[OpenLayers-Commits] r11369 - in sandbox/sbrunner: . addins addins/deviceorientation addins/deviceorientation/trunk addins/deviceorientation/trunk/examples addins/deviceorientation/trunk/lib addins/deviceorientation/trunk/lib/OpenLayers addins/deviceorientation/trunk/lib/OpenLayers/Control addins/deviceorientation/trunk/theme addins/deviceorientation/trunk/theme/default
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 13:30:33 EST 2011
Author: fredj
Date: 2011-02-23 10:30:33 -0800 (Wed, 23 Feb 2011)
New Revision: 11369
Added:
   sandbox/sbrunner/addins/
   sandbox/sbrunner/addins/deviceorientation/
   sandbox/sbrunner/addins/deviceorientation/trunk/
   sandbox/sbrunner/addins/deviceorientation/trunk/examples/
   sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.html
   sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.js
   sandbox/sbrunner/addins/deviceorientation/trunk/lib/
   sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/
   sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/Control/
   sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/Control/DeviceOrientation.js
   sandbox/sbrunner/addins/deviceorientation/trunk/theme/
   sandbox/sbrunner/addins/deviceorientation/trunk/theme/default/
   sandbox/sbrunner/addins/deviceorientation/trunk/theme/default/style.css
Added: sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.html
--- sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.html	                        (rev 0)
+++ sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.html	2011-02-23 18:30:33 UTC (rev 11369)
@@ -0,0 +1,19 @@
+<!DOCTYPE html>
+<html>
+<head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;"/>
+    <meta name="apple-mobile-web-app-capable" content="yes"/>
+    <title>OpenLayers Device Orientation</title>
+    <link rel="stylesheet" href="http://www.openlayers.org/dev/theme/default/style.css" type="text/css"/>
+    <link rel="stylesheet" href="http://www.openlayers.org/dev/examples/style.css" type="text/css"/>
+    <script type="text/javascript" src="../../../../openlayers/lib/OpenLayers.js"></script>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"/>
+    <script type="text/javascript" src="../lib/OpenLayers/Control/DeviceOrientation.js"></script>
+    <script type="text/javascript" src="orientation.js"></script>
+</head>
+<body onload="init()">
+    <h1>Device Orientation</h1>
+    <div id="map" class="smallmap"></div>
+</body>
+</html>
Added: sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.js
--- sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.js	                        (rev 0)
+++ sandbox/sbrunner/addins/deviceorientation/trunk/examples/orientation.js	2011-02-23 18:30:33 UTC (rev 11369)
@@ -0,0 +1,27 @@
+var map, orientation;
+function init() {
+    map = new OpenLayers.Map('map', {
+        layers: [new OpenLayers.Layer.OSM()]
+    orientation = new OpenLayers.Control.DeviceOrientation();
+    map.addControl(orientation);
+    map.zoomToMaxExtent();
+//     function init() {
+//         var logs = document.getElementById("logs");
+//         orientation = new OpenLayers.Control.DeviceOrientation();
+//         if (orientation.supported()) {
+//             orientation.events.register("orientationchange", this, function(event) {
+//                 logs.innerHTML = "rotation: " + event.orientation;
+//                 var img = document.getElementById("orientation");
+//                 var value = "rotate(" + event.orientation + "deg)";
+//                 img.style.transform = value;
+//                 img.style.webkitTransform = value;
+//             orientation.activate();
+//         } else {
+//             logs.innerHTML = "This device don't supports device orientation";
Added: sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/Control/DeviceOrientation.js
--- sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/Control/DeviceOrientation.js	                        (rev 0)
+++ sandbox/sbrunner/addins/deviceorientation/trunk/lib/OpenLayers/Control/DeviceOrientation.js	2011-02-23 18:30:33 UTC (rev 11369)
@@ -0,0 +1,58 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Control.js
+ * Class: OpenLayers.Control.DeviceOrientation
+ * see: http://dev.w3.org/geo/api/spec-source-orientation.html
+OpenLayers.Control.DeviceOrientation = OpenLayers.Class(OpenLayers.Control, {
+     * APIMethod: supported
+     * Returns:
+     * {Boolean} Whether or not the browser supports device orientation
+    supported: function() {
+        return !!(window.DeviceOrientationEvent);
+     * Method: draw
+     * Returns:
+     * {DOMElement}
+    draw: function() {
+        OpenLayers.Control.prototype.draw.apply(this, arguments);
+        if (this.supported()) {
+            window.addEventListener("deviceorientation",
+                OpenLayers.Function.bind(this.updateOrientation, this), true);
+        } else {
+            OpenLayers.Element.addClass(this.div, "unsupported");
+        return this.div;
+    updateOrientation: function(event) {
+        var v = "rotate(" + event.alpha - window.orientation - 90 + "deg)";
+        this.div.style.transform = v;
+        this.div.style.webkitTransform = v;
+    destroy: function() {
+        window.removeEventListener("deviceorientation",
+        OpenLayers.Control.prototype.destroy.apply(this, arguments);
+    CLASS_NAME: "OpenLayers.Control.DeviceOrientation"
Added: sandbox/sbrunner/addins/deviceorientation/trunk/theme/default/style.css
--- sandbox/sbrunner/addins/deviceorientation/trunk/theme/default/style.css	                        (rev 0)
+++ sandbox/sbrunner/addins/deviceorientation/trunk/theme/default/style.css	2011-02-23 18:30:33 UTC (rev 11369)
@@ -0,0 +1,7 @@
+.olControlDeviceOrientation {
+    right: 5px;
+    top: 5px;
+    width: 30px;
+    height: 30px;
+    border: 1px solid red;
More information about the Commits mailing list
