[OpenLayers-Commits] r11600 - sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 1 10:39:32 EST 2011
Author: ahocevar
Date: 2011-03-01 07:39:30 -0800 (Tue, 01 Mar 2011)
New Revision: 11600
   sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/NG.js
   sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/SVG2.js
pulling in improvements and bug fixes from Layer.SVG on trunk
Modified: sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/NG.js
--- sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/NG.js	2011-03-01 14:11:42 UTC (rev 11599)
+++ sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/NG.js	2011-03-01 15:39:30 UTC (rev 11600)
@@ -1,4 +1,4 @@
-/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
  * full list of contributors). Published under the Clear BSD license.
  * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
  * full text of the license. */
Modified: sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/SVG2.js
--- sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/SVG2.js	2011-03-01 14:11:42 UTC (rev 11599)
+++ sandbox/ahocevar/renderer-ng/lib/OpenLayers/Renderer/SVG2.js	2011-03-01 15:39:30 UTC (rev 11600)
@@ -1,10 +1,10 @@
- * @requires OpenLayers/Renderer/Elements.js
+ * @requires OpenLayers/Renderer/NG.js
@@ -31,7 +31,7 @@
      * Property: symbolMetrics
      * {Object} Cache for symbol metrics according to their svg coordinate
      *     space. This is an object keyed by the symbol's id, and values are
-     *     an array of [width, centerX, centerY].
+     *     an object with size, x and y properties.
     symbolMetrics: null,
@@ -131,7 +131,7 @@
                 if (style.externalGraphic) {
                     nodeType = "image";
                 } else if (this.isComplexSymbol(style.graphicName)) {
-                    nodeType = "use";
+                    nodeType = "svg";
                 } else {
                     nodeType = "circle";
@@ -184,6 +184,10 @@
                 if (style.graphicTitle) {
                     node.setAttributeNS(null, "title", style.graphicTitle);
+                    //Standards-conformant SVG
+                    var label = this.nodeFactory(null, "title");
+                    label.textContent = style.graphicTitle;
+                    node.appendChild(label);
                 if (style.graphicWidth && style.graphicHeight) {
                     node.setAttributeNS(null, "preserveAspectRatio", "none");
@@ -208,6 +212,7 @@
                 node.setAttributeNS(null, "height", height);
                 node.setAttributeNS(this.xlinkns, "href", style.externalGraphic);
                 node.setAttributeNS(null, "style", "opacity: "+opacity);
+                node.onclick = OpenLayers.Renderer.SVG2.preventDefault;
                 // the symbol viewBox is three times as large as the symbol
                 var offset = style.pointRadius * 3 * resolution;
@@ -223,7 +228,17 @@
                     parent.removeChild(node);
-                node.setAttributeNS(this.xlinkns, "href", "#" + id);
+                // The more appropriate way to implement this would be use/defs,
+                // but due to various issues in several browsers, it is safer to
+                // copy the symbols instead of referencing them.
+                // See e.g. ticket http://trac.osgeo.org/openlayers/ticket/2985
+                // and this email thread
+                // http://osgeo-org.1803224.n2.nabble.com/Select-Control-Ctrl-click-on-Feature-with-a-graphicName-opens-new-browser-window-tc5846039.html
+                var src = document.getElementById(id);
+                node.firstChild && node.removeChild(node.firstChild);
+                node.appendChild(src.firstChild.cloneNode(true));
+                node.setAttributeNS(null, "viewBox", src.getAttributeNS(null, "viewBox"));
                 node.setAttributeNS(null, "width", size);
                 node.setAttributeNS(null, "height", size);
                 node.setAttributeNS(null, "x", node._x - offset);
@@ -244,16 +259,15 @@
             if (rotation !== undefined || node._rotation !== undefined) {
                 node._rotation = rotation;
                 rotation |= 0;
-                if(node.nodeName !== "svg") {
-                    node.setAttributeNS(null, "transform",
-                        "rotate(" + rotation + " " + node._x + " " + node._y + ")"
+                if (node.nodeName !== "svg") {
+                    node.setAttributeNS(null, "transform",
+                        ["rotate(", rotation, node._x, node._y, ")"].join(" ")
+                } else {
+                    var metrics = this.symbolMetrics[id];
+                    node.firstChild.setAttributeNS(null, "transform",
+                        ["rotate(", rotation, metrics.x, metrics.y, ")"].join(" ")
-                } else {
-                     var metrics = this.symbolMetrics[id];
-                     node.firstChild.setAttributeNS(null, "transform",
-                         "rotate(" + rotation + " " + metrics.x +
-                         " " +  metrics.y + ")"
@@ -318,10 +332,10 @@
                 return [8 * w, 4 * w, widthFactor, 4 * w].join();
             default:
                 var parts = OpenLayers.String.trim(str).split(/\s+/g);
-	            for (var i=0, ii=parts.length; i<ii; i++) {
-	                parts[i] = parts[i] * widthFactor;
-	            return parts.join();
+                for (var i=0, ii=parts.length; i<ii; i++) {
+                    parts[i] = parts[i] * widthFactor;
+                return parts.join();
@@ -722,5 +736,34 @@
         return symbolNode.id;
+     * Method: getFeatureIdFromEvent
+     * Parameters:
+     * evt - {Object} An <OpenLayers.Event> object
+     * Returns:
+     * {<OpenLayers.Geometry>} A geometry from an event that
+     *     happened on a layer.
+    getFeatureIdFromEvent: function(evt) {
+        var featureId = OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this, arguments);
+        if(!featureId) {
+            var target = evt.target;
+            featureId = target.parentNode && target != this.rendererRoot &&
+                target.parentNode._featureId;
+        return featureId;
     CLASS_NAME: "OpenLayers.Renderer.SVG2"
\ No newline at end of file
+ * Function: OpenLayers.Renderer.SVG2.preventDefault
+ * Used to prevent default events (especially opening images in a new tab on
+ * ctrl-click) from being executed for externalGraphic and graphicName symbols
+OpenLayers.Renderer.SVG2.preventDefault = function(e) {
+    e.preventDefault && e.preventDefault();
More information about the Commits mailing list
