[OpenLayers-Commits] r12187 - in trunk/openlayers: lib/OpenLayers/Layer tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jul 25 09:13:48 EDT 2011
Author: bartvde
Date: 2011-07-25 06:13:46 -0700 (Mon, 25 Jul 2011)
New Revision: 12187
   trunk/openlayers/lib/OpenLayers/Layer/Vector.js
   trunk/openlayers/tests/Layer/Vector.html
getDataExtent should return null when there are no features with a geometry, r=ahocevar (closes #3435)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Vector.js
--- trunk/openlayers/lib/OpenLayers/Layer/Vector.js	2011-07-25 12:22:54 UTC (rev 12186)
+++ trunk/openlayers/lib/OpenLayers/Layer/Vector.js	2011-07-25 13:13:46 UTC (rev 12187)
@@ -597,7 +597,7 @@
                 if(this.events.triggerEvent("beforefeatureadded",
                                             {feature: feature}) === false) {
                     continue;
                 this.preFeatureInsert(feature);
@@ -816,7 +816,7 @@
             this.unrenderedFeatures[feature.id] = feature;
         } else {
             delete this.unrenderedFeatures[feature.id];
@@ -988,17 +988,20 @@
      * Calculates the max extent which includes all of the features.
      * Returns:
-     * {<OpenLayers.Bounds>}
+     * {<OpenLayers.Bounds>} or null if the layer has no features with
+     * geometries.
     getDataExtent: function () {
         var maxExtent = null;
         var features = this.features;
         if(features && (features.length > 0)) {
-            maxExtent = new OpenLayers.Bounds();
             var geometry = null;
             for(var i=0, len=features.length; i<len; i++) {
                 geometry = features[i].geometry;
                 if (geometry) {
+                    if (maxExtent === null) {
+                        maxExtent = new OpenLayers.Bounds();
                     maxExtent.extend(geometry.getBounds());
Modified: trunk/openlayers/tests/Layer/Vector.html
--- trunk/openlayers/tests/Layer/Vector.html	2011-07-25 12:22:54 UTC (rev 12186)
+++ trunk/openlayers/tests/Layer/Vector.html	2011-07-25 13:13:46 UTC (rev 12187)
@@ -286,6 +286,14 @@
         t.ok(extent.toBBOX() != layer.features[0].geometry.getBounds().toBBOX(), "extent from getDataExtent doesn't clobber first feature");
+    function test_Layer_Vector_getDataExtentEmpty(t) {
+        t.plan(1);
+        var layer = new OpenLayers.Layer.Vector(name);
+        layer.addFeatures([new OpenLayers.Feature.Vector(null), new OpenLayers.Feature.Vector(null)]);
+        var extent = layer.getDataExtent();
+        t.eq(extent, null, "We expect null to be returned if there are no features with a geometry");
     function test_Layer_Vector_removeFeatures(t) {
         t.plan(17);
More information about the Commits mailing list
