[OpenLayers-Commits] r12427 - in sandbox/august/trunk: . playground playground/mapquest playground/wmts
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Oct 6 18:42:06 EDT 2011
Author: augusttown
Date: 2011-10-06 15:42:05 -0700 (Thu, 06 Oct 2011)
New Revision: 12427
Added:
   sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html
   sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-epsg3857.html
   sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-wgs84.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.js
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.js
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.js
Removed:
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.js
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js
   sandbox/august/trunk/OpenLayers.js
   sandbox/august/trunk/playground/index.html
   sandbox/august/trunk/playground/mapquest/mapquest-osm.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.js
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.html
   sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.js
   sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857-load-capa.js
Modified: sandbox/august/trunk/OpenLayers.js
--- sandbox/august/trunk/OpenLayers.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/OpenLayers.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -127,7 +127,7 @@
 if(!factory){return;}
 if(!window.google){google={};}
 if(!google.gears){google.gears={factory:factory};}})();var OpenLayers={VERSION_NUMBER:"$Revision: 11704 $",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
-return(function(){return l;});})()};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
+return(function(){return l;});})()};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.prototype.initialize.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
 return C;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(P){var C=function(){P.call(this);};var newArgs=[C].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,newArgs);return C.prototype;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
 OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
 var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
@@ -159,17 +159,7 @@
 if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
 OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
 for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
-return selected;}};OpenLayers.Date={toISOString:(function(){if("toISOString"in Date.prototype){return function(date){return date.toISOString();};}else{function pad(num,len){var str=num+"";while(str.length<len){str="0"+str;}
-return str;}
-return function(date){var str;if(isNaN(date.getTime())){str="Invalid Date";}else{str=date.getUTCFullYear()+"-"+
-pad(date.getUTCMonth()+1,2)+"-"+
-pad(date.getUTCDate(),2)+"T"+
-pad(date.getUTCHours(),2)+":"+
-pad(date.getUTCMinutes(),2)+":"+
-pad(date.getUTCSeconds(),2)+"."+
-pad(date.getUTCMilliseconds(),3)+"Z";}
-return str;};}})(),parse:function(str){var date;var match=str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);if(match&&(match[1]||match[7])){var year=parseInt(match[1],10)||0;var month=(parseInt(match[2],10)-1)||0;var day=parseInt(match[3],10)||1;date=new Date(Date.UTC(year,month,day));var type=match[7];if(type){var hours=parseInt(match[4],10);var minutes=parseInt(match[5],10);var secFrac=parseFloat(match[6]);var seconds=secFrac|0;var milliseconds=Math.round(1000*(secFrac-seconds));date.setUTCHours(hours,minutes,seconds,milliseconds);if(type!=="Z"){var hoursOffset=parseInt(type,10);var minutesOffset=parseInt(match[8],10)||0;var offset=-1000*(60*(hoursOffset*60)+minutesOffset*60);date=new Date(date.getTime()+offset);}}}else{date=new Date("invalid");}
-return date;}};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
+return selected;}};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
 if(bottom!=null){this.bottom=OpenLayers.Util.toFloat(bottom);}
 if(right!=null){this.right=OpenLayers.Util.toFloat(right);}
 if(top!=null){this.top=OpenLayers.Util.toFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
@@ -201,7 +191,7 @@
 return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(lon),this.lat+OpenLayers.Util.toFloat(lat));},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
 return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
 while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
-return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(pair[0],pair[1]);};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
+return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(pair[0],pair[1]);};OpenLayers.LonLat.fromArray=function(arr){var gotArr=OpenLayers.Util.isArray(arr),lon=gotArr&&arr[0],lat=gotArr&&arr[1];return new OpenLayers.LonLat(lon,lat);};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
 return equals;},distanceTo:function(px){return Math.sqrt(Math.pow(this.x-px.x,2)+
 Math.pow(this.y-px.y,2));},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
 return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
@@ -245,11 +235,7 @@
 paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
 return paramsArray.join("&");};OpenLayers.Util.urlAppend=function(url,paramStr){var newUrl=url;if(paramStr){var parts=(url+" ").split(/[?&]/);newUrl+=(parts.pop()===" "?paramStr:parts.length?"&"+paramStr:"?"+paramStr);}
 return newUrl;};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0,len=arguments.length;i<len;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
-return returnValue;};OpenLayers.Util.getNodes=function(p,tagName){var nodes=OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(p.documentElement.childNodes,tagName);},function(){return OpenLayers.Util._getNodes(p.childNodes,tagName);});return nodes;};OpenLayers.Util._getNodes=function(nodes,tagName){var retArray=[];for(var i=0,len=nodes.length;i<len;i++){if(nodes[i].nodeName==tagName){retArray.push(nodes[i]);}}
-return retArray;};OpenLayers.Util.getTagText=function(parent,item,index){var result=OpenLayers.Util.getNodes(parent,item);if(result&&(result.length>0))
-{if(!index){index=0;}
-if(result[index].childNodes.length>1){return result.childNodes[1].nodeValue;}
-else if(result[index].childNodes.length==1){return result[index].firstChild.nodeValue;}}else{return"";}};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
+return returnValue;};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
 if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
 return(target!=div);};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(number,precision){if(precision==null){precision=OpenLayers.Util.DEFAULT_PRECISION;}
 if(typeof number!=="number"){number=parseFloat(number);}
@@ -260,7 +246,7 @@
 var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
 B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.destinationVincenty=function(lonlat,brng,dist){var u=OpenLayers.Util;var ct=u.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var lon1=lonlat.lon;var lat1=lonlat.lat;var s=dist;var alpha1=u.rad(brng);var sinAlpha1=Math.sin(alpha1);var cosAlpha1=Math.cos(alpha1);var tanU1=(1-f)*Math.tan(u.rad(lat1));var cosU1=1/Math.sqrt((1+tanU1*tanU1)),sinU1=tanU1*cosU1;var sigma1=Math.atan2(tanU1,cosAlpha1);var sinAlpha=cosU1*sinAlpha1;var cosSqAlpha=1-sinAlpha*sinAlpha;var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var sigma=s/(b*A),sigmaP=2*Math.PI;while(Math.abs(sigma-sigmaP)>1e-12){var cos2SigmaM=Math.cos(2*sigma1+sigma);var sinSigma=Math.sin(sigma);var cosSigma=Math.cos(sigma);var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2Sigm
 aM)-
 B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));sigmaP=sigma;sigma=s/(b*A)+deltaSigma;}
-var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=url||window.location.href;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=(url===null||url===undefined)?window.location.href:url;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
 var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0,len=pairs.length;i<len;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=keyValue[0];try{key=decodeURIComponent(key);}catch(err){key=unescape(key);}
 var value=(keyValue[1]||'').replace(/\+/g," ");try{value=decodeURIComponent(value);}catch(err){value=unescape(value);}
 value=value.split(",");if(value.length==1){value=value[0];}
@@ -295,7 +281,7 @@
 if(!h){h=parseInt(content.scrollHeight);}
 container.removeChild(content);containerElement.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
 return scrollbarWidth;};OpenLayers.Util.getFormattedLonLat=function(coordinate,axis,dmsOption){if(!dmsOption){dmsOption='dms';}
-var abscoordinate=Math.abs(coordinate);var coordinatedegrees=Math.floor(abscoordinate);var coordinateminutes=(abscoordinate-coordinatedegrees)/(1/60);var tempcoordinateminutes=coordinateminutes;coordinateminutes=Math.floor(coordinateminutes);var coordinateseconds=(tempcoordinateminutes-coordinateminutes)/(1/60);coordinateseconds=Math.round(coordinateseconds*10);coordinateseconds/=10;if(coordinateseconds>=60){coordinateseconds-=60;coordinateminutes+=1;if(coordinateminutes>=60){coordinateminutes-=60;coordinatedegrees+=1;}}
+coordinate=(coordinate+540)%360-180;var abscoordinate=Math.abs(coordinate);var coordinatedegrees=Math.floor(abscoordinate);var coordinateminutes=(abscoordinate-coordinatedegrees)/(1/60);var tempcoordinateminutes=coordinateminutes;coordinateminutes=Math.floor(coordinateminutes);var coordinateseconds=(tempcoordinateminutes-coordinateminutes)/(1/60);coordinateseconds=Math.round(coordinateseconds*10);coordinateseconds/=10;if(coordinateseconds>=60){coordinateseconds-=60;coordinateminutes+=1;if(coordinateminutes>=60){coordinateminutes-=60;coordinatedegrees+=1;}}
 if(coordinatedegrees<10){coordinatedegrees="0"+coordinatedegrees;}
 var str=coordinatedegrees+"\u00B0";if(dmsOption.indexOf('dm')>=0){if(coordinateminutes<10){coordinateminutes="0"+coordinateminutes;}
 str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
@@ -357,7 +343,7 @@
 return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push('('+
 this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
 return array.join(',');},'collection':function(collection){var array=[];for(var i=0,len=collection.components.length;i<len;++i){array.push(this.extractGeometry.apply(this,[collection.components[i]]));}
-return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var point;var points=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=points.length;i<len;++i){point=points[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.point.apply(this,[point]).geometry);}
+return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var point;var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){point=points[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.point.apply(this,[point]).geometry);}
 return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
 return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=lines.length;i<len;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
 return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=rings.length;i<len;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
@@ -427,7 +413,17 @@
 var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
 uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
 return uri;},getXMLDoc:function(){if(!OpenLayers.Format.XML.document&&!this.xmldom){if(document.implementation&&document.implementation.createDocument){OpenLayers.Format.XML.document=document.implementation.createDocument("","",null);}else if(!this.xmldom&&window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}}
-return OpenLayers.Format.XML.document||this.xmldom;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return OpenLayers.Format.XML.document||this.xmldom;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Date={toISOString:(function(){if("toISOString"in Date.prototype){return function(date){return date.toISOString();};}else{function pad(num,len){var str=num+"";while(str.length<len){str="0"+str;}
+return str;}
+return function(date){var str;if(isNaN(date.getTime())){str="Invalid Date";}else{str=date.getUTCFullYear()+"-"+
+pad(date.getUTCMonth()+1,2)+"-"+
+pad(date.getUTCDate(),2)+"T"+
+pad(date.getUTCHours(),2)+":"+
+pad(date.getUTCMinutes(),2)+":"+
+pad(date.getUTCSeconds(),2)+"."+
+pad(date.getUTCMilliseconds(),3)+"Z";}
+return str;};}})(),parse:function(str){var date;var match=str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);if(match&&(match[1]||match[7])){var year=parseInt(match[1],10)||0;var month=(parseInt(match[2],10)-1)||0;var day=parseInt(match[3],10)||1;date=new Date(Date.UTC(year,month,day));var type=match[7];if(type){var hours=parseInt(match[4],10);var minutes=parseInt(match[5],10);var secFrac=parseFloat(match[6]);var seconds=secFrac|0;var milliseconds=Math.round(1000*(secFrac-seconds));date.setUTCHours(hours,minutes,seconds,milliseconds);if(type!=="Z"){var hoursOffset=parseInt(type,10);var minutesOffset=parseInt(match[8],10)||0;var offset=-1000*(60*(hoursOffset*60)+minutesOffset*60);date=new Date(date.getTime()+offset);}}}else{date=new Date("invalid");}
+return date;}};OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
 return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
 return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
 var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(OpenLayers.Util.isArray(result)){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
@@ -469,10 +465,10 @@
 this.bounds=null;}
 return this;},intersects:function(geometry){var intersect=false;for(var i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
 return intersect;},getVertices:function(nodes){var vertices=[];for(var i=0,len=this.components.length;i<len;++i){Array.prototype.push.apply(vertices,this.components[i].getVertices(nodes));}
-return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
+return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
 return length;},getGeodesicLength:function(projection){var geom=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){geom=this.clone().transform(projection,gg);}}
 var length=0.0;if(geom.components&&(geom.components.length>1)){var p1,p2;for(var i=1,len=geom.components.length;i<len;i++){p1=geom.components[i-1];p2=geom.components[i];length+=OpenLayers.Util.distVincenty({lon:p1.x,lat:p1.y},{lon:p2.x,lat:p2.y});}}
-return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){var removed=this.components&&(this.components.length>2);if(removed){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}
+return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{removeComponent:function(point){var removed=this.components&&(this.components.length>2);if(removed){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}
 return removed;},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
 var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0,len=segs1.length;i<len;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0,jlen=segs2.length;j<jlen;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
 if(seg2.x2<seg1x1){continue;}
@@ -506,7 +502,7 @@
 if(maxDistance>tolerance&&indexFarthest!=firstPoint){pointIndexsToKeep.push(indexFarthest);douglasPeuckerReduction(points,firstPoint,indexFarthest,tolerance);douglasPeuckerReduction(points,indexFarthest,lastPoint,tolerance);}};var perpendicularDistance=function(point1,point2,point){var area=Math.abs(0.5*(point1.x*point2.y+point2.x*point.y+point.x*point1.y-point2.x*point1.y-point.x*point2.y-point1.x*point.y));var bottom=Math.sqrt(Math.pow(point1.x-point2.x,2)+Math.pow(point1.y-point2.y,2));var height=area/bottom*2;return height;};var firstPoint=0;var lastPoint=points.length-1;var pointIndexsToKeep=[];pointIndexsToKeep.push(firstPoint);pointIndexsToKeep.push(lastPoint);while(points[firstPoint].equals(points[lastPoint])){lastPoint--;pointIndexsToKeep.push(lastPoint);}
 douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
