[OpenLayers-Commits] r12188 - in trunk/openlayers: lib/OpenLayers/Format/WFST tests/Format/WFST
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jul 25 10:01:01 EDT 2011
Author: bartvde
Date: 2011-07-25 07:01:00 -0700 (Mon, 25 Jul 2011)
New Revision: 12188
   trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
   trunk/openlayers/tests/Format/WFST/v1.html
modified checks for Format.WFST should use not equal to undefined instead of truthy to deal properly with initial null values, r=ahocevar (closes #3436)
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js	2011-07-25 13:13:46 UTC (rev 12187)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js	2011-07-25 14:01:00 UTC (rev 12188)
@@ -183,12 +183,12 @@
      * transaction:
      * - *modified* is not set at all: The geometry and all attributes will be
      *     included.
-     * - *modified.geometry* is truthy: The geometry will be
+     * - *modified.geometry* is set (null or a geometry): The geometry will be
      *     included. If *modified.attributes* is not set, all attributes will
      *     be included.
-     * - *modified.attributes* is set: Only the attributes with a truthy value
-     *     in *modified.attributes* will be included. If *modified.geometry*
-     *     is not set, the geometry will not be included.
+     * - *modified.attributes* is set: Only the attributes set (i.e. to null or
+     *     a value) in *modified.attributes* will be included.
+     *     If *modified.geometry* is not set, the geometry will not be included.
      * Valid options include:
      * - *multi* {Boolean} If set to true, geometries will be casted to
@@ -323,7 +323,7 @@
                 // add in geometry
                 var modified = feature.modified;
-                if (this.geometryName !== null && (!modified || modified.geometry)) {
+                if (this.geometryName !== null && (!modified || modified.geometry !== undefined)) {
                     this.srsName = this.getSrsName(feature);
                     this.writeNode(
                         "Property", {name: this.geometryName, value: feature.geometry}, node
@@ -334,7 +334,7 @@
                 for(var key in feature.attributes) {
                     if(feature.attributes[key] !== undefined &&
                                 (!modified || !modified.attributes ||
-                                (modified.attributes && modified.attributes[key]))) {
+                                (modified.attributes && modified.attributes[key] !== undefined))) {
                         this.writeNode(
                             "Property", {name: key, value: feature.attributes[key]}, node
Modified: trunk/openlayers/tests/Format/WFST/v1.html
--- trunk/openlayers/tests/Format/WFST/v1.html	2011-07-25 13:13:46 UTC (rev 12187)
+++ trunk/openlayers/tests/Format/WFST/v1.html	2011-07-25 14:01:00 UTC (rev 12188)
@@ -45,7 +45,7 @@
         deleteFeature.state = OpenLayers.State.DELETE;
         deleteFeature.fid = "fid.37";
-        t.plan(7);
+        t.plan(8);
         var snippets = {
             "GetFeature": {handle: "handle_g", maxFeatures: 1, outputFormat: 'json'},
             "Transaction": {handle: "handle_t"},
@@ -74,6 +74,14 @@
         var expected = readXML("UpdateModifiedNoGeometry");
         var got = format.writers["wfs"]["Update"].apply(format, [{feature: updateFeature}]);
         t.xml_eq(got, expected, "Update request for feature with no modified geometry but modified attributes created correctly");
+        // test for a feature that originally had a null geometry and a null value for the attribute
+        updateFeature.modified = {attributes: {foo: null, nul: "nul"}, geometry: null};
+        updateFeature.attributes.foo = "bar";
+        updateFeature.geometry = new OpenLayers.Geometry.Point(2,3);
+        var expected = readXML("UpdateModified");
+        var got = format.writers["wfs"]["Update"].apply(format, [{feature: updateFeature}]);
+        t.xml_eq(got, expected, "Update request for feature with modified geometry created correctly even if original geometry was null");
     function test_writeNative(t) {
More information about the Commits mailing list
