[OpenLayers-Commits] r12005 - in sandbox/bartvde/wps/openlayers: lib/OpenLayers/Format tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed May 25 07:17:05 EDT 2011
Author: bartvde
Date: 2011-05-25 04:17:04 -0700 (Wed, 25 May 2011)
New Revision: 12005
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
   sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
more WPSExecute coverage
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-25 10:55:58 UTC (rev 12004)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-25 11:17:04 UTC (rev 12005)
@@ -127,11 +127,28 @@
             "Input": function(input) {
                 var node = this.createElementNSPlus("wps:Input", {});
                 this.writeNode("ows:Identifier", input.identifier, node);
+                if (input.title) {
+                    this.writeNode("ows:Title", input.title, node);
+                if (input.data) {
+                    this.writeNode("wps:Data", input.data, node);
                 if (input.reference) {
                     this.writeNode("wps:Reference", input.reference, node);
                 return node;
+            "Data": function(data) {
+                var node = this.createElementNSPlus("wps:Data", {});
+                if (data.literalData) {
+                    this.writeNode("wps:LiteralData", data.literalData, node);
+                return node;
+            "LiteralData": function(literalData) {
+                var node = this.createElementNSPlus("wps:LiteralData", {value: literalData});
+                return node;
             "Reference": function(reference) {
                 var node = this.createElementNSPlus("wps:Reference", {
                     attributes: {
Modified: sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
--- sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-25 10:55:58 UTC (rev 12004)
+++ sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-25 11:17:04 UTC (rev 12005)
@@ -100,6 +100,64 @@
         t.xml_eq(result, expected, "WPS Execute written out correctly");
+    function test_write_raw_data_output(t) {
+        t.plan(1);
+        // example request taken from: http://geoprocessing.info/wpsdoc/1x0ExecutePOST
+        var expected = '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>' +
+'<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" ' +
+'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0' +
+'	http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+'	<ows:Identifier>Buffer</ows:Identifier>' +
+'	<wps:DataInputs>' +
+'		<wps:Input>' +
+'			<ows:Identifier>InputPolygon</ows:Identifier>' +
+'			<ows:Title>Playground area</ows:Title>' +
+'			<wps:Reference xlink:href="http://foo.bar/some_WFS_request.xml"/>' +
+'		</wps:Input>' +
+'		<wps:Input>' +
+'			<ows:Identifier>BufferDistance</ows:Identifier>' +
+'			<ows:Title>Distance which people will walk to get to a playground.</ows:Title>' +
+'			<wps:Data>' +
+'				<wps:LiteralData>400</wps:LiteralData>' +
+'			</wps:Data>' +
+'		</wps:Input>' +
+'	</wps:DataInputs>' +
+'	<wps:ResponseForm>' +
+'		<wps:RawDataOutput>' +
+'			<ows:Identifier>BufferedPolygon</ows:Identifier>' +
+'		</wps:RawDataOutput>' +
+'	</wps:ResponseForm>' +
+'</wps:Execute>';
+        var format = new OpenLayers.Format.WPSExecute();
+        var result = format.write({
+            identifier: "Buffer",
+            dataInputs: {
+                inputs: [
+                        identifier: 'InputPolygon',
+                        title: 'Playground area',
+                        reference: {
+                            href: 'http://foo.bar/some_WFS_request.xml'
+                        identifier: 'BufferDistance',
+                        title: 'Distance which people will walk to get to a playground.',
+                        data: {
+                            literalData: 400
+            responseForm: {
+                rawDataOutput: {
+                    identifier: "BufferedPolygon"
+        t.xml_eq(result, expected, "WPS Execute written out correctly");
     </script>
 </head>
 <body>
More information about the Commits mailing list