 return new OpenLayers.Geometry.LineString(returnPoints);}
-else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
+else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
 var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){var removed=this.components&&(this.components.length>3);if(removed){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}
 return removed;},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
 return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
@@ -526,7 +522,7 @@
 if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
 if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
 var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0,len=geometry.components.length;i<len;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
+return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
 return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
 return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
 break;}}}}}
@@ -550,13 +546,12 @@
 if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
 return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
 OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
-OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(eventTypes!=null){for(var i=0,len=eventTypes.length;i<len;i++){this.addEventType(eventTypes[i]);}}
-if(element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
-this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.eventTypes.push(eventName);this.listeners[eventName]=[];}},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
-this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
-OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if((func!=null)&&(OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];listeners.push({obj:obj,func:func});}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};if(element!=null){this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
+this.element=null;this.listeners=null;this.object=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
+this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){OpenLayers.Event.observe(element,this.BROWSER_EVENTS[i],this.eventHandler);}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func,priority){if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(!listeners){listeners=[];this.listeners[type]=listeners;}
+if(priority){listeners.unshift({obj:obj,func:func});}else{listeners.push({obj:obj,func:func});}}},registerPriority:function(type,obj,func){this.register(type,obj,func,true);},un:function(object){for(var type in object){if(type!="scope"&&object.hasOwnProperty(type)){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
 var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return undefined;}
 if(evt==null){evt={};}
 evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
@@ -572,7 +567,7 @@
 if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
 return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
 -this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
--this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uP
 ort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
+-this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if
 if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
 request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
 var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
@@ -691,13 +686,13 @@
 kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
 if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
 return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=feature.style&&feature.style.label?feature.style.label:feature.attributes.name||feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=feature.attributes.description||this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection&&!(geometry instanceof OpenLayers.Geometry.Collection)){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
+placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
 return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0,len=rings.length;i<len;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[
 i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
 return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0,len=geometry.components.length;i<len;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.Mult
 iLineString([sourceLines[k]]));}}
+return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=this.buildCoordinates(point);}
+path=parts.join(" ");}else{path=this.buildCoordinates(geometry);}
+var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},buildCoordinates:function(point){if(this.internalProjection&&this.externalProjection){point=point.clone();point.transform(this.internalProjection,this.externalProjection);}
+return point.x+","+point.y;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
 sourceSplit=true;splits=splits[1];}
 if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
 if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
@@ -712,7 +707,7 @@
 if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
 if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
 if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
-return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
 return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
 break;}}
@@ -776,9 +771,9 @@
 if(container.bounds){feature.bounds=container.bounds;}
 obj.features.push(feature);},"_geometry":function(node,obj){if(!this.geometryName){this.geometryName=node.nodeName.split(":").pop();}
 this.readChildNodes(node,obj);},"_attribute":function(node,obj){var local=node.localName||node.nodeName.split(":").pop();var value=this.getChildValue(node);obj.attributes[local]=value;}},"wfs":{"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);}}},write:function(features){var name;if(OpenLayers.Util.isArray(features)){name="featureMembers";}else{name="featureMember";}
-var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":{"featureMember":function(feature){var node=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",feature,node);return node;},"MultiPoint":function(geometry){var node=this.createElementNSPlus("gml:MultiPoint");for(var i=0;i<geometry.components.length;++i){this.writeNode("pointMember",geometry.components[i],node);}
-return node;},"pointMember":function(geometry){var node=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",geometry,node);return node;},"MultiLineString":function(geometry){var node=this.createElementNSPlus("gml:MultiLineString");for(var i=0;i<geometry.components.length;++i){this.writeNode("lineStringMember",geometry.components[i],node);}
-return node;},"lineStringMember":function(geometry){var node=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",geometry,node);return node;},"MultiPolygon":function(geometry){var node=this.createElementNSPlus("gml:MultiPolygon");for(var i=0;i<geometry.components.length;++i){this.writeNode("polygonMember",geometry.components[i],node);}
+var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":{"featureMember":function(feature){var node=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",feature,node);return node;},"MultiPoint":function(geometry){var node=this.createElementNSPlus("gml:MultiPoint");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("pointMember",components[i],node);}
+return node;},"pointMember":function(geometry){var node=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",geometry,node);return node;},"MultiLineString":function(geometry){var node=this.createElementNSPlus("gml:MultiLineString");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("lineStringMember",components[i],node);}
+return node;},"lineStringMember":function(geometry){var node=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",geometry,node);return node;},"MultiPolygon":function(geometry){var node=this.createElementNSPlus("gml:MultiPolygon");var components=geometry.components||[geometry];for(var i=0,ii=components.length;i<ii;++i){this.writeNode("polygonMember",components[i],node);}
 return node;},"polygonMember":function(geometry){var node=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",geometry,node);return node;},"GeometryCollection":function(geometry){var node=this.createElementNSPlus("gml:GeometryCollection");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("geometryMember",geometry.components[i],node);}
 return node;},"geometryMember":function(geometry){var node=this.createElementNSPlus("gml:geometryMember");var child=this.writeNode("feature:_geometry",geometry);node.appendChild(child.firstChild);return node;}},"feature":{"_typeName":function(feature){var node=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:feature.fid}});if(feature.geometry){this.writeNode("feature:_geometry",feature.geometry,node);}
 for(var name in feature.attributes){var value=feature.attributes[name];if(value!=null){this.writeNode("feature:_attribute",{name:name,value:value},node);}}
@@ -832,10 +827,10 @@
 break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
 break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
 return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
 if(feature.geometry.intersects(geom)){intersect=true;}}
 break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
-return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",stringifyOutput:true,namedLayersAsArray:false,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Filter.Function"}
 );OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":f
 unction(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new Op
 enLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node
 ,obj,OpenLayers.Filter.Spatial.CONTAINS);},"DWithin":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.DWITHIN);},"Distance":function(node,obj){obj.distance=parseInt(this.getChildValue(node));obj.distanceUnits=node.getAttribute("units");},"Function":function(node,obj){return;}}},readSpatial:function(node,obj,type){var filter=new OpenLayers.Filter.Spatial({type:type});this.readChildNodes(node,filter);filter.value=filter.components[0];delete filter.components;obj.filters.push(filter);},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(value===undefined){value=this.getChildValue(node);}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",stringifyOutput:true,namedLayersAsArray:false,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,CLASS_NAME:"OpenLayers.Filter.Function"});OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http:
 //www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.O
 R});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});thi
 s.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.CONTAINS);},"DWithin":function(node,obj){this.readSpatial(nod
 return value;},writeOgcExpression:function(value,node){if(value instanceof OpenLayers.Filter.Function){var child=this.writeNode("Function",value,node);node.appendChild(child);}else{this.writeNode("Literal",value,node);}
 return node;},write:function(filter){return this.writers.ogc["Filter"].apply(this,[filter]);},writeFeatureIdNodes:function(filter,node){for(var i=0,ii=filter.fids.length;i<ii;++i){this.writeNode("FeatureId",filter.fids[i],node);}},writers:{"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");if(filter.type==="FID"){this.writeFeatureIdNodes(filter,node);}else{this.writeNode(this.getFilterType(filter),filter,node);}
 return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0,ii=filter.filters.length;i<ii;++i){childFilter=filter.filters[i];if(childFilter.type==="FID"){this.writeFeatureIdNodes(childFilter,node);}else{this.writeNode(this.getFilterType(childFilter),childFilter,node);}}
@@ -942,13 +937,13 @@
 return node;},"Server":function(options){var node=this.createElementNSPlus("Server",{attributes:{version:options.version,service:options.service}});this.writeNode("OnlineResource",options,node);return node;},"OnlineResource":function(options){var node=this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":options.url}});return node;},"InlineGeometry":function(layer){var node=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",layer.getDataExtent(),node);for(var i=0,len=layer.features.length;i<len;i++){this.writeNode("gml:featureMember",layer.features[i],node);}
 return node;},"StyleList":function(styles){var node=this.createElementNSPlus("StyleList");for(var i=0,len=styles.length;i<len;i++){this.writeNode("Style",styles[i],node);}
 return node;},"Style":function(style){var node=this.createElementNSPlus("Style");this.writeNode("Name",style,node);this.writeNode("Title",style,node);if(style.legend){this.writeNode("LegendURL",style,node);}
-return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.opacity?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.metadata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
+return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.hasOwnProperty("opacity")?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.metadata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
 return node;},"_Layer":function(options){var layer,subPaths,node,title;layer=options.layer;subPaths=options.subPaths;node=null;title=null;if(subPaths.length>0){var path=subPaths[0].join("/");var index=path.lastIndexOf("/");node=this.nestingLayerLookup[path];title=(index>0)?path.substring(index+1,path.length):path;if(!node){node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",title,node);this.nestingLayerLookup[path]=node;}
 options.subPaths.shift();this.writeNode("_Layer",options,node);return node;}else{if(layer instanceof OpenLayers.Layer.WMS){node=this.writeNode("_WMS",layer);}else if(layer instanceof OpenLayers.Layer.Vector){if(layer.protocol instanceof OpenLayers.Protocol.WFS.v1){node=this.writeNode("_WFS",layer);}else if(layer.protocol instanceof OpenLayers.Protocol.HTTP){if(layer.protocol.format instanceof OpenLayers.Format.GML){layer.protocol.format.version="2.1.2";node=this.writeNode("_GML",layer);}else if(layer.protocol.format instanceof OpenLayers.Format.KML){layer.protocol.format.version="2.2";node=this.writeNode("_KML",layer);}}else{this.setNamespace("feature",this.featureNS);node=this.writeNode("_InlineGeometry",layer);}}
 if(layer.options.maxScale){this.writeNode("sld:MinScaleDenominator",layer.options.maxScale,node);}
 if(layer.options.minScale){this.writeNode("sld:MaxScaleDenominator",layer.options.minScale,node);}
 this.nestingLayerLookup[layer.name]=node;return node;}},"_WFS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.protocol.featurePrefix+":"+layer.protocol.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:layer.protocol.version,url:layer.protocol.url},node);return node;},"_InlineGeometry":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("InlineGeometry",layer,node);return node;},"_GML":function(layer){var node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:layer.protocol.url,version:layer.protocol.format.version},node);return node;},"_KML":function(layer){var node=this.createE
 lementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:layer.protocol.format.version,url:layer.protocol.url},node);return node;}},"gml":OpenLayers.Util.applyDefaults({"boundedBy":function(bounds){var node=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",bounds,node);return node;}},OpenLayers.Format.GML.v2.prototype.writers.gml),"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,"feature":OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Format.CSWGetRecords=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetRecords.DEFAULTS);var cls=OpenLayers.Format.CSWGetRecords["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetRecords version: "+options.version;}
-return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
 if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
 this.events.destroy();this.events=null;}
 this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
@@ -996,9 +991,9 @@
 window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
