[OpenLayers-Commits] r12426 - in sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers: . Control Format/WMSCapabilities TimeAgent
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Oct 3 02:37:12 EDT 2011
Author: mpriour
Date: 2011-10-02 23:37:11 -0700 (Sun, 02 Oct 2011)
New Revision: 12426
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent.js
   sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent/WMS.js
Modify to better handle existing WMS 1.1 Dimension & resolutions data from GetCapabilities
Self-config control based on time agents
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js	2011-09-29 15:10:08 UTC (rev 12425)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/TimeManager.js	2011-10-03 06:37:11 UTC (rev 12426)
@@ -158,6 +158,16 @@
             this.timeAgents = this.buildTimeAgents(options.layers);
             if(this.timeAgents.length){this.fixedLayers=true;}
+        this.events.on({
+            'play': function(){
+                if (!this.units) {
+                    this.guessPlaybackRate()
+                else {
+                    this.events.un({'play': arguments.caller.callee,scope: this})
+            },scope:this
 	 * APIMethod: destroy
@@ -184,7 +194,7 @@
         if (!this.timeAgents) {
             for (var i = 0, len = map.layers.length; i < len; i++) {
                 var lyr = map.layers[i];
-                if (lyr.metadata.timeInterval && lyr.metadata.timeInterval.length) {
+                if ((lyr.dimensions && lyr.dimensions.time) || (lyr.metadata.timeInterval && lyr.metadata.timeInterval.length)) {
                     if (!this.layers) this.layers = [];
                     this.layers.push(lyr);
@@ -210,6 +220,9 @@
     onAddLayer: function(evt){
         var lyr = evt.layer;
+        if(lyr.dimensions && lyr.dimensions.time){
+            lyr.metadata.timeInterval = this.timeExtentsToIntervals(lyr.dimensions.time)
         var added=false;
         if (lyr.metadata.timeInterval && !this.fixedLayers) {
             this.timeAgents || (this.timeAgents = [])
@@ -457,14 +470,11 @@
 		//categorize layers and separate into arrays for use in subclasses
 		for(var i=0,len=layers.length;i<len;i++){
 			var lyr = layers[i];
+            if(lyr.dimensions && lyr.dimensions.time){lyr.metadata.timeInterval=this.timeExtentsToIntervals(lyr.dimensions.time)}
 			//allow user specified overrides and custom behavior
             if (lyr.timeAgent) {
                 var agent;
-                if(lyr.timeAgent instanceof OpenLayers.TimeAgent){
-                    agent = lyr.timeAgent;
-                    agent.layers = (agent.layers && agent.layers instanceof Array)?(agent.layers.push(lyr)):agent.layers=[lyr];
-                    agent.timeManager=this;
-                }else if(lyr.timeAgent instanceof Function){
+                if(lyr.timeAgent instanceof Function){
                     agent = new OpenLayers.TimeAgent({
                         onTick:lyr.timeAgent,
                         layers:[lyr],
@@ -543,6 +553,101 @@
         return (range.length)?range:null;
+    guessPlaybackRate:function(){
+        var timeSpans=this.getValidTimeSpans();
+        if (timeSpans) {
+            timeSpans.sort(function(a, b){
+                //sort by most restrictive range
+                var arange = a.end - a.start, brange = b.end - b.start;
+                if (arange != brange) {
+                    return (arange < brange) ? 1 : -1
+                else if (a.resolution.units != b.resolution.units) {
+                    //same range find biggest step unit
+                    switch (a.resolution.units) {
+                        case OpenLayers.TimeUnit.YEARS:
+                            return 1
+                        case OpenLayers.TimeUnit.SECONDS:
+                            return -1
+                        case OpenLayers.TimeUnit.MONTHS:
+                            return (b.resolution.units == OpenLayers.TimeUnit.YEARS) ? -1 : 1
+                        case OpenLayers.TimeUnit.MINUTES:
+                            return (b.resolution.units == OpenLayers.TimeUnit.SECONDS) ? 1 : -1
+                        case OpenLayers.TimeUnit.HOURS:
+                            if (b.resolution.units == OpenLayers.TimeUnit.MINUTES || b.resolution.units == OpenLayers.TimeUnit.SECONDS) {
+                                return 1
+                            else {
+                                return -1
+                        case OpenLayers.TimeUnit.DAYS:
+                            if (b.resolution.units == OpenLayers.TimeUnit.MONTHS || b.resolution.units == OpenLayers.TimeUnit.YEARS) {
+                                return -1
+                            else {
+                                return 1
