[OpenLayers-Commits] r11884 - trunk/openlayers/tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 7 14:29:19 EDT 2011
Author: tschaub
Date: 2011-04-07 11:29:18 -0700 (Thu, 07 Apr 2011)
New Revision: 11884
   trunk/openlayers/tests/Style.html
Reworking test so failures are deterministic.
Modified: trunk/openlayers/tests/Style.html
--- trunk/openlayers/tests/Style.html	2011-04-07 06:49:38 UTC (rev 11883)
+++ trunk/openlayers/tests/Style.html	2011-04-07 18:29:18 UTC (rev 11884)
@@ -127,8 +127,16 @@
     function test_Style_createSymbolizer(t) {
-        t.plan(2);
+        t.plan(4);
         var style = new OpenLayers.Style();
+        // override applySymbolizer to log arguments
+        var log = [];
+        style.applySymbolizer = function(r) {
+            log.push(r);
+            OpenLayers.Style.prototype.applySymbolizer.apply(this, arguments);
         var rule = new OpenLayers.Rule({
@@ -138,17 +146,19 @@
         style.addRules([rule, elseRule]);
-        // test that applySymbolizer is only called with rule
-        style.applySymbolizer = function(r) {
-            t.eq(r.id, rule.id, "(plain) applySymbolizer called with correct rule");
+        // a) test that applySymbolizer is only called with rule
+        log = [];
         style.createSymbolizer(new OpenLayers.Feature.Vector());
+        t.eq(log.length, 1, "a) applySymbolizer called once");
+        t.eq(log[0] && log[0].id, rule.id, "a) applySymbolizer called with correct rule");
+        // b) test that applySymbolizer is only called with elseRule
+        log = [];
         rule.evaluate = function() {return false;};
-            t.eq(r.id, elseRule.id, "(else) applySymbolizer called with correct rule");
+        t.eq(log.length, 1, "b) applySymbolizer called once");
+        t.eq(log[0] && log[0].id, elseRule.id, "b) applySymbolizer called with correct rule");
     function test_Style_applySymbolizer(t) {
More information about the Commits mailing list