 var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
 this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","preremovelayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,i
 nitialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
 verlay:325,Feature:725,Popup:750,Control:1000},id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
 this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
-OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.ev
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,null,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this
 .eventListeners);}
 this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
 if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
 if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
@@ -1055,7 +1050,7 @@
 this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;if(wrapDateLine){if(this.maxPx.x>maxX){this.maxPx.x-=(maxX-minX);}
 if(this.minPx.x<minX){this.minPx.x+=(maxX-minX);}}}
 if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
-var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
+var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility&&(layer===this.baseLayer||layer.inRange)){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
 this.events.triggerEvent("move");}},moveTo:function(lonlat,zoom,options){if(!options){options={};}
 if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
 var dragging=options.dragging||this.dragging;var forceZoomChange=options.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();this.center=lonlat.clone();}
@@ -1096,7 +1091,7 @@
 return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
 return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
 return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
 :null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,trans
 itionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
 if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
 if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
 this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
@@ -1192,12 +1187,28 @@
 this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject.getContainer();if(visible===true){this.mapObject.setMapType(this.type);container.style.display="";this.termsOfUse.style.left="";this.termsOfUse.style.display="";this.poweredBy.style.display="";cache.displayed=this.id;}else{if(cache.displayed===this.id){delete cache.displayed;}
 if(!cache.displayed){container.style.display="none";this.termsOfUse.style.display="none";this.termsOfUse.style.left="-9999px";this.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getContainer();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
 return moBounds;},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
+return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
 return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
 return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,timerId:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this);},removeMap:function(map){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[i
 Row];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Tile=OpenLayers.Class({events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;if(size){this.size=size.clone();}
+this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},draw:function(){this.clear();return this.shouldDraw();},shouldDraw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));return withinMaxExtent||this.layer.displayOutsideMaxExtent;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(draw){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.BackBufferable=OpenLayers.Class(OpenLayers.Tile,{backBufferMode:null,backBufferData:null,initialize:function(){OpenLayers.Tile.prototype.initialize.apply(this,arguments);var transitionSupported=OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1;this.backBufferMode=(this.layer.singleTile&&1)|(transitionSupported&&2);this.backBufferData={};if(!this.size){this.size=new OpenLayers.Size(256,256);}},draw:function(){var draw=OpenLayers.Tile.prototype.shouldDraw.apply(this,arguments),backBufferMode=this.backBufferMode;if(draw){this.updateBackBuffer();}
+this.clear();if(!draw){this.resetBackBuffer();};return draw;},setBackBufferData:function(){this.backBufferData=OpenLayers.Util.extend(this.backBufferData,{bounds:this.bounds,resolution:this.layer.map.getResolution()});},updateBackBuffer:function(){var layer=this.layer,map=layer.map,backBufferMode=this.backBufferMode,data=this.backBufferData,tile=this.getTile(),backBuffer=data.tile,resolution=data.resolution,ratio=resolution?resolution/map.getResolution():1,notNeeded=!(ratio==1?backBufferMode&1:backBufferMode&2),noParent=tile&&tile.parentNode!==layer.div,noTile=!(tile&&tile.childNodes.length>0),noBackBuffer=!backBuffer&&this.isLoading;if(notNeeded||noParent||noTile||noBackBuffer){this.setBackBufferData();return;}
+if(!backBuffer){backBuffer=this.createBackBuffer();layer.events.register("loadend",this,this.resetBackBuffer);data.tile=backBuffer;layer.div.insertBefore(backBuffer,tile);}
+var lonLat={lon:data.bounds.left,lat:data.bounds.top},position=map.getPixelFromLonLat(lonLat),containerStyle=map.layerContainerDiv.style,leftOffset=parseInt(containerStyle.left,10),topOffset=parseInt(containerStyle.top,10),style=backBuffer.style;style.left=(position.x-leftOffset)+"px";style.top=(position.y-topOffset)+"px";style.width=(this.size.w*ratio)+"px";style.height=(this.size.h*ratio)+"px";return backBuffer;},resetBackBuffer:function(){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.removeBackBuffer();this.setBackBufferData();},removeBackBuffer:function(){var backBufferData=this.backBufferData;var backBuffer=backBufferData.tile;delete backBufferData.tile;var parent=backBuffer&&backBuffer.parentNode;if(backBuffer){parent.removeChild(backBuffer);}},destroy:function(){this.removeBackBuffer();this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.backBufferData=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);}});OpenLayer
 s.Tile.Image=OpenLayers.Class(OpenLayers.Tile.BackBufferable,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,blankImageUrl:"data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.BackBufferable.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement("div");this.frame.style.position="absolute";this.frame.style.overflow="hidden";this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}},destroy:function(){if(this.frame!=null){this.clear();this.imgDiv=null;this.frame=null;}
+this.asyncRequestId=null;OpenLayers.Tile.BackBufferable.prototype.destroy.apply(this,arguments);},draw:function(){var drawn=OpenLayers.Tile.BackBufferable.prototype.draw.apply(this,arguments);if(drawn){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+this.positionTile();this.renderTile();}else{this.unload();}
+return drawn;},renderTile:function(){this.layer.div.appendChild(this.frame);if(this.layer.async){var myId=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,this,"url",function(){if(myId==this.asyncRequestId){this.initImage();}});}else{this.url=this.layer.getURL(this.bounds);this.initImage();}},positionTile:function(){var style=this.frame.style;style.left=this.position.x+"px";style.top=this.position.y+"px";style.width=this.size.w+"px";style.height=this.size.h+"px";},clear:function(){var img=this.imgDiv;if(img){OpenLayers.Event.stopObservingElement(img);if(this.frame.parentNode===this.layer.div){this.layer.div.removeChild(this.frame);}
+this.setImgSrc();if(this.layerAlphaHack===true){img.style.filter="";}
+OpenLayers.Element.removeClass(img,"olImageLoadError");}},createImage:function(){var img=document.createElement("img");this.imgDiv=img;img.className="olTileImage";img.galleryImg="no";var style=img.style,gutter=this.layer.gutter;if(gutter){var tileSize=this.layer.tileSize,left=(gutter/tileSize.w*100),top=(gutter/tileSize.h*100);style.left=-left+"%";style.top=-top+"%";style.width=(2*left+100)+"%";style.height=(2*top+100)+"%";style.position="absolute";}else{style.width="100%";style.height="100%";}
+style.display="none";if(this.layer.opacity<1){OpenLayers.Util.modifyDOMElement(img,null,null,null,null,null,null,this.layer.opacity);}
+if(this.layerAlphaHack){style.paddingTop=style.height;style.height="0";}
+this.frame.appendChild(img);return img;},initImage:function(){var img=this.imgDiv||this.createImage();if(this.url&&img.getAttribute("src")==this.url){this.onImageLoad();}else{var load=OpenLayers.Function.bind(function(){OpenLayers.Event.stopObservingElement(img);OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(this.onImageLoad,this));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(this.onImageError,this));this.imageReloadAttempts=0;this.setImgSrc(this.url);},this);if(img.getAttribute("src")==this.blankImageUrl){load();}else{OpenLayers.Event.observe(img,"load",load);OpenLayers.Event.observe(img,"error",load);img.src=this.blankImageUrl;}}},setImgSrc:function(url){var img=this.imgDiv;img.style.display="none";if(url){img.src=url;}},getTile:function(){return this.frame;},createBackBuffer:function(){var frame=this.frame.cloneNode(false);frame.appendChild(this.imgDiv);this.imgDiv=null;return frame;},onImageLoad:function(){var img=this.imgDiv;OpenLayers.Eve
 nt.stopObservingElement(img);img.style.display="";this.isLoading=false;this.events.triggerEvent("loadend");if(this.layerAlphaHack===true){img.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+
+img.src+"', sizingMethod='scale')";}},onImageError:function(){var img=this.imgDiv;if(img.src!=null){this.imageReloadAttempts++;if(this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.setImgSrc(this.layer.getURL(this.bounds));}else{OpenLayers.Element.addClass(img,"olImageLoadError");this.onImageLoad();}}},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,timerId:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this);},removeMap:function(map){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},destroy:function(){this.clearGrid();this.grid=nul
 l;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[iRow];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
 obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.scheduleMoveGriddedTiles();}}}},moveByPx:function(dx,dy){if(!this.singleTile){this.scheduleMoveGriddedTiles();}},scheduleMoveGriddedTiles:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);}
@@ -1219,36 +1230,10 @@
 if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
 maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;if(size){this.size=size.clone();}
-this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
-this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
-this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){this.removeImgDiv();}
-this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
-this.frame=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}
-this.layer.events.unregister("loadend",this,this.resetBackBuffer);OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
-obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
-var drawTile=OpenLayers.Tile.prototype.draw.apply(this,arguments);if((OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1)||this.layer.singleTile){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
-this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
-if(!drawTile){return false;}
-if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-return this.renderTile();},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.getImageSize(this.bounds)||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}
-this.backBufferTile.hide();}},renderTile:function(){if(this.layer.async){this.initImgDiv();this.layer.getURLasync(this.bounds,this,"url",this.positionImage);}else{this.url=this.layer.getURL(this.bounds);this.initImgDiv();this.positionImage();}
-return true;},positionImage:function(){if(this.layer===null){return;}
-OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){if(this.imgDiv==null){var offset=this.layer.imageOffset;var size=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
-if(OpenLayers.Util.isArray(this.layer.url)){this.imgDiv.urls=this.layer.url.slice();}
-this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
-this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
-var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));}
-this.imgDiv.viewRequestID=this.layer.map.viewRequestID;},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}
-this.imgDiv.urls=null;var child=this.imgDiv.firstChild;if(child){OpenLayers.Event.stopObservingElement(child);this.imgDiv.removeChild(child);delete child;}else{this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
-var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
-if(ratio!=1){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
-OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128
 *156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
 url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
-return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
+return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var resolutions=this.serverResolutions||this.resolutions;var z=this.zoomOffset==0?OpenLayers.Util.indexOf(resolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
 {x=((x%limit)+limit)%limit;}
 return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
 obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
@@ -1257,13 +1242,13 @@
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
 this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(control,callbacks,optio
 ns){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,citeCompliant:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,pixelTolerance:5,touch:false,lastTouchPx:null,initialize:function(con
 trol,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
 OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
+var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
 this.cancel();if(this.layer.map!=null){this.destroyFeature(true);this.layer.destroy(false);}
 this.layer=null;this.touch=false;return true;},destroyFeature:function(force){if(this.layer&&(force||!this.persist)){this.layer.destroyFeatures();}
 this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel){var key=cancel?"cancel":"done";this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.lastTouchPx=null;this.callback(key,[this.geometryClone()]);this.destroyFeature(cancel);},cancel:function(){this.finalize(true);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){if(!this.point){this.createFeature(pixel);}
-var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
 return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){return this.down(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
 this.lastTouchPx=evt.xy;return this.down(evt);},mousemove:function(evt){return this.move(evt);},touchmove:function(evt){this.lastTouchPx=evt.xy;return this.move(evt);},mouseup:function(evt){return this.up(evt);},touchend:function(evt){evt.xy=this.lastTouchPx;return this.up(evt);},down:function(evt){this.mouseDown=true;this.lastDown=evt.xy;if(!this.touch){this.modifyFeature(evt.xy);}
 this.stoppedDown=this.stopDown;return!this.stopDown;},move:function(evt){if(!this.touch&&(!this.mouseDown||this.stoppedDown)){this.modifyFeature(evt.xy);}
@@ -1272,13 +1257,13 @@
 if(this.lastDown&&this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance)){if(this.touch){this.modifyFeature(evt.xy);}
 if(this.persist){this.destroyPersistedFeature();}
 this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},passesTolerance:function(pixel1,pixel2,tolerance){var passes=true;if(tolerance!=null&&pixel1&&pixel2){var dist=pixel1.distanceTo(pixel2);if(dist>tolerance){passes=false;}}
-return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(lay
 er&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousIndex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.
 insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=length*Math.cos(direction);var dy=length*Math.sin(direction);this.insertDeltaXY(dx,dy);},insertDeflectionLength:function(deflection,length){var previousIndex=this.getCurrentPointIndex()-1;if(previousIndex>0){var p1=this.line.geometry.components[previousIndex];var p0=this.line.geometry.components[previousIndex-1];var theta=Math.atan2(p1.y-p0.y,p1.x-p0.x);this.insertDirectionLength((theta*180/Math.PI)+deflection,length);}},getCurrentPointIndex:function(){return this.line.geometry.components.length-1;},undo:function(){var geometry=this.line.geometry;var components=geometry.components;var index=this.getCurrentPointIndex()-1;var target=components[index];var undone=geometry.removeComponent(target);if(undone){if(!this.redoStack){this.redoStack=[];}
+return passes;},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:false,freehandToggle:'shiftKey',timerId:null,redoStack:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(force){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,force);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.la
 yer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack;},insertXY:function(x,y){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(x,y),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack;},insertDeltaXY:function(dx,dy){var previousIndex=this.getCurrentPointIndex()-1;var p0=this.line.geometry.components[previousIndex];if(p0&&!isNaN(p0.x)&&!isNaN(p0.y)){this.insertXY(p0.x+dx,p0.y+dy);}},insertDirectionLength:function(direction,length){direction*=Math.PI/180;var dx=len
 this.redoStack.push(target);this.drawFeature();}
 return undone;},redo:function(){var target=this.redoStack&&this.redoStack.pop();if(target){this.line.geometry.addComponent(target,this.getCurrentPointIndex());this.drawFeature();}
 return!!target;},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){if(!this.line){this.createFeature(pixel);}
-var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
+var lonlat=this.layer.getLonLatFromViewPortPx(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
 return geometry;},touchstart:function(evt){if(this.timerId&&this.passesTolerance(this.lastTouchPx,evt.xy,this.doubleTouchTolerance)){this.finishGeometry();window.clearTimeout(this.timerId);this.timerId=null;return false;}else{if(this.timerId){window.clearTimeout(this.timerId);this.timerId=null;}
-this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;}
+this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null;},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,evt);}},down:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;if(this.touch){this.modifyFeature(evt.xy,!!this.lastUp);OpenLayers.Event.stop(evt);}}
 if(!this.touch&&(!this.lastDown||!this.passesTolerance(this.lastDown,evt.xy,this.pixelTolerance))){this.modifyFeature(evt.xy,!!this.lastUp);}
 this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},move:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
 this.addPoint(evt.xy);return false;}
@@ -1288,7 +1273,7 @@
 if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
 this.addPoint(evt.xy);this.lastUp=evt.xy;if(this.line.geometry.components.length===this.maxVertices+1){this.finishGeometry();}}}}
 this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var featur
 es=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{silent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
+return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,createFeature:function(pixel){var lonlat=this.layer.getLonLatFromViewPortPx(pixel);var geometry=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);this.point=new OpenLayers.Feature.Vector(geometry);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features
 OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},getCurrentPointIndex:function(){return this.line.geometry.components.length-2;},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finishGeometry:function(){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
 if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
 if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
@@ -1324,16 +1309,18 @@
 var obj={};if(data){this.readNode(data,obj,true);}
 if(obj.features&&options.output==="features"){obj=obj.features;}
 return obj;},readers:{"wfs":{"FeatureCollection":function(node,obj){obj.features=[];this.readChildNodes(node,obj);}}},write:function(features,options){var node=this.writeNode("wfs:Transaction",{features:features,options:options});var value=this.schemaLocationAttr();if(value){this.setAttributeNS(node,this.namespaces["xsi"],"xsi:schemaLocation",value);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wfs":{"GetFeature":function(options){var node=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(options)}});if(typeof this.featureType=="string"){this.writeNode("Query",options,node);}else{for(var i=0,len=this.featureType.length;i<len;i++){options.featureType=this.featureType[i];this.writeNode("Query",options,node);}}
-return node;},"Transaction":function(obj){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var i,len;var features=obj&&obj.features;var options=obj&&obj.options;if(features){var name,feature;for(i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,feature,node);}}}
-if(options&&options.nativeElements){for(i=0,len=options.nativeElements.length;i<len;++i){this.writeNode("wfs:Native",options.nativeElements[i],node);}}
-return node;},"Native":function(nativeElement){var node=this.createElementNSPlus("wfs:Native",{attributes:{vendorId:nativeElement.vendorId,safeToIgnore:nativeElement.safeToIgnore},value:nativeElement.value});return node;},"Insert":function(feature){var node=this.createElementNSPlus("wfs:Insert");this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(feature){var node=this.createElementNSPlus("wfs:Update",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
+return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wfs":{"GetFeature":function(options){var node=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,handle:options&&options.handle,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(options)}});if(typeof this.featureType=="string"){this.writeNode("Query",options,node);}else{for(var i=0,len=this.featureType.length;i<len;i++){options.featureType=this.featureType[i];this.writeNode("Query",options,node);}}
+return node;},"Transaction":function(obj){obj=obj||{};var options=obj.options||{};var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,handle:options.handle}});var i,len;var features=obj.features;if(features){if(options.multi===true){OpenLayers.Util.extend(this.geometryTypes,{"OpenLayers.Geometry.Point":"MultiPoint","OpenLayers.Geometry.LineString":(this.multiCurve===true)?"MultiCurve":"MultiLineString","OpenLayers.Geometry.Polygon":(this.multiSurface===true)?"MultiSurface":"MultiPolygon"});}
+var name,feature;for(i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,{feature:feature,options:options},node);}}
+if(options.multi===true){this.setGeometryTypes();}}
+if(options.nativeElements){for(i=0,len=options.nativeElements.length;i<len;++i){this.writeNode("wfs:Native",options.nativeElements[i],node);}}
+return node;},"Native":function(nativeElement){var node=this.createElementNSPlus("wfs:Native",{attributes:{vendorId:nativeElement.vendorId,safeToIgnore:nativeElement.safeToIgnore},value:nativeElement.value});return node;},"Insert":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Insert",{attributes:{handle:options&&options.handle}});this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Update",{attributes:{handle:options&&options.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+
 this.featureType}});if(this.featureNS){node.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);}
-var modified=feature.modified;if(this.geometryName!==null&&(!modified||modified.geometry)){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
-for(var key in feature.attributes){if(feature.attributes[key]!==undefined&&(!modified||!modified.attributes||(modified.attributes&&modified.attributes[key]))){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
+var modified=feature.modified;if(this.geometryName!==null&&(!modified||modified.geometry!==undefined)){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
+for(var key in feature.attributes){if(feature.attributes[key]!==undefined&&(!modified||!modified.attributes||(modified.attributes&&modified.attributes[key]!==undefined))){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
 this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;},"Property":function(obj){var node=this.createElementNSPlus("wfs:Property");this.writeNode("Name",obj.name,node);if(obj.value!==null){this.writeNode("Value",obj.value,node);}
 return node;},"Name":function(name){return this.createElementNSPlus("wfs:Name",{value:name});},"Value":function(obj){var node;if(obj instanceof OpenLayers.Geometry){node=this.createElementNSPlus("wfs:Value");var geom=this.writeNode("feature:_geometry",obj).firstChild;node.appendChild(geom);}else{node=this.createElementNSPlus("wfs:Value",{value:obj});}
-return node;},"Delete":function(feature){var node=this.createElementNSPlus("wfs:Delete",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
+return node;},"Delete":function(obj){var feature=obj.feature;var options=obj.options;var node=this.createElementNSPlus("wfs:Delete",{attributes:{handle:options&&options.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+
 this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;}}},schemaLocationAttr:function(options){options=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},options);var schemaLocations=OpenLayers.Util.extend({},this.schemaLocations);if(options.schema){schemaLocations[options.featurePrefix]=options.schema;}
 var parts=[];var uri;for(var key in schemaLocations){uri=this.namespaces[key];if(uri){parts.push(uri+" "+schemaLocations[key]);}}
@@ -1346,9 +1333,9 @@
 return node;},"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("pos",geometry,node);return node;},"pos":function(point){var pos=(this.xy)?(point.x+" "+point.y):(point.y+" "+point.x);return this.createElementNSPlus("gml:pos",{value:pos});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("posList",geometry.components,node);return node;},"Curve":function(geometry){var node=this.createElementNSPlus("gml:Curve");this.writeNode("segments",geometry,node);return node;},"segments":function(geometry){var node=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",geometry,node);return node;},"LineStringSegment":function(geometry){var node=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",geometry.components,node);return node;},"posList":function(points){var len=points.length;var parts=new Array(len);var point;for(var i=0;i<len;++i){point=points[i];if
 (this.xy){parts[i]=point.x+" "+point.y;}else{parts[i]=point.y+" "+point.x;}}
 return this.createElementNSPlus("gml:posList",{value:parts.join(" ")});},"Surface":function(geometry){var node=this.createElementNSPlus("gml:Surface");this.writeNode("patches",geometry,node);return node;},"patches":function(geometry){var node=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",geometry,node);return node;},"PolygonPatch":function(geometry){var node=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
 return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
-return node;},"exterior":function(ring){var node=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",ring,node);return node;},"interior":function(ring){var node=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",ring.components,node);return node;},"MultiCurve":function(geometry){var node=this.createElementNSPlus("gml:MultiCurve");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("curveMember",geometry.components[i],node);}
+return node;},"exterior":function(ring){var node=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",ring,node);return node;},"interior":function(ring){var node=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",ring.components,node);return node;},"MultiCurve":function(geometry){var node=this.createElementNSPlus("gml:MultiCurve");var components=geometry.components||[geometry];for(var i=0,len=components.length;i<len;++i){this.writeNode("curveMember",components[i],node);}
 return node;},"curveMember":function(geometry){var node=this.createElementNSPlus("gml:curveMember");if(this.curve){this.writeNode("Curve",geometry,node);}else{this.writeNode("LineString",geometry,node);}
-return node;},"MultiSurface":function(geometry){var node=this.createElementNSPlus("gml:MultiSurface");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("surfaceMember",geometry.components[i],node);}
+return node;},"MultiSurface":function(geometry){var node=this.createElementNSPlus("gml:MultiSurface");var components=geometry.components||[geometry];for(var i=0,len=components.length;i<len;++i){this.writeNode("surfaceMember",components[i],node);}
 return node;},"surfaceMember":function(polygon){var node=this.createElementNSPlus("gml:surfaceMember");if(this.surface){this.writeNode("Surface",polygon,node);}else{this.writeNode("Polygon",polygon,node);}
 return node;},"Envelope":function(bounds){var node=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",bounds,node);this.writeNode("upperCorner",bounds,node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