+                else {
+                    //same range and units, pick largest step
+                    return a.resolution.step - b.resolution.step
+            this.setRange([timeSpans[0].start, timeSpans[0].end]);
+            this.units = timeSpans[0].resolution.units;
+            this.step = timeSpans[0].resolution.step;
+        else if (this.intervals) {
+            this.snapToIntervals = true;
+        else {
+            //guess based on range, keep step at 1
+            var diff = this.range[1] - this.range[0];
+            if (diff < 6e3) {
+                this.units = OpenLayers.TimeUnit.SECONDS;
+            else if (diff < 36e5) {
+                this.units = OpenLayers.TimeUnit.MINUTES;
+            else if (diff < 864e5) {
+                this.units = OpenLayers.TimeUnit.HOURS;
+            else if (diff < 2628e6) {
+                this.units = OpenLayers.TimeUnit.DAYS;
+            else if (diff < 31536e6) {
+                this.units = OpenLayers.TimeUnit.MONTHS;
+            else {
+                this.units = OpenLayers.TimeUnit.YEARS;
+    getValidTimeSpans:function(agents){
+        agents = agents || this.timeAgents || [];
+        var validTimes = []
+        for(var i=0,len=agents.length;i<len;i++){
+            if(agents[i].timeSpans){
+                validTimes=validTimes.concat(agents[i].timeSpans)
+        return (validTimes.length)?validTimes:null;
+    timeExtentsToIntervals: function(timeExtents){
+        var intervals=[];
+        for (var i = 0; i < timeExtents.length; ++i) {
+            var timeParts = timeExtents[i].split("/");
+            if (timeParts.length > 1) {
+                var min = timeParts[0], max = timeParts[1], res = timeParts[2];
+                intervals.push([min, max, res])
+            else {
+                intervals.push(timeParts[0])
+        return (intervals.length) ? intervals : null;
     getUniqueDates:function(dates){
         //sort the times
         dates.sort(function(a, b){return a - b;});
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js	2011-09-29 15:10:08 UTC (rev 12425)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js	2011-10-03 06:37:11 UTC (rev 12426)
@@ -428,6 +428,32 @@
             "SRS": function(node, obj) {
                 obj.srs[this.getChildValue(node)] = true;
+            "Dimension": function(node,obj){
+                var dimension = node.getAttribute("name");
+                var units = node.getAttribute("units");
+                obj.dimensions = obj.dimensions || [];
+                obj.dimensions.push({name:dimension,"units":unit})
+            "Extent": function(node,obj){
+                var type = node.getAttribute("name");
+                if(type == "time"){
+                    if(!obj.metadata){obj.metadata={}}
+                    var timeExtents = this.getChildValue(node),
+                    intervals=[];
+                    timeExtents = timeExtents.split(',');
+                        else {
+                    obj.metadata.timeInterval=intervals;
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent/WMS.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent/WMS.js	2011-09-29 15:10:08 UTC (rev 12425)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent/WMS.js	2011-10-03 06:37:11 UTC (rev 12426)
@@ -130,8 +130,28 @@
             isotime=OpenLayers.Date.toISOString(minTime)+'/'+OpenLayers.Date.toISOString(time)
-        else if(layer.metadata.timeInterval.length>2 && this.intervalMode != "exact"){
-			//TODO implement special case handling
+        else if(layer.metadata.timeInterval[0] instanceof Date && this.intervalMode != "exact"){
+			//find where this time fits into
+            var intervals = layer.metadata.timeInterval;
+            //first check that this time is in the array
+            for (var i = 0,len=intervals.length; i < len; i++) {
+                if (time.getTime() == intervals[i].getTime()) {
+                    isotime = OpenLayers.Date.toISOString(intervals[i])
+                    break;
+                else{
+                    var diff = time-intervals[i];
+                    if(diff<0){
+                        if(this.intervalMode=="lastValid"){
+                            isotime = OpenLayers.Date.toISOString(intervals[i-1])
+                        }else{
+                            var useTime = diff>(time-intervals[i-1]) ? intervals[i-1] : intervals[i];
+                            isotime = OpenLayers.Date.toISOString(useTime);
+                        break;
 		}else{
 			//format time in ISO:8601 format
 			isotime = OpenLayers.Date.toISOString(time);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent.js	2011-09-29 15:10:08 UTC (rev 12425)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/TimeAgent.js	2011-10-03 06:37:11 UTC (rev 12426)
