[OpenLayers-Commits] r11368 - in
	sandbox/crschmidt/pan-tap/lib/OpenLayers: Control Handler
    commits-20090109 at openlayers.org
    Wed Feb 23 13:27:47 EST 2011
Author: crschmidt
Date: 2011-02-23 10:27:46 -0800 (Wed, 23 Feb 2011)
New Revision: 11368
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/TouchNavigation.js
   sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
Support tap-to-pan in Navigation controls. Still includes
alerts to inform whether tap is being set to true or false
on the click handler.
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js	2011-02-23 18:17:13 UTC (rev 11367)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/Navigation.js	2011-02-23 18:27:46 UTC (rev 11368)
@@ -162,7 +162,8 @@
             this.map.viewPortDiv.oncontextmenu = OpenLayers.Function.False;
-        var clickCallbacks = {
+        var clickCallbacks = {
+            'click': this.handleClick,
             'dblclick': this.defaultDblClick,
             'dblrightclick': this.defaultDblRightClick
@@ -189,6 +190,11 @@
                                     this.mouseWheelOptions );
+    handleClick: function(evt) {
+        if (this.handlers.click.tap) {
+            map.panTo(map.getLonLatFromPixel(evt.xy));
      * Method: defaultDblClick
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/TouchNavigation.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/TouchNavigation.js	2011-02-23 18:17:13 UTC (rev 11367)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Control/TouchNavigation.js	2011-02-23 18:27:46 UTC (rev 11368)
@@ -130,6 +130,8 @@
     defaultClick: function (evt) {
         if(evt.lastTouches && evt.lastTouches.length == 2) {
             this.map.zoomOut();
+        } else if (this.handlers.click.tap) {
+            this.map.panTo(map.getLonLatFromViewPortPx(evt.xy));
Modified: sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js
--- sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-23 18:17:13 UTC (rev 11367)
+++ sandbox/crschmidt/pan-tap/lib/OpenLayers/Handler/Click.js	2011-02-23 18:27:46 UTC (rev 11368)
@@ -102,7 +102,22 @@
     touch: false,
+     * Property: tap
+     * Are we on a device which supports 'taps', but is not touch?
+    tap: undefined,
+     * Property: tapTolerance
+     * How long from mousemove->mousedown->mouseup in order to decide
+     *     that it must be a tap? Setting this to anything larger than
+     *     50ms may result in setting tap true on the handler even
+     *     on non-mobile browsers with fast move+down+up event chains.
+    tapTolerance: 50,
      * Property: rightclickTimerId
      * {Number} The id of the right mouse timeout waiting to clear the
      *     <delayedEvent>.
@@ -128,25 +143,38 @@
     initialize: function(control, callbacks, options) {
         OpenLayers.Handler.prototype.initialize.apply(this, arguments);
         // optionally register for mouseup and mousedown
-        if(this.pixelTolerance != null) {
-            this.mousedown = function(evt) {
-                this.down = evt;
-                return true;
+    mouseover: function(evt) {
+        this.firstMouseOver = evt.xy;
+        this.unregister("mouseover", this.mouseover);
      * Method: mousedown
-     * Handle mousedown.  Only registered as a listener if pixelTolerance is
-     *     a non-zero value at construction.
+     * Handle mousedown.
      * Returns:
      * {Boolean} Continue propagating this event.
-    mousedown: null,
+    mousedown: function(evt) {
+        if (this.pixelTolerance != null) {
+            this.down = evt;
+        this.lastDown = new Date().getTime();
+        return true;
+     * Method: mousemove
+     * Handle mousemove. This is simply used to record
+    mousemove: function(evt) {
+        this.lastMove = new Date().getTime();
      * Method: touchstart
      * Handle touchstart.
@@ -168,6 +196,7 @@
     mouseup: function (evt) {
+        this.lastUp = new Date().getTime();
         var propagate = true;
         // Collect right mouse clicks from the mouseup
@@ -286,11 +315,35 @@
     click: function(evt) {
+        if (this.tap === undefined) {
+            if (this.touch === true) {
+                this.tap = false;
+            // Opera on Symbian, FF on Maemo: first mouseover and click happen at the
+            // same location.
+            } else if (this.firstMouseOver && this.firstMouseOver.equals(evt.xy)) {
+                this.tap = true;
+                alert('tap true');
+            // IE on WP7 (and possibly others) -- move->down->up all happen at almost
+            // exactly the same time (within tapTolerance) means this was a tap. Setting
+            // the tapTolerance too high can cause this to also be triggered on
+            // desktop browsers.
+            } else if (this.lastMove < this.lastDown && this.lastDown < this.lastUp && ((this.lastUp - this.lastMove) < this.tapTolerance)) {
+                this.tap = true;
+            } else {
+                this.tap = false;
+                alert('tap false');
         // Sencha Touch emulates click events, see ticket 3079 for more info
         if (this.touch === true && evt.type === "click") {
             return !this.stopSingle;
-        if(this.passesTolerance(evt)) {
+        if (this.passesTolerance(evt)) {
             if(this.timerId != null) {
                 // already received a click
                 if(evt.lastTouches) {
More information about the Commits
