[OpenLayers-Commits] r11885 - trunk/openlayers/tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Apr 7 14:37:23 EDT 2011
Author: tschaub
Date: 2011-04-07 11:37:22 -0700 (Thu, 07 Apr 2011)
New Revision: 11885
   trunk/openlayers/tests/Style.html
Less mocking in the createSymbolizer tests.
Modified: trunk/openlayers/tests/Style.html
--- trunk/openlayers/tests/Style.html	2011-04-07 18:29:18 UTC (rev 11884)
+++ trunk/openlayers/tests/Style.html	2011-04-07 18:37:22 UTC (rev 11885)
@@ -137,25 +137,34 @@
             OpenLayers.Style.prototype.applySymbolizer.apply(this, arguments);
+        // rules for the style
         var rule = new OpenLayers.Rule({
-            id: Math.random()
+            filter: new OpenLayers.Filter.Comparison({
+                type: OpenLayers.Filter.Comparison.EQUAL_TO,
+                property: "foo",
+                value: "bar"
+        rule.id = "foo=bar rule";
         var elseRule = new OpenLayers.Rule({
-            id: Math.random(),
             elseFilter: true
+        elseRule.id = "else rule";
         style.addRules([rule, elseRule]);
         // a) test that applySymbolizer is only called with rule
         log = [];
-        style.createSymbolizer(new OpenLayers.Feature.Vector());
+        style.createSymbolizer(
+            new OpenLayers.Feature.Vector(null, {foo: "bar"})
         t.eq(log.length, 1, "a) applySymbolizer called once");
         t.eq(log[0] && log[0].id, rule.id, "a) applySymbolizer called with correct rule");
         // b) test that applySymbolizer is only called with elseRule
         log = [];
-        rule.evaluate = function() {return false;};
+            new OpenLayers.Feature.Vector(null, {foo: "baz"})
         t.eq(log.length, 1, "b) applySymbolizer called once");
         t.eq(log[0] && log[0].id, elseRule.id, "b) applySymbolizer called with correct rule");
More information about the Commits mailing list