 return node;},"lowerCorner":function(bounds){var pos=(this.xy)?(bounds.left+" "+bounds.bottom):(bounds.bottom+" "+bounds.left);return this.createElementNSPlus("gml:lowerCorner",{value:pos});},"upperCorner":function(bounds){var pos=(this.xy)?(bounds.right+" "+bounds.top):(bounds.top+" "+bounds.right);return this.createElementNSPlus("gml:upperCorner",{value:pos});}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":(this.curve===true)?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":(this.multiCurve===false)?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":(this.surface===true)?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":(this.multiSurface===false)?"MultiPoly
 gon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.v3"});OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,
 filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escapeChar");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:filter.matchCase}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",{attributes:{matchCase:filter.matchCa
 se}});this.writeNode("PropertyName",filter,node);this.writeOgcExpression(filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:filter.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");filter.property&&this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Envelope",filter.value);if(filter.projection){box.setAttribute("srsName",filter.projection);}
@@ -1360,7 +1347,7 @@
 options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+prefix,options.featureNS);}
 if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
 if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,"abstract":layer.metadata["abstract"],dataURL:layer.metadata.dataURL,metadataURL:layer.metadataURL,server:{version:layer.params["VERSION"],url:layer.url},maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity,
 displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[],styles:[],srs:layer.srs,dimensions:layer.dimensions};if(layer.metadata.servertitle){layerContext.server.title=layer.metadata.servertitle;}
+return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,"abstract":layer.metadata["abstract"],dataURL:layer.metadata.dataURL,metadataURL:layer.metadataURL,server:{version:layer.params["VERSION"],url:layer.url},maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity=
 =1?undefined:layer.opacity,displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[],styles:[],srs:layer.srs,dimensions:layer.dimensions};if(layer.metadata.servertitle){layerContext.server.title=layer.metadata.servertitle;}
 if(layer.metadata.formats&&layer.metadata.formats.length>0){for(var i=0,len=layer.metadata.formats.length;i<len;i++){var format=layer.metadata.formats[i];layerContext.formats.push({value:format.value,current:(format.value==layer.params["FORMAT"])});}}else{layerContext.formats.push({value:layer.params["FORMAT"],current:true});}
 if(layer.metadata.styles&&layer.metadata.styles.length>0){for(var i=0,len=layer.metadata.styles.length;i<len;i++){var style=layer.metadata.styles[i];if((style.href==layer.params["SLD"])||(style.body==layer.params["SLD_BODY"])||(style.name==layer.params["STYLES"])){style.current=true;}else{style.current=false;}
 layerContext.styles.push(style);}}else{layerContext.styles.push({href:layer.params["SLD"],body:layer.params["SLD_BODY"],name:layer.params["STYLES"]||parser.defaultStyleName,title:parser.defaultStyleTitle,current:true});}
@@ -1455,7 +1442,7 @@
 var scope=this;OpenLayers.loadURL(resUrl,{},scope,function(response){if(response.statusText=="OK"&&response.status==200){t.ok(true,"...execute check result status...");}else{t.ok(false,"...execute check result status...");}
 var allResponesHeaders=response.getAllResponseHeaders();if(allResponesHeaders.indexOf(refMimeType)!=-1){t.ok(true,"...execute check result header content type...");}else{t.ok(false,"...execute check result header content type...");}
 if(resRefUrl&&resRefUrl!=""){OpenLayers.loadURL(resRefUrl,null,this,function(reference){t.html_eq(this._stripXmlDeclaration(response.responseText),reference.responseText,"...execute check result...");});}},function(response){t.ok(false,"...async execute check result...");});});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postReqXmlStr});},_verify_features_number:function(reqParams,featureType,expectedNumOfFeatures,t){var caller=this;OpenLayers.Request.GET({url:this.url,params:reqParams,success:function(response){var result_parser=new OpenLayers.Format.WFSTWithLock({version:"1.1.0",featureType:featureType,geometryName:"Shape",featureNS:"http://www.esri.com",featurePrefix:"esri",extractAttributes:false});var features=result_parser.read(response.responseXML);t.eq(features.length,expectedNumOfFeatures,"...verify features number...");},failure:function(response){t.ok(false,"......");},scope:caller});},_run_wfst_post_:function(lockReqId,lockResUrl,
 transactionReqId,transactionResUrl,t){var postLockReqXmlStr=document.getElementById(lockReqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(lockResponse){var lockId=lockResponse.responseXML.firstChild.getAttribute("lockId");if((!lockId)||lockId==""){t.ok(false,"...test failed...null or invalid lockId");}else{t.ok(true,"...test succeeded...valid lockId retrieved...");}
-var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var xmlFormat=new OpenLayers.Format.XML({namespaces:{'wfs':"http://www.opengis.net/wfs"}});var postTransReqXmlDom=xmlFormat.read(postTransReqXmlStr);var lockIdNode=xmlFormat.createElementNSPlus("wfs:LockId",{'value':lockId});postTransReqXmlDom.firstChild.insertBefore(lockIdNode,postTransReqXmlDom.firstChild.firstChild);var postTransReqLockIdXmlStr=xmlFormat.write(postTransReqXmlDom);var innerCaller=caller;OpenLayers.Request.POST({url:caller.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,innerCaller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqLockIdXmlStr});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postLockReqXmlStr});},_stripXmlDeclaration:function(x
 mlStr){var idx_l=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");var idx_u=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");if(idx_l>=0||idx_u>=0){OpenLayers.Console.debug("..."+xmlStr.substring(39,xmlStr.length-1));return xmlStr.substring(39,xmlStr.length-1);}else{OpenLayers.Console.debug(xmlStr);return xmlStr;}},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.f
 ilterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
+var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var xmlFormat=new OpenLayers.Format.XML({namespaces:{'wfs':"http://www.opengis.net/wfs"}});var postTransReqXmlDom=xmlFormat.read(postTransReqXmlStr);var lockIdNode=xmlFormat.createElementNSPlus("wfs:LockId",{'value':lockId});postTransReqXmlDom.firstChild.insertBefore(lockIdNode,postTransReqXmlDom.firstChild.firstChild);var postTransReqLockIdXmlStr=xmlFormat.write(postTransReqXmlDom);var innerCaller=caller;OpenLayers.Request.POST({url:caller.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,innerCaller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqLockIdXmlStr});},failure:function(response){t.ok(false,"......");},params:{},headers:{},data:postLockReqXmlStr});},_run_wfst_post_without_locks:fu
 nction(transactionReqId,transactionResUrl,t){var postTransReqXmlStr=document.getElementById(transactionReqId).firstChild.nodeValue;var caller=this;OpenLayers.Request.POST({url:this.url,success:function(transResponse){OpenLayers.loadURL(transactionResUrl,null,caller,function(transReference){t.html_eq(this._stripXmlDeclaration(transResponse.responseText),transReference.responseText,"...");});},failure:function(transResponse){t.ok(false,"......");},params:{},headers:{},data:postTransReqXmlStr});},_stripXmlDeclaration:function(xmlStr){var idx_l=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"utf-8\" ?>");var idx_u=xmlStr.indexOf("<?xml version=\"1.0\" encoding=\"UTF-8\"?>");if(idx_l>=0||idx_u>=0){OpenLayers.Console.debug("..."+xmlStr.substring(39,xmlStr.length-1));return xmlStr.substring(39,xmlStr.length-1);}else{OpenLayers.Console.debug(xmlStr);return xmlStr;}},CLASS_NAME:"OpenLayers.Test.AgsOgcRegression"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{font
 StyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist
 OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},parseEnvelope:function(env,arr){if(arr&&arr.length==4){env.minx=arr[0];env.miny=arr[1];env.maxx=arr[2];env.maxy=arr[3];}},addLayers:function(ll,lyrs){for(var lind=0,len=lyrs.length;lind<len;lind++){ll.push(lyrs[lind]);}},addImageSize:function(imsize,olsize){if(olsize!==null){imsize.width=olsize.w;imsize.height=olsize.h;imsize.printwidth=olsize.w;imsize.printheight=olsize.h;}},addCoordSys:function(featOrFilt,fsys){if(typeof fsys=="string"){featOrFilt.id=parseInt(fsys);featOrFilt.string=fsys;}
 else if(typeof fsys=="object"&&fsys.proj!==null){featOrFilt.id=fsys.proj.srsProjNumber;featOrFilt.string=fsys.proj.srsCode;}else{featOrFilt=fsys;}},iserror:function(data){var ret=null;if(!data){ret=(this.response.error!=='');}else{data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);var errorNodes=data.documentElement.getElementsByTagName("ERROR");ret=(errorNodes!==null&&errorNodes.length>0);}
 return ret;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
@@ -1540,7 +1527,7 @@
 point=null;}
 return new OpenLayers.Geometry.LinearRing(ringPoints);},CLASS_NAME:"OpenLayers.Format.ArcXML"});OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(params){var defaults={get_image:{properties:{background:null,draw:true,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:false},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:false,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]};return O
 penLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(params){var defaults={image:{envelope:null,output:''},features:{featurecount:0,envelope:null,feature:[]},error:''};return OpenLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:''},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:true,name:"ArcIMS",isBaseLayer:true,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:true,async:true,name:"ArcIMS"},initialize:function(name,url,options){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:options.serviceName},this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(options,this.D
 EFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,this.params,options]);if(this.transparent){if(!this.isBaseLayer){this.isBaseLayer=false;}
 if(this.format=="image/jpeg"){this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}
-if(this.options.layers===null){this.options.layers=[];}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},getURL:function(bounds){var url="";bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));var req=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:axlReq.write(),async:false});if(req!=null){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
+if(this.options.layers===null){this.options.layers=[];}},getURL:function(bounds){var url="";bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));var req=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:axlReq.write(),async:false});if(req!=null){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
 var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);url=this.getUrlOrImage(arcxml.image.output);}
 return url;},getURLasync:function(bounds,scope,prop,callback){bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));OpenLayers.Request.POST({url:this.getFullRequestString(),async:true,data:axlReq.write(),callback:function(req){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
 var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);scope[prop]=this.getUrlOrImage(arcxml.image.output);callback.apply(scope);},scope:this});},getUrlOrImage:function(output){var ret="";if(output.url){ret=output.url;}else if(output.data){ret="data:image/"+output.type+";base64,"+output.data;}
@@ -1548,18 +1535,7 @@
 this.options.layers.push({id:id,visible:true,query:querydef});},getFeatureInfo:function(geometry,layer,options){var buffer=options.buffer||1;var callback=options.callback||function(){};var scope=options.scope||window;var requestOptions={};OpenLayers.Util.extend(requestOptions,this.options);requestOptions.requesttype="feature";if(geometry instanceof OpenLayers.LonLat){requestOptions.polygon=null;requestOptions.envelope=[geometry.lon-buffer,geometry.lat-buffer,geometry.lon+buffer,geometry.lat+buffer];}else if(geometry instanceof OpenLayers.Geometry.Polygon){requestOptions.envelope=null;requestOptions.polygon=geometry;}
 var arcxml=new OpenLayers.Format.ArcXML(requestOptions);OpenLayers.Util.extend(arcxml.request.get_feature,options);arcxml.request.get_feature.layer=layer.id;if(typeof layer.query.accuracy=="number"){arcxml.request.get_feature.query.accuracy=layer.query.accuracy;}else{var mapCenter=this.map.getCenter();var viewPx=this.map.getViewPortPxFromLonLat(mapCenter);viewPx.x++;var mapOffCenter=this.map.getLonLatFromPixel(viewPx);arcxml.request.get_feature.query.accuracy=mapOffCenter.lon-mapCenter.lon;}
 arcxml.request.get_feature.query.where=layer.query.where;arcxml.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({'CustomService':'Query'}),data:arcxml.write(),callback:function(request){var response=arcxml.parseResponse(request.responseText);if(!arcxml.iserror()){callback.call(scope,response.features);}else{callback.call(scope,null);}}});},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
