[OpenLayers-Commits] r12189 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jul 25 11:05:51 EDT 2011
Author: fredj
Date: 2011-07-25 08:05:50 -0700 (Mon, 25 Jul 2011)
New Revision: 12189
   trunk/openlayers/lib/OpenLayers/Util.js
remove unused OpenLayers.Util.getTagText, OpenLayers.Util.getNodes and OpenLayers.Util._getNodes functions. r=bartvde, p=me (closes #3437)
Modified: trunk/openlayers/lib/OpenLayers/Util.js
--- trunk/openlayers/lib/OpenLayers/Util.js	2011-07-25 14:01:00 UTC (rev 12188)
+++ trunk/openlayers/lib/OpenLayers/Util.js	2011-07-25 15:05:50 UTC (rev 12189)
@@ -694,85 +694,7 @@
     return returnValue;
- * Function: getNodes
- * These could/should be made namespace aware?
- * Parameters:
- * p - {}
- * tagName - {String}
- * Returns:
- * {Array}
-OpenLayers.Util.getNodes=function(p, tagName) {
-    var nodes = OpenLayers.Util.Try(
-        function () {
-            return OpenLayers.Util._getNodes(p.documentElement.childNodes,
-                                            tagName);
-        function () {
-            return OpenLayers.Util._getNodes(p.childNodes, tagName);
-    return nodes;
- * Function: _getNodes
- * Parameters:
- * nodes - {Array}
- * Returns:
- * {Array}
-OpenLayers.Util._getNodes=function(nodes, tagName) {
-    var retArray = [];
-    for (var i=0, len=nodes.length; i<len; i++) {
-        if (nodes[i].nodeName==tagName) {
-            retArray.push(nodes[i]);
-    return retArray;
- * Function: getTagText
- * Parameters:
- * parent - {}
- * item - {String}
- * index - {Integer}
- * Returns:
- * {String}
-OpenLayers.Util.getTagText = function (parent, item, index) {
-    var result = OpenLayers.Util.getNodes(parent, item);
-    if (result && (result.length > 0))
-        if (!index) {
-            index=0;
-        if (result[index].childNodes.length > 1) {
-            return result.childNodes[1].nodeValue;
-        else if (result[index].childNodes.length == 1) {
-            return result[index].firstChild.nodeValue;
-    } else {
-        return "";
  * Function: getXmlNodeValue
  * Parameters:
More information about the Commits mailing list
