[OpenLayers-Commits] r12045 - trunk/openlayers/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Jun 6 02:47:46 EDT 2011
Author: erilem
Date: 2011-06-05 23:47:46 -0700 (Sun, 05 Jun 2011)
New Revision: 12045
   trunk/openlayers/build/build.py
better help message for the --compressor option of build.py, no functional change
Modified: trunk/openlayers/build/build.py
--- trunk/openlayers/build/build.py	2011-06-05 23:46:32 UTC (rev 12044)
+++ trunk/openlayers/build/build.py	2011-06-06 06:47:46 UTC (rev 12045)
@@ -70,7 +70,7 @@
 if __name__ == '__main__':
   opt = optparse.OptionParser(usage="%s [options] [config_file] [output_file]\n  Default config_file is 'full.cfg', Default output_file is 'OpenLayers.js'")
-  opt.add_option("-c", "--compressor", dest="compressor", help="compression method: one of 'jsmin', 'minimize', or 'none'", default="jsmin")
+  opt.add_option("-c", "--compressor", dest="compressor", help="compression method: one of 'jsmin', 'minimize', 'closure_ws', 'closure', or 'none'", default="jsmin")
   (options, args) = opt.parse_args()
   if not len(args):
     build(options=options)
More information about the Commits mailing list
