[OpenLayers-Commits] r11601 - in sandbox/ahocevar/renderer-ng/tests: Layer Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 1 10:39:59 EST 2011
Author: ahocevar
Date: 2011-03-01 07:39:57 -0800 (Tue, 01 Mar 2011)
New Revision: 11601
   sandbox/ahocevar/renderer-ng/tests/Layer/Vector.html
   sandbox/ahocevar/renderer-ng/tests/Renderer/SVG2.html
updated tests
Modified: sandbox/ahocevar/renderer-ng/tests/Layer/Vector.html
--- sandbox/ahocevar/renderer-ng/tests/Layer/Vector.html	2011-03-01 15:39:30 UTC (rev 11600)
+++ sandbox/ahocevar/renderer-ng/tests/Layer/Vector.html	2011-03-01 15:39:57 UTC (rev 11601)
@@ -458,9 +458,7 @@
         t.plan(9);
         var map = new OpenLayers.Map("map");
-        var layer = new OpenLayers.Layer.Vector(null, {
-            drawn: true
+        var layer = new OpenLayers.Layer.Vector();
         map.addLayer(layer);
         var feature = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.Point(10, 10)
@@ -477,6 +475,7 @@
         // draw feature with no state
+        layer.drawn = true;
         layer.drawFeature(feature);
         t.ok(log.feature === feature, "[no state] drawFeature called with correct feature");
         t.ok(log.style.display !== "none", "[no state] drawFeature called with style display not none");
Modified: sandbox/ahocevar/renderer-ng/tests/Renderer/SVG2.html
--- sandbox/ahocevar/renderer-ng/tests/Renderer/SVG2.html	2011-03-01 15:39:30 UTC (rev 11600)
+++ sandbox/ahocevar/renderer-ng/tests/Renderer/SVG2.html	2011-03-01 15:39:57 UTC (rev 11601)
@@ -1,6 +1,6 @@
 <html>
 <head>
-<script src="../../lib/OpenLayers.js"></script>
+<script src="../OLLoader.js"></script>
   <script type="text/javascript">
     var geometry = null, node = null;
@@ -51,7 +51,7 @@
         t.plan(5);
         OpenLayers.Renderer.SVG2.prototype._setExtent =
-            OpenLayers.Renderer.Elements.prototype.setExtent;
+            OpenLayers.Renderer.SVG2.prototype.setExtent;
         var g_SetExtent = false;
         OpenLayers.Renderer.SVG2.prototype.setExtent = function() {
@@ -60,7 +60,6 @@
         var r = new OpenLayers.Renderer.SVG2(document.body);
         var extent = new OpenLayers.Bounds(1,2,3,4);
         r.map = {
             getResolution: function() {
@@ -68,23 +67,26 @@
             getExtent: function() {
                 return extent;
+            getMaxExtent: function() {
+                return extent;
         r.updateDimensions();
         t.eq(g_SetExtent, true, "Elements.setExtent() called");
-        t.eq(r.rendererRoot.getAttributeNS(null, "width"), "12", "width is correct");
-        t.eq(r.rendererRoot.getAttributeNS(null, "height"), "12", "height is correct");
-        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "-1 -6 6 6", "rendererRoot viewBox is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "width"), "4", "width is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "height"), "4", "height is correct");
+        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "1 -4 2 2", "rendererRoot viewBox is correct");
         // test extent changes
         extent = new OpenLayers.Bounds(2,3,5,6);
-        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "-1 -9 9 9", "rendererRoot viewBox is correct after a new setExtent");
+        t.eq(r.rendererRoot.getAttributeNS(null, "viewBox"), "2 -6 3 3", "rendererRoot viewBox is correct after a new setExtent");
-        OpenLayers.Renderer.Elements.prototype.setExtent =
-            OpenLayers.Renderer.Elements.prototype._setExtent;
+        OpenLayers.Renderer.SVG2.prototype.setExtent =
+            OpenLayers.Renderer.SVG2.prototype._setExtent;
     function test_SVG_drawpoint(t) {
@@ -361,13 +363,13 @@
         t.plan(1);
         var g = {CLASS_NAME: "OpenLayers.Geometry.Point"}
         var s = {graphicName: "square"};
-        t.eq(r.getNodeType(g, s), "use", "Correct node type for well known symbols");
+        t.eq(r.getNodeType(g, s), "svg", "Correct node type for well known symbols");
     function test_svg_importsymbol(t) {
@@ -413,7 +415,7 @@
         t.eq(r.dashStyle({strokeWidth: 1, strokeDashstyle: "dashdot"}, 1), "4,4,1,4", "dashdot dasharray created correctly");
         t.eq(r.dashStyle({strokeWidth: 1, strokeDashstyle: "longdashdot"}, 1), "8,4,1,4", "dashdot dasharray created correctly");
   </script>
 </head>
 <body>
More information about the Commits mailing list
