22:06:31 UTC (rev 11882)
+++ trunk/openlayers/tests/Protocol/HTTP.html	2011-04-07 06:49:38 UTC (rev 11883)
@@ -779,7 +779,7 @@
         protocol.read();
-        t.delay_call(1, function() {
+        t.delay_call(2, function() {
             t.eq(log1.callbackCalled, true, "[read] callback called");
             t.eq(log1.callbackScope, scope, "[read] correct scope");
             t.ok(log1.request instanceof OpenLayers.Request.XMLHttpRequest, "[read] correct priv type");
@@ -801,11 +801,37 @@
             {state: OpenLayers.State.DELETE, url: "./3"},
             {state: OpenLayers.State.DELETE, url: "./4"}
             t.eq(log2.called, 1, "[commit] Callback called once.");
             t.eq(log2.scope, scope, "[commit] Correct scope.");
+    function test_read_global_options(t) {
+        // test that calling read doesn't write params into the protocol's
+        // options object, see ticket #3237
+        t.plan(2);
+        var protocol = new OpenLayers.Protocol.HTTP({
+            url: '.',
+            callback: function() {},
+            params: {'a': 'a'}
+        // check initial state first
+        t.eq(protocol.options.params, {'a': 'a'},
+             'protocol params are ok at initial state');
+        var filter = new OpenLayers.Filter.Comparison({
+            type: OpenLayers.Filter.Comparison.EQUAL_TO,
+            property: 'b',
+            value: 'b'
+        protocol.read({filter: filter});
+             "protocol params are ok after read");
More information about the Commits mailing list
