[OpenLayers-Commits] r12044 - in sandbox/tschaub/editing: examples lib/OpenLayers/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Jun 5 19:46:33 EDT 2011
Author: tschaub
Date: 2011-06-05 16:46:32 -0700 (Sun, 05 Jun 2011)
New Revision: 12044
Added:
   sandbox/tschaub/editing/examples/draw-undo-redo.html
   sandbox/tschaub/editing/examples/draw-undo-redo.js
   sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
Add undo/redo example.
Added: sandbox/tschaub/editing/examples/draw-undo-redo.html
--- sandbox/tschaub/editing/examples/draw-undo-redo.html	                        (rev 0)
+++ sandbox/tschaub/editing/examples/draw-undo-redo.html	2011-06-05 23:46:32 UTC (rev 12044)
@@ -0,0 +1,41 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>OpenLayers Undo/Redo Drawing Methods</title>
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+        <meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">
+        <meta name="apple-mobile-web-app-capable" content="yes">
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+        <script src="../lib/OpenLayers.js"></script>
+    </head>
+    <body>
+        <h1 id="title">Undo/Redo Drawing</h1>
+        <p id="shortdesc">
+            Demonstrates the use of undo &amp; redo methods while drawing.
+        </p>
+        <div id="map" class="smallmap"></div>
+        <div id="docs">
+            <p>
+                Use <code>Ctrl-Z</code> or<code> ⌘-Z</code> to undo while drawing.
+                Use <code>Ctrl-Y</code> or<code> ⌘-Y</code> to redo what you have
+                undone.  Use <code>Esc</code> to cancel the current sketch.
+            <p>
+                The <code>control.undo</code> method works first on any current
+                sketch, removing the most recently added point.  To fully erase
+                a sketch, cancel drawing.  After removing all but two points
+                from the current sketch (in the case of a line) the undo method
+                will begin removing previously drawn features.
+            </p><p>
+                The <code>control.redo</code> method adds back items that were
+                removed from an undo.
+            </p><p>
+                View the <a href="draw-undo-redo.js" target="_blank">draw-undo-redo.js</a>
+                source to see how this is done.
+            </p>
+        </div>
+        <script src="draw-undo-redo.js"></script>
+    </body>
+</html>
Added: sandbox/tschaub/editing/examples/draw-undo-redo.js
--- sandbox/tschaub/editing/examples/draw-undo-redo.js	                        (rev 0)
+++ sandbox/tschaub/editing/examples/draw-undo-redo.js	2011-06-05 23:46:32 UTC (rev 12044)
@@ -0,0 +1,52 @@
+var map = new OpenLayers.Map({
+    div: "map",
+    layers: [
+        new OpenLayers.Layer.WMS(
+            "Global Imagery",
+            "http://maps.opengeo.org/geowebcache/service/wms",
+            {layers: "bluemarble"},
+            {tileOrigin: new OpenLayers.LonLat(-180, -90)}
+        new OpenLayers.Layer.Vector()
+    center: new OpenLayers.LonLat(0, 0),
+    zoom: 1
+var draw = new OpenLayers.Control.DrawFeature(
+    map.layers[1], OpenLayers.Handler.Path
+map.addControl(draw);
+draw.activate();
+OpenLayers.Event.observe(document, "keypress", function(evt) {
+    var code = evt.charCode || evt.keyCode;
+    if (code === 90) {
+        // z
+        if ("metaKey" in evt) {
+            if (evt.metaKey) {
+                draw.undo();
+                evt.preventDefault();
+        } else if (evt.ctrlKey) {
+            draw.undo();
+    if (code === 89) {
+        // y
+                draw.redo();
+            draw.redo();
+    if (code === 27) {
+        // esc
+        draw.cancel();
\ No newline at end of file
Modified: sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
--- sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js	2011-06-05 23:27:04 UTC (rev 12043)
+++ sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js	2011-06-05 23:46:32 UTC (rev 12044)
@@ -82,6 +82,7 @@
                     this.layer.events.triggerEvent(
                         "sketchmodified", {vertex: vertex, feature: feature}
+                    delete this.redoStack;
                 create: function(vertex, feature) {
More information about the Commits mailing list