-return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
-var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
-return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};var j;var jlen=featureNode.attributes.length;if(jlen>0){for(j=0;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}}else{var nodes=featureNode.childNodes;for(j=0,jlen=nodes.length;j<jlen;++j){var node=nodes[j];if(node.nodeType!=3){attributes[node.getAttribute("name")]=node.getAttribute("value");}}}
-response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
-return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
-tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
-return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;if(grandchildren.length==0){attributes[name]=null}else if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
-var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
-return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
 return false;},deactivate:function(){if(this.active){this.active=false;return true;}
 return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:false,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.cache=[];this.layer.events.on({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
 return activated;},deactivate:function(){this.cache=null;if(this.layer&&this.layer.events){this.layer.events.un({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
@@ -1568,7 +1544,7 @@
 OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions());}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
 OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);this.addTileMonitoringHooks(this.tile);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
-this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){this.events.triggerEvent("loadstart");};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.events.triggerEvent("loadend");};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Process=OpenLayers.Class({events:null,eventListeners:null,EVENT_TYPES:["beforeprocessstart","processstarted","process
 succeeded","processfailed","afterprocesscompleted"],initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}},CLASS_NAME:"OpenLayers.Process"});OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{extractWaypoints:true,extractTracks:true,extractRoutes:true,extractAttributes:true,initialize:function(options){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){this.events.triggerEvent("loadstart");};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.events.triggerEvent("loadend");};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Process=OpenLayers.Class({events:null,eventListeners:null,EVENT_TYPES:["beforeprocessstart","processstarted","process
 succeeded","processfailed","afterprocesscompleted"],initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}},CLASS_NAME:"OpenLayers.Process"});OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{defaultDesc:"No description available",extractWaypoints:true,extractTracks:true,extractRoutes:true,extractAttributes:true,gpxns:"http://www.topografix.com/GPX/1/1",initialize:function(options){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
 var features=[];if(this.extractTracks){var tracks=doc.getElementsByTagName("trk");for(var i=0,len=tracks.length;i<len;i++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(tracks[i]);}
 var segs=this.getElementsByTagNameNS(tracks[i],tracks[i].namespaceURI,"trkseg");for(var j=0,seglen=segs.length;j<seglen;j++){var track=this.extractSegment(segs[j],"trkpt");features.push(new OpenLayers.Feature.Vector(track,attrs));}}}
 if(this.extractRoutes){var routes=doc.getElementsByTagName("rte");for(var k=0,klen=routes.length;k<klen;k++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(routes[k]);}
@@ -1579,7 +1555,14 @@
 return features;},extractSegment:function(segment,segmentType){var points=this.getElementsByTagNameNS(segment,segment.namespaceURI,segmentType);var point_features=[];for(var i=0,len=points.length;i<len;i++){point_features.push(new OpenLayers.Geometry.Point(points[i].getAttribute("lon"),points[i].getAttribute("lat")));}
 return new OpenLayers.Geometry.LineString(point_features);},parseAttributes:function(node){var attributes={};var attrNode=node.firstChild,value,name;while(attrNode){if(attrNode.nodeType==1){value=attrNode.firstChild;if(value.nodeType==3||value.nodeType==4){name=(attrNode.prefix)?attrNode.nodeName.split(":")[1]:attrNode.nodeName;if(name!="trkseg"&&name!="rtept"){attributes[name]=value.nodeValue;}}}
 attrNode=attrNode.nextSibling;}
-return attributes;},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Util.AgsUtil=(function(){return function(){}})();OpenLayers.Util.AgsUtil.isDefined=function(value){if(value===undefined||value===null||value===""){return false;}
+return attributes;},write:function(features,metadata){var gpx;features=OpenLayers.Util.isArray(features)?features:[features];gpx=this.createElementNS(this.gpxns,"gpx");for(var i=0,len=features.length;i<len;i++){gpx.appendChild(this.buildFeatureNode(features[i]));}
+if(metadata&&typeof metadata=='object'){gpx.appendChild(this.buildMetadataNode(metadata));}
+return OpenLayers.Format.XML.prototype.write.apply(this,[gpx]);},buildMetadataNode:function(metadata){var types=['name','desc','author'],node=this.createElementNS(this.gpxns,'metadata');for(var i=0;i<types.length;i++){var type=types[i];if(metadata[type]){var n=this.createElementNS(this.gpxns,type);n.appendChild(this.createTextNode(metadata[type]));node.appendChild(n);}}
+return node;},buildFeatureNode:function(feature){var geometry=feature.geometry;geometry=geometry.clone();if(this.internalProjection&&this.externalProjection){geometry.transform(this.internalProjection,this.externalProjection);}
+if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){var wpt=this.buildWptNode(feature);return wpt;}else{var trkNode=this.createElementNS(this.gpxns,"trk");this.appendAttributesNode(trkNode,feature);var trkSegNodes=this.buildTrkSegNode(geometry);trkSegNodes=OpenLayers.Util.isArray(trkSegNodes)?trkSegNodes:[trkSegNodes];for(var i=0,len=trkSegNodes.length;i<len;i++){trkNode.appendChild(trkSegNodes[i]);}
+return trkNode;}},buildTrkSegNode:function(geometry){var node,i,len,point,nodes;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){node=this.createElementNS(this.gpxns,"trkseg");for(i=0,len=geometry.components.length;i<len;i++){point=geometry.components[i];node.appendChild(this.buildTrkPtNode(point));}
+return node;}else{nodes=[];for(i=0,len=geometry.components.length;i<len;i++){nodes.push(this.buildTrkSegNode(geometry.components[i]));}
+return nodes;}},buildTrkPtNode:function(point){var node=this.createElementNS(this.gpxns,"trkpt");node.setAttribute("lon",point.x);node.setAttribute("lat",point.y);return node;},buildWptNode:function(feature){var node=this.createElementNS(this.gpxns,"wpt");node.setAttribute("lon",feature.geometry.x);node.setAttribute("lat",feature.geometry.y);this.appendAttributesNode(node,feature);return node;},appendAttributesNode:function(node,feature){var name=this.createElementNS(this.gpxns,'name');name.appendChild(this.createTextNode(feature.attributes.name||feature.id));node.appendChild(name);var desc=this.createElementNS(this.gpxns,'desc');desc.appendChild(this.createTextNode(feature.attributes.description||this.defaultDesc));node.appendChild(desc);},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Util.AgsUtil=(function(){return function(){}})();OpenLayers.Util.AgsUtil.isDefined=function(value){if(value===undefined||value===null||value===""){return false;}
 else{return true;}};OpenLayers.Util.AgsUtil.isNumber=function(value){if(value===undefined||value===null||value===""){return false;}else if(typeof value==="number"){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isBoolean=function(value){if(value===undefined||value===null||value===""){return false;}else if(typeof value==="boolean"){return true;}
 else{return false;}};OpenLayers.Util.AgsUtil.isAgsGeometry=function(value){if(value===undefined||value===null||value===""){return false;}else if(value instanceof esri.geometry.Point){return true;}else if(value instanceof esri.geometry.Polyline){return true;}else if(value instanceof esri.geometry.Polygon){return true;}else if(value instanceof esri.geometry.Extent){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isOLGeometry=function(value){if(value===undefined||value===null||value===""){return false;}else if(value instanceof OpenLayers.Geometry.Point){return true;}else if(value instanceof OpenLayers.Geometry.LineString){return true;}else if(value instanceof OpenLayers.Geometry.LinearRing){return true;}else if(value instanceof OpenLayers.Geometry.MultiLineString){return true;}else if(value instanceof OpenLayers.Geometry.MultiPoint){return true;}else if(value instanceof OpenLayers.Geometry.MultiPolygon){return true;}else if(value instanceof OpenLayers.Geometry.Polygon
 ){return true;}else if(value instanceof OpenLayers.Bounds){return true;}else{return false;}};OpenLayers.Util.AgsUtil.isSameOLPoint=function(point1,point2){if(typeof point1.x==="number"&&typeof point1.y==="number"&&typeof point2.x==="number"&&typeof point2.y==="number"){if(point1.x==point2.x&&point1.y==point2.y){return true;}}
 return false;};OpenLayers.Util.AgsUtil.dispatch=function(functions,complete,scope){var requests=functions.length;var responses=0;var storage={};function respond(){++responses;if(responses===requests){complete.call(scope,storage);}}
@@ -1598,7 +1581,7 @@
 return rendered;}}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
 for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
 if(symbolizer.fill===false){delete result.fillColor;}
-OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;
 root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);rendered=(style.display!=="none")&&feature.geometry.getBounds().intersectsBounds(this.extent);if(rendered){this.features[feature.id]=[feature,style];}
+OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;
 root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolution=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);var bounds=feature.geometry.getBounds();rendered=(style.display!=="none")&&!!bounds&&bounds.intersectsBounds(this.extent);if(rendered){this.features[feature.id]=[feature,style];}
 else{delete(this.features[feature.id]);}
 this.pendingRedraw=true;}
 if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
@@ -1680,14 +1663,14 @@
 return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
 Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.touch=false;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
-return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={d
 rag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deact
 ivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
+return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={d
 rag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},clickFeature:function(feature){if(this.handlers.feature.touch&&!this.over&&this.overFeature(feature)){this.handlers.drag.dragstart(this.handlers.feature.evt);this.handlers.drag.stopDown=false;}},clickoutFeature:function(feature){if(this.handlers.feature.touch&&this.over){this.outFeature(feature);this.handlers.drag.stopDown=true;}},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,ar
 guments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){var activated=false;if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();activated=true;this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}
 return activated;},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},
 CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style
 );this.styles["delete"]=new OpenLayers.Style(style);break;}}}
 OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
 this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
 if(!this.styles[intent]){intent="default";}
 feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
 return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","vertexremoved","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply
 (this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
 if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
 if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
 this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
@@ -1697,7 +1680,7 @@
 this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
 this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
-obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var ng=(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG);if(ng){zoomChanged&&this.renderer.updateDimensions();}else{var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenLayers.IS
 _GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
+obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var ng=(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG);if(ng){dragging||this.renderer.updateDimensions(zoomChanged);}else{var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenL
 ayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
 if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}}
 if(!this.drawn||(!ng&&(zoomChanged||!coordSysUnchanged))){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},redraw:function(){if(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG){this.drawn=false;}
 return OpenLayers.Layer.prototype.redraw.apply(this,arguments);},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