@@ -58,8 +58,9 @@
         if (this.layers) {
             var timeConfig = this.buildRangeAndIntervals(this.layers);
-            this.range = timeConfig.range;
-            this.intervals = timeConfig.intervals;
+            this.range = timeConfig.range,
+            this.intervals = timeConfig.intervals,
+            this.timeSpans = timeConfig.timeSpans;
 	destroy:function(){
@@ -79,8 +80,9 @@
         else {
     removeLayer:function(layer){
@@ -96,29 +98,36 @@
         the range & intervals*/
        if(this.intervals || timeInterval[0].getTime() == this.range[0].getTime() || timeInterval[1].getTime() == this.range[1].getTime()){
 	buildRangeAndIntervals:function(layers){
-		var range = [], intervals=[];
+		var range = [], intervals=[], validTimes=[];
 			var timeInterval = (layers[i].metadata)?layers[i].metadata.timeInterval:null;
 			if (timeInterval) {
                 for (var j = 0; j < timeInterval.length; j++) {
-                    if (!(timeInterval[j] instanceof Date)) {
-                        timeInterval[j] = OpenLayers.Date.parse(timeInterval[j])
+                    if(timeInterval[j] instanceof Array){
+                        var min = OpenLayers.Date.parse(timeInterval[j][0]),
+                        max = OpenLayers.Date.parse(timeInterval[j][1]),
+                        resolution = timeInterval[j][2] ? this.parseISOPeriod(timeInterval[j][2]) : null;
+                        var timeRangeObj = {
+                            start: min,
+                            end: max,
+                            'resolution': (resolution) ? resolution : null
+                        validTimes.push(timeRangeObj);
+                        timeInterval[j] = timeRangeObj;
+                        if (!range[0] || min < range[0]) {range[0] = min;}
+                        if (!range[1] || max > range[1]) {range[1] = max;}
-                if (timeInterval.length == 2) {
-                    if (!range[0] || timeInterval[0] < range[0]) {range[0] = timeInterval[0];}
-                    if (!range[1] || timeInterval[1] > range[1]) {range[1] = timeInterval[1];}
-                else if (timeInterval.length > 2) {
-                    for (var j = 0; j < timeInterval.length; j++) {
-                        if (OpenLayers.Util.indexOf(intervals, timeInterval[j]) == -1) {
-                            intervals.push(timeInterval[j])
+                    else{
+                        if (!(timeInterval[j] instanceof Date)) {
+                            timeInterval[j] = OpenLayers.Date.parse(timeInterval[j])
+                        intervals.push(timeInterval[j])
@@ -127,12 +136,41 @@
             intervals = this.timeManager.getUniqueDates(intervals);
             var last = intervals.length-1;
             if (!range[0] || intervals[0] < range[0]) {range[0] = intervals[0];}
-			if (!range[1] || intervals[last] > range[1]) {range[1] = intervals[last];}
+            if (!range[1] || intervals[last] > range[1]) {range[1] = intervals[last];}
 		}else{
             intervals=null;
-		return {'range':range,'intervals':intervals}
+		return {'range':range,'intervals':intervals,'timeSpans':(validTimes.length)? validTimes : null}
+	parseISOPeriod:function(period){
+        var dateRE = [/(\d+)Y/,/(\d+)M/,/(\d+)D/],
+        timeRE = [/(\d+)H/,/(\d+)M/,/(\d+)S/],
+        periods = period.split('P')[1].split('T'),
+        intervalPeriod,d={};
+        if (periods[0]) {
+            var dt = periods[0];
+            d.years = dt.match(dateRE[0]) ? dt.match(dateRE[0])[1] : null;
+            d.months = dt.match(dateRE[1]) ? dt.match(dateRE[1])[1] * ((d.years) ? 12 * d.years : 1) : null;
+            d.days = dt.match(dateRE[2]) ? dt.match(dateRE[2])[1] * ((d.months) ? 30 * d.months : 1) : null;
+        if (periods[1]) {
+            var tm = periods[1];
+            d.hours = tm.match(timeRE[0]) ? tm.match(timeRE[0])[1] * ((d.days) ? 24 * d.days : 1) : null;
+            d.minutes = tm.match(timeRE[1]) ? tm.match(timeRE[1])[1] * ((d.hours) ? 60 * d.hours : 1) : null;
+            d.seconds = tm.match(timeRE[2]) ? tm.match(timeRE[2])[1] * ((d.hours) ? 60 * 60 * d.hours : (d.minutes) ? 60 * d.minutes : 1) : null;
+        var unitTest = ['seconds','minutes','hours','days','months','years']
+        for(var i=0;i<unitTest.length;++i){
+            var u = unitTest[i];
+            if(d[u]){
+                intervalPeriod = {
+                    step: d[u],
+                    units: OpenLayers.TimeUnit[u.toUpperCase()]
+                break;
+        return intervalPeriod;
 	CLASS_NAME:'OpenLayers.TimeAgent'
\ No newline at end of file
More information about the Commits mailing list
