[OpenLayers-Commits] r12006 - in sandbox/bartvde/wps/openlayers: lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed May 25 11:00:16 EDT 2011
Author: bartvde
Date: 2011-05-25 08:00:15 -0700 (Wed, 25 May 2011)
New Revision: 12006
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
   sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
more work on WPSExecute
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-05-25 11:17:04 UTC (rev 12005)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-05-25 15:00:15 UTC (rev 12006)
@@ -251,6 +251,11 @@
                     value: title });
                 return node;
+            "Abstract": function(abstractValue) {
+                var node = this.createElementNSPlus("ows:Abstract", {
+                    value: abstractValue });
+                return node;
             "OutputFormat": function(format) {
                 var node = this.createElementNSPlus("ows:OutputFormat", {
                     value: format });
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-25 11:17:04 UTC (rev 12005)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-25 15:00:15 UTC (rev 12006)
@@ -105,9 +105,36 @@
             "ResponseForm": function(responseForm) {
                 var node = this.createElementNSPlus("wps:ResponseForm", {});
-                this.writeNode("wps:RawDataOutput", responseForm.rawDataOutput, node);
+                if (responseForm.rawDataOutput) {
+                    this.writeNode("wps:RawDataOutput", responseForm.rawDataOutput, node);
+                if (responseForm.responseDocument) {
+                    this.writeNode("wps:ResponseDocument", responseForm.responseDocument, node);
                 return node;
+            "ResponseDocument": function(responseDocument) {
+                var node = this.createElementNSPlus("wps:ResponseDocument", {
+                    attributes: {
+                        storeExecuteResponse: responseDocument.storeExecuteResponse
+                if (responseDocument.output) {
+                    this.writeNode("wps:Output", responseDocument.output, node);
+                return node;
+            "Output": function(output) {
+                var node = this.createElementNSPlus("wps:Output", {
+                    attributes: {
+                        asReference: output.asReference
+                this.writeNode("ows:Identifier", output.identifier, node);
+                this.writeNode("ows:Title", output.title, node);
+                this.writeNode("ows:Abstract", output["abstract"], node);
+                return node;
             "RawDataOutput": function(rawDataOutput) {
                 var node = this.createElementNSPlus("wps:RawDataOutput", {
                     attributes: {
Modified: sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
--- sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-25 11:17:04 UTC (rev 12005)
+++ sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-25 15:00:15 UTC (rev 12006)
@@ -158,6 +158,74 @@
         t.xml_eq(result, expected, "WPS Execute written out correctly");
+    function test_write_request_responseDoc_defaultFormat(t) {
+        t.plan(1);
+        // taken from http://geoprocessing.info/schemas/wps/1.0/examples/51_wpsExecute_request_ResponseDocument.xml
+        var expected = '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>' +
+'<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" ' +
+'xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0' +
+'	http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">' +
+'	<ows:Identifier>Buffer</ows:Identifier>' +
+'	<wps:DataInputs>' +
+'		<wps:Input>' +
+'			<ows:Identifier>InputPolygon</ows:Identifier>' +
+'			<ows:Title>Playground area</ows:Title>' +
+'			<wps:Reference xlink:href="http://foo.bar/some_WFS_request.xml"/>' +
+'		</wps:Input>' +
+'		<wps:Input>' +
+'			<ows:Identifier>BufferDistance</ows:Identifier>' +
+'			<ows:Title>Distance which people will walk to get to a playground.</ows:Title>' +
+'			<wps:Data>' +
+'				<wps:LiteralData>400</wps:LiteralData>' +
+'			</wps:Data>' +
+'		</wps:Input>' +
+'	</wps:DataInputs>' +
+'	<wps:ResponseForm>' +
+'		<wps:ResponseDocument storeExecuteResponse="true">' +
+'			<wps:Output asReference="true">' +
+'				<ows:Identifier>BufferedPolygon</ows:Identifier>' +
+'				<ows:Title>Area serviced by playground.</ows:Title>' +
+'				<ows:Abstract>Area within which most users of this playground will live.</ows:Abstract>' +
+'			</wps:Output>' +
+'		</wps:ResponseDocument>' +
+'	</wps:ResponseForm>' +
+'</wps:Execute>';
+        var format = new OpenLayers.Format.WPSExecute();
+        var result = format.write({
+            identifier: "Buffer",
+            dataInputs: {
+                inputs: [
+                        identifier: 'InputPolygon',
+                        title: 'Playground area',
+                        reference: {
+                            href: 'http://foo.bar/some_WFS_request.xml'
+                        identifier: 'BufferDistance',
+                        title: 'Distance which people will walk to get to a playground.',
+                        data: {
+                            literalData: 400
+            responseForm: {
+                responseDocument: {
+                    storeExecuteResponse: true,
+                    output: {
+                        asReference: true,
+                        identifier: 'BufferedPolygon',
+                        title: 'Area serviced by playground.',
+                        abstract: 'Area within which most users of this playground will live.'
+        t.xml_eq(result, expected, "WPS Execute written out correctly");
     </script>
 </head>
 <body>
More information about the Commits mailing list