@@ -1706,7 +1689,8 @@
 var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
 var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
 feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;};this.preFeatureInsert(feature);}
+if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;}
+this.preFeatureInsert(feature);}
 featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
 if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
 if(features===this.features){return this.removeAllFeatures(options);}
@@ -1725,12 +1709,13 @@
 if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
 if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
 var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-var drawn=this.renderer.drawFeature(feature,style);if(drawn===false||drawn===null){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];};},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
+var drawn=this.renderer.drawFeature(feature,style);if(drawn===false||drawn===null){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];}},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
 var feature=null;var featureId=this.renderer.getFeatureIdFromEvent(evt);if(featureId){if(typeof featureId==="string"){feature=this.getFeatureById(featureId);}else{feature=featureId;}}
 return feature;},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
 return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
-return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){maxExtent=new OpenLayers.Bounds();var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){maxExtent.extend(geometry.getBounds());}}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer
 .moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeaturehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.Select
 Feature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
+return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){if(maxExtent===null){maxExtent=new OpenLayers.Bounds();}
+maxExtent.extend(geometry.getBounds());}}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){laye
 r=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
 this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
 this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
@@ -1768,13 +1753,13 @@
 if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
 if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
 if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component,l
 en;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
+if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.modified=true;this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i
 ,vertex,component,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
 for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
 if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
 collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
 penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
 if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
 geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338
 ,0.07464553542435169],attributionTemplate:'<span class="olBingAttribution ${type}">'+'<div><a target="_blank" href="http://www.bing.com/maps/">'+'<img src="${logo}" /></a></div>${copyrights}'+'<a style="white-space: nowrap" target="_blank" '+'href="http://www.microsoft.com/maps/product/terms.html">'+'Terms of Use</a></span>',metadata:null,type:"Road",metadataParams:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({sphericalMercator:true},options);var name=options.name||"Bing "+(options.type||this.type);var newArgs=[name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);this.loadMetadata();},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var params=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams);var url="http://dev.virtualearth.net/RES
 T/v1/Imagery/Metadata/"+
-this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({maxResolution:Math.min(this.serverResolutions[res.zoomMin],this.maxResolution),zoomOffset:res.zoomMin,numZoomLevels:Math.min(res.zoomMax+1-res.zoomMin,this.numZoomLevels)},true);},getURL:function(bounds){if(!this.url){return OpenLayers.Util.getImagesLocation()+"blank.gif";}
+this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({maxResolution:Math.min(this.serverResolutions[res.zoomMin],this.maxResolution),zoomOffset:res.zoomMin,numZoomLevels:Math.min(res.zoomMax+1-res.zoomMin,this.numZoomLevels)},true);},getURL:function(bounds){if(!this.url){return;}
 var xyz=this.getXYZ(bounds),x=xyz.x,y=xyz.y,z=xyz.z;var quadDigits=[];for(var i=z;i>0;--i){var digit='0';var mask=1<<(i-1);if((x&mask)!=0){digit++;}
 if((y&mask)!=0){digit++;digit++;}
 quadDigits.push(digit);}
@@ -1851,7 +1836,7 @@
 href+=separator+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element){window.location.href=href;}
 else{this.element.href=href;}},createParams:function(center,zoom,layers){center=center||this.map.getCenter();var params=OpenLayers.Util.getParameters(this.base);if(center){params.zoom=zoom||this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
 params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;layers=layers||this.map.layers;params.layers='';for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}}
-return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
+return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
 return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Protocol.AgsFeatureAccess=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS);var cls=OpenLayers.Protocol.AgsFeatureAccess["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported AgsFeatureAccess version: "+options.version;}
 return new cls(options);};OpenLayers.Protocol.AgsFeatureAccess.DEFAULTS={"version":"2.0"};OpenLayers.Format.AgsJsAdapter=(function(){var _AGS_UNITS={'UNIT_METER':9001,'UNIT_FOOT':9002,'UNIT_KILOMETER':9036,'UNIT_DEGREE':9102};var _AGS_SPATIALRELATIONSHIP={'INTERSECTS':"esriSpatialRelIntersects",'CONTAINS':"esriSpatialRelContains",'CROSSES':"esriSpatialRelCrosses",'ENVELOPE_INTERSECTS':"esriSpatialRelEnvelopeIntersects",'INDEX_INTERSECTS':"esriSpatialRelIndexIntersects",'OVERLAPS':"esriSpatialRelOverlaps",'TOUCHES':"esriSpatialRelTouches",'WITHIN':"esriSpatialRelWithin"};var _AGS_GEOMETRY_SPATIALRELATIONSHIP={'CROSS':"esriGeometryRelationCross",'DISJOINT':"esriGeometryRelationDisjoint",'IN':"esriGeometryRelationIn",'INTERIOR_INTERSECTION':"esriGeometryRelationInteriorIntersection",'INTERSECTION':"esriGeometryRelationIntersection",'LINE_COINCIDENCE':"esriGeometryRelationLineCoincidence",'LINE_TOUCHE':"esriGeometryRelationLineTouch",'OVERLAP':"esriGeometryRelationOverlap",'POIN
 T_TOUCH':"esriGeometryRelationPointTouch",'RELATION':"esriGeometryRelationRelation",'TOUCH':"esriGeometryRelationTouch",'WITHIN':"esriGeometryRelationWithin",};var _UNMATCH_AGS_WKID={'900913':"102113"};var _UNMATCH_OL_WKID={'102113':"900913"};var _OL_GEOMETRY_MAP={'OpenLayers.Geometry.Point':"point",'OpenLayers.Geometry.MultiLineString':"polyline",'OpenLayers.Geometry.LineString':"polyline",'OpenLayers.Geometry.MultiPolygon':"polygon",'OpenLayers.Geometry.Polygon':"polygon",'OpenLayers.Bounds':"extent"};var _AGS_OL_RENDERER_PARSER_MAP={'esri.renderer.SimpleRenderer':"SimpleRenderer",'esri.renderer.ClassBreaksRenderer':"ClassBreaksRenderer",'esri.renderer.UniqueValueRenderer':"UniqueValueRenderer"};var _OL_AGS_STYLE_MAP={'OpenLayers.Geometry.Point':"SimpleMarkerSymbol",'OpenLayers.Geometry.MultiLineString':"SimpleLineSymbol",'OpenLayers.Geometry.Polygon':"SimpleFillSymbol",'OpenLayers.Bounds':"SimpleFillSymbol",'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"
 PictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimleFillSymbol",'picturefillsymbol':"PictureFillSymbol",};var _AGS_OL_SYMBOL_PARSER_MAP={'simplemarkersymbol':"SimpleMarkerSymbol",'picturemarkersymbol':"PictureMarkerSymbol",'simplelinesymbol':"SimpleLineSymbol",'cartographiclinesymbol':"CartographicLineSymbol",'simplefillsymbol':"SimpleFillSymbol",'picturefillsymbol':"PictureFillSymbol"};var _OL_AGS_SIMPLE_MARKERSYMBOL_MAP={'circle':"STYLE_CIRCLE",'cross':"STYLE_CROSS",'diamond':"STYLE_DIAMOND",'square':"STYLE_SQUARE",'x':"STYLE_X"};var _AGS_OL_SIMPLE_MARKERSYMBOL_MAP={'STYLE_CIRCLE':"circle",'STYLE_CROSS':"cross",'STYLE_DIAMOND':"diamond",'STYLE_SQUARE':"square",'STYLE_X':"x"};var _OL_AGS_SIMPLE_LINESYMBOL_MAP={'dash':"STYLE_DASH",'dashdot':"STYLE_DASHDOT",'longdashdot':"STYLE_DASHDOTDOT",'dot':"STYLE_DOT",'solid':"STYLE_NULL",'solid':"STYLE_SOLID"};var _AGS_OL_SIMPLE_LINESYMBOL_MAP={'STYLE_DAS
 H':"dash",'STYLE_DASHDOT':"dashdot",'STYLE_DASHDOTDOT':"longdashdot",'STYLE_DOT':"dot",'STYLE_NULL':"solid",'STYLE_SOLID':"solid"};var _OL_AGS_NAUTURN_MAP={'ALLOW_BACKTRACK':"allow_backtrack",'AT_DEAD_ENDS_ONLY':"at_dead_ends_only",'NO_BACKTRACK':"no_backtrack"};var _AGS_OL_NAUTURN_MAP={'allow_backtrack':"ALLOW_BACKTRACK",'at_dead_ends_only':"AT_DEAD_ENDS_ONLY",'no_backtrack':"NO_BACKTRACK"};var _OL_AGS_NAOUTPUTLINE_MAP={'NONE':"none",'STRAIGHT':"straight",'TRUE_SHAPE':"true_shape",'TRUE_SHAPE_WITH_MEASURE':"true_shape_with_measure"};var _AGS_OL_NAOUTPUTLINE_MAP={'none':"NONE",'straight':"STRAIGHT",'true_shape':"TRUE_SHAPE",'true_shape_with_measure':"TRUE_SHAPE_WITH_MEASURE"};var _OL_ROUTETASK_STYLE={'route':{strokeColor:"#00FF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",},'stop':{fillColor:"#FFFF00",fillOpacity:1,strokeColor:"#FF0000",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10,},'barrier':{fi
 llColor:"#FF0000",fillOpacity:1,strokeColor:"#FFFF00",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",pointRadius:10,}};var _isDefined=OpenLayers.Util.AgsUtil.isDefined;var _isNumber=OpenLayers.Util.AgsUtil.isNumber;var _isBoolean=OpenLayers.Util.AgsUtil.isBoolean;var _isAgsGeometry=OpenLayers.Util.AgsUtil.isAgsGeometry;var _isOLGeometry=OpenLayers.Util.AgsUtil.isOLGeometry;var _isSameOLPoint=OpenLayers.Util.AgsUtil.isSameOLPoint;function _toAgsWkid(olWkid){if(_isDefined(_UNMATCH_AGS_WKID[olWkid])){return _UNMATCH_AGS_WKID[olWkid];}else{return olWkid;}};function _toOlWkid(agsWkid){if(_isDefined(_UNMATCH_OL_WKID[agsWkid])){return _UNMATCH_OL_WKID[agsWkid];}else{return agsWkid;}};function __bindFunction(func,scope){if(window.dojo!==undefined){return dojo.hitch(scope,func);}else{OpenLayers.Console.log("...dojo not found...use OpenLayers.Function.bind() to bind function to scope...");return OpenLayers.Function.bind(func,scope);}}
@@ -1861,11 +1846,11 @@
 olLinearRing=new OpenLayers.Geometry.LinearRing(olLineString.components);return olLinearRing;},"polyline":function(agsPolyline){var olMultiLineString=null;if(_isDefined(agsPolyline.paths)&&agsPolyline.paths instanceof Array){var paths=agsPolyline.paths;var lineStrings=[];for(var i=0;i<paths.length;i++){try{var lineString=this.parseAgsGeometry['path'].apply(this,[paths[i]]);lineStrings.push(lineString);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
 olMultiLineString=new OpenLayers.Geometry.MultiLineString(lineStrings);return olMultiLineString;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline...");throw"...AgsAdapter.parseAgsGeometry.polyline...invalid esri.geometry.Polyline..."+agsPolyline;}},"polygon":function(agsPolygon){var olPolygon=null;if(_isDefined(agsPolygon.rings)&&agsPolygon.rings instanceof Array){var rings=agsPolygon.rings;var linearRings=[];for(var i=0;i<rings.length;i++){try{var linearRing=this.parseAgsGeometry['ring'].apply(this,[rings[i]]);linearRings.push(linearRing);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
 olPolygon=new OpenLayers.Geometry.Polygon(linearRings);return olPolygon;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon...");throw"...AgsAdapter.parseAgsGeometry.polygon...invalid esri.geometry.Polygon..."+agsPolygon;}},"multipoint":function(agsMultipoint){var olPoints=[];if(_isDefined(agsMultipoint.points)&&agsMultipoint.points instanceof Array){var agsPoints=agsMultipoint.points;for(var i=0;i<agsPoints.length;i++){try{var olPoint=this.parseAgsGeometry['coordinate'].apply(this,[agsPoints[i]]);olPoints.push(olPoint);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
-return olPoints;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint...");throw"...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint..."+agsPolygon;}},"extent":function(agsExtent){var olBounds=null;if(_isDefined(agsExtent.xmin)&&_isDefined(agsExtent.xmax)&&_isDefined(agsExtent.ymin)&&_isDefined(agsExtent.ymax)){olBounds=new OpenLayers.Bounds(agsExtent.xmin,agsExtent.ymin,agsExtent.xmax,agsExtent.ymax);return olBounds;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent...");throw"...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent..."+agsExtent;}}};this.parseAgsSymbol={"SimpleMarkerSymbol":function(agsSimpleMarkerSymbol){if(_isDefined(agsSimpleMarkerSymbol)&&agsSimpleMarkerSymbol instanceof esri.symbol.SimpleMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.strokeColor=agsSimpleMarkerSymbol.outlin
 e.color.toHex()||pointSymbolizer.strokeColor;pointSymbolizer.strokeWidth=agsSimpleMarkerSymbol.outline.width||pointSymbolizer.strokeWidth;pointSymbolizer.strokeOpacity=agsSimpleMarkerSymbol.outline.color.toRgba()[3]||pointSymbolizer.strokeOpacity;pointSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleMarkerSymbol.outline.style]||pointSymbolizer.strokeDashstyle;pointSymbolizer.fillColor=agsSimpleMarkerSymbol.color.toHex()||pointSymbolizer.fillColor;pointSymbolizer.fillOpacity=agsSimpleMarkerSymbol.color.toRgba()[3]||pointSymbolizer.fillOpacity;pointSymbolizer.pointRadius=agsSimpleMarkerSymbol.size||pointSymbolizer.pointRadius;pointSymbolizer.graphicName=_AGS_OL_SIMPLE_MARKERSYMBOL_MAP[agsSimpleMarkerSymbol.style]||pointSymbolizer.graphicName;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid
  SimpleMarkerSymbol..."+agsSimpleMarkerSymbol;}},"PictureMarkerSymbol":function(agsPictureMarkerSymbol){if(_isDefined(agsPictureMarkerSymbol)&&agsPictureMarkerSymbol instanceof esri.symbol.PictureMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.pointRadius=agsPictureMarkerSymbol.size||pointSymbolizer.pointRadius;pointSymbolizer.externalGraphic=agsPictureMarkerSymbol.url||pointSymbolizer.externalGraphic;pointSymbolizer.graphicWidth=agsPictureMarkerSymbol.width||pointSymbolizer.graphicWidth;pointSymbolizer.graphicHeight=agsPictureMarkerSymbol.height||pointSymbolizer.graphicHeight;pointSymbolizer.graphicXOffset=agsPictureMarkerSymbol.xoffset||pointSymbolizer.graphicXOffset;pointSymbolizer.graphicYOffset=agsPictureMarkerSymbol.yoffset||pointSymbolizer.graphicYOffset;pointSymbolizer.rotation=agsPictureMarkerSymbol.angle||pointSymbolizer.rotation;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSym
 bol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSimpleMarkerSymbol;}},"SimpleLineSymbol":function(agsSimpleLineSymbol){if(_isDefined(agsSimpleLineSymbol)&&agsSimpleLineSymbol instanceof esri.symbol.SimpleLineSymbol){var lineSymbolizer=new OpenLayers.Symbolizer.Line({});lineSymbolizer.strokeColor=agsSimpleLineSymbol.color.toHex()||lineSymbolizer.strokeColor;lineSymbolizer.strokeWidth=agsSimpleLineSymbol.width||lineSymbolizer.strokeWidth;lineSymbolizer.strokeOpacity=agsSimpleLineSymbol.color.toRgba()[3]||lineSymbolizer.strokeOpacity;lineSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleLineSymbol.style]||lineSymbolizer.strokeDashstyle;return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymb
 ol..."+agsSimpleLineSymbol;}},"CartographicLineSymbol":function(agsCartographicLineSymbol){if(_isDefined(agsCartographicLineSymbol)&&agsCartographicLineSymbol instanceof esri.symbol.CartographicLineSymbol){var lineSymbolizer=this.parseAgsSymbol['SimpleLineSymbol'].apply(this,[agsCartographicLineSymbol]);return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol..."+agsCartographicLineSymbol;}},"SimpleFillSymbol":function(agsSimpleFillSymbol){if(_isDefined(agsSimpleFillSymbol)&&agsSimpleFillSymbol instanceof esri.symbol.SimpleFillSymbol){var polygonSymbolizer=new OpenLayers.Symbolizer.Polygon({});polygonSymbolizer.strokeColor=agsSimpleFillSymbol.outline.color.toHex()||polygonSymbolizer.strokeColor;polygonSymbolizer.strokeWidth=agsSimpleFillSymbol.outline.width||polygonSymbolizer.st
 rokeWidth;polygonSymbolizer.strokeOpacity=agsSimpleFillSymbol.outline.color.toRgba()[3]||polygonSymbolizer.strokeOpacity;polygonSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleFillSymbol.outline.style]||polygonSymbolizer.strokeDashstyle;polygonSymbolizer.fillColor=agsSimpleFillSymbol.color.toHex()||polygonSymbolizer.fillColor;polygonSymbolizer.fillOpacity=agsSimpleFillSymbol.color.toRgba()[3]||polygonSymbolizer.fillOpacity;return polygonSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol..."+agsSimpleFillSymbol;}},"PictureFillSymbol":function(agsPictureFillSymbol){if(_isDefined(agsPictureFillSymbol)&&agsPictureFillSymbol instanceof esri.symbol.PictureFillSymbol){var polygonSymbolizer=this.parseAgsSymbol['SimpleFillSymbol'].apply(this,[agsPictureFillSymbol]);return polygonSymbolizer;}else{Op
 enLayers.Console.error("...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol..."+agsPictureFillSymbol;}},"TextSymbol":function(agsTextSymbol){if(_isDefined(agsTextSymbol)&&agsTextSymbol instanceof esri.symbol.TextSymbol){var textSymbolizer=new OpenLayers.Symbolizer.Text({});textSymbolizer.label=agsTextSymbol.text||textSymbolizer.label;textSymbolizer.fontFamily=agsTextSymbol.font.family||textSymbolizer.fontFamily;textSymbolizer.fontSize=agsTextSymbol.font.size||textSymbolizer.fontSize;textSymbolizer.fontWeight=agsTextSymbol.font.weight||textSymbolizer.fontWeight;textSymbolizer.fontStyle=agsTextSymbol.font.style||textSymbolizer.fontStyle;textSymbolizer.color=agsTextSymbol.color.toHex()||textSymbolizer.color;return textSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol...");throw"...AgsA
 dapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol..."+agsTextSymbol;}}};this.parseAgsRenderer={"SimpleRenderer":function(agsSimpleRenderer){if(_isDefined(agsSimpleRenderer)&&agsSimpleRenderer instanceof esri.renderer.SimpleRenderer){var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[agsSimpleRenderer.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[agsSimpleRenderer.symbol]);var olRule=new OpenLayers.Rule({symbolizer:olSymbolizer});olRule.name=agsSimpleRenderer.label;olRule.title=agsSimpleRenderer.label;olRule.description=agsSimpleRenderer.description;var olStyle=new OpenLayers.Style(null,{rules:[olRule]});olStyle.name="SimpleRendererStyle";olStyle.title="SimpleRenderer Style";olStyle.description="An OpenLayers Style converted from an esri SimpleRenderer";return olStyle;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer...");throw"...AgsAdapter.parseAg
 sRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer..."+agsSimpleRenderer;}},"ClassBreaksRenderer":function(agsClassBreaksRenderer){if(_isDefined(agsClassBreaksRenderer)&&agsClassBreaksRenderer instanceof esri.renderer.ClassBreaksRenderer){var filterProperty=agsClassBreaksRenderer.attributeField;if(agsClassBreaksRenderer.infos!=null&&agsClassBreaksRenderer.infos.length>0){var olRules=[];for(var i=0;i<agsClassBreaksRenderer.infos.length;i++){var info=agsClassBreaksRenderer.infos[i];var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN,property:filterProperty,lowerBoundary:info.minValue,upperBoundary:info.maxValue});var olRule=new OpenLayers.Rule({symbolizer:olSymbolizer,filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;
 olRules.push(olRule);}
-var agsDefaultSymbol=agsClassBreaksRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolizer=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultRule=new OpenLayers.Rule({symbolizer:olDefaultSymbolizer,elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
-var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name="ClassBreaksRendererStyle";olStyle.title="ClassBreaksRenderer Style";olStyle.description="An OpenLayers Style converted from an esri ClassBreaksRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer...");throw"...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer..."+agsClassBreaksRenderer;}},"UniqueValueRenderer":function(agsUniqueValueRenderer){if(_isDefined(agsUniqueValueRenderer)&&agsUniqueValueRenderer instanceof esri.renderer.UniqueValueRenderer){var filterProperty=agsUniqueValueRenderer.attributeField;if(agsUniqueValueRenderer.infos!=null&&agsUniqueValueRenderer.infos.length>0){var olRules=[];for(var i=0;i<agsUniqueValueRenderer.infos.length;i++){var info=agsUniqueValueRenderer.infos[i];var olSymbolPa
 srserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:filterProperty,value:info.value});var olRule=new OpenLayers.Rule({symbolizer:olSymbolizer,filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;olRules.push(olRule);}
-var agsDefaultSymbol=agsUniqueValueRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolizer=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultRule=new OpenLayers.Rule({symbolizer:olDefaultSymbolizer,elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
-var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name="UniqueValueRendererStyle";olStyle.title="UniqueValueRenderer Style";olStyle.description="An OpenLayers Style converted from an esri UniqueValueRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer...");throw"...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer..."+agsUniqueValueRenderer;}},"TemporalRenderer":function(agsTemporalRenderer){}};this.parseAgsFeatureTemplate=function(agsFeatureTemplate){if(_isDefined(agsFeatureTemplate)&&agsFeatureTemplate.declaredClass=="esri.layers.FeatureTemplate"){var olFeatureTemplate={};if(agsFeatureTemplate.name!=null){olFeatureTemplate.name=agsFeatureTemplate.name;}
+return olPoints;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint...");throw"...AgsAdapter.parseAgsGeometry.multipoint...invalid esri.geometry.MultiPoint..."+agsPolygon;}},"extent":function(agsExtent){var olBounds=null;if(_isDefined(agsExtent.xmin)&&_isDefined(agsExtent.xmax)&&_isDefined(agsExtent.ymin)&&_isDefined(agsExtent.ymax)){olBounds=new OpenLayers.Bounds(agsExtent.xmin,agsExtent.ymin,agsExtent.xmax,agsExtent.ymax);return olBounds;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent...");throw"...AgsAdapter.parseAgsGeometry.extent...invalid esri.geometry.Extent..."+agsExtent;}}};this.parseAgsSymbol={"SimpleMarkerSymbol":function(agsSimpleMarkerSymbol){if(_isDefined(agsSimpleMarkerSymbol)&&agsSimpleMarkerSymbol instanceof esri.symbol.SimpleMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.strokeColor=agsSimpleMarkerSymbol.outlin
 e.color.toHex()||pointSymbolizer.strokeColor;pointSymbolizer.strokeWidth=agsSimpleMarkerSymbol.outline.width;pointSymbolizer.strokeOpacity=agsSimpleMarkerSymbol.outline.color.toRgba()[3]||pointSymbolizer.strokeOpacity;pointSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleMarkerSymbol.outline.style]||pointSymbolizer.strokeDashstyle;pointSymbolizer.fillColor=agsSimpleMarkerSymbol.color.toHex()||pointSymbolizer.fillColor;pointSymbolizer.fillOpacity=agsSimpleMarkerSymbol.color.toRgba()[3]||pointSymbolizer.fillOpacity;pointSymbolizer.pointRadius=agsSimpleMarkerSymbol.size||pointSymbolizer.pointRadius;pointSymbolizer.graphicName=_AGS_OL_SIMPLE_MARKERSYMBOL_MAP[agsSimpleMarkerSymbol.style]||pointSymbolizer.graphicName;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSi
 mpleMarkerSymbol;}},"PictureMarkerSymbol":function(agsPictureMarkerSymbol){if(_isDefined(agsPictureMarkerSymbol)&&agsPictureMarkerSymbol instanceof esri.symbol.PictureMarkerSymbol){var pointSymbolizer=new OpenLayers.Symbolizer.Point({});pointSymbolizer.pointRadius=agsPictureMarkerSymbol.size||pointSymbolizer.pointRadius;pointSymbolizer.externalGraphic=agsPictureMarkerSymbol.url||pointSymbolizer.externalGraphic;pointSymbolizer.graphicWidth=Math.floor(agsPictureMarkerSymbol.width)||pointSymbolizer.graphicWidth;pointSymbolizer.graphicHeight=Math.floor(agsPictureMarkerSymbol.height)||pointSymbolizer.graphicHeight;pointSymbolizer.graphicXOffset=agsPictureMarkerSymbol.xoffset||pointSymbolizer.graphicXOffset;pointSymbolizer.graphicYOffset=agsPictureMarkerSymbol.yoffset||pointSymbolizer.graphicYOffset;pointSymbolizer.rotation=agsPictureMarkerSymbol.angle||pointSymbolizer.rotation;return pointSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol..
 .missing or invalid SimpleMarkerSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleMarkerSymbol...invalid or invalid SimpleMarkerSymbol..."+agsSimpleMarkerSymbol;}},"SimpleLineSymbol":function(agsSimpleLineSymbol){if(_isDefined(agsSimpleLineSymbol)&&agsSimpleLineSymbol instanceof esri.symbol.SimpleLineSymbol){var lineSymbolizer=new OpenLayers.Symbolizer.Line({});lineSymbolizer.strokeColor=agsSimpleLineSymbol.color.toHex()||lineSymbolizer.strokeColor;lineSymbolizer.strokeWidth=Math.floor(agsSimpleLineSymbol.width);lineSymbolizer.strokeOpacity=agsSimpleLineSymbol.color.toRgba()[3]||lineSymbolizer.strokeOpacity;lineSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleLineSymbol.style]||lineSymbolizer.strokeDashstyle;return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleLineSymbol...missing or invalid SimpleLineSymbol..."+agsSimpleLineS
 ymbol;}},"CartographicLineSymbol":function(agsCartographicLineSymbol){if(_isDefined(agsCartographicLineSymbol)&&agsCartographicLineSymbol instanceof esri.symbol.CartographicLineSymbol){var lineSymbolizer=this.parseAgsSymbol['SimpleLineSymbol'].apply(this,[agsCartographicLineSymbol]);return lineSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol...");throw"...AgsAdapter.parseAgsSymbol.CartographicLineSymbol...missing or invalid CartographicLineSymbol..."+agsCartographicLineSymbol;}},"SimpleFillSymbol":function(agsSimpleFillSymbol){if(_isDefined(agsSimpleFillSymbol)&&agsSimpleFillSymbol instanceof esri.symbol.SimpleFillSymbol){var polygonSymbolizer=new OpenLayers.Symbolizer.Polygon({});polygonSymbolizer.strokeColor=agsSimpleFillSymbol.outline.color.toHex()||polygonSymbolizer.strokeColor;polygonSymbolizer.strokeWidth=Math.floor(agsSimpleFillSymbol.outline.width);polygonSymbolizer.strokeOpacit
 y=agsSimpleFillSymbol.outline.color.toRgba()[3]||polygonSymbolizer.strokeOpacity;polygonSymbolizer.strokeDashstyle=_AGS_OL_SIMPLE_LINESYMBOL_MAP[agsSimpleFillSymbol.outline.style]||polygonSymbolizer.strokeDashstyle;polygonSymbolizer.fillColor=agsSimpleFillSymbol.color.toHex()||polygonSymbolizer.fillColor;polygonSymbolizer.fillOpacity=agsSimpleFillSymbol.color.toRgba()[3]||polygonSymbolizer.fillOpacity;return polygonSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.SimpleFillSymbol...missing or invalid SimpleFillSymbol..."+agsSimpleFillSymbol;}},"PictureFillSymbol":function(agsPictureFillSymbol){if(_isDefined(agsPictureFillSymbol)&&agsPictureFillSymbol instanceof esri.symbol.PictureFillSymbol){var polygonSymbolizer=this.parseAgsSymbol['SimpleFillSymbol'].apply(this,[agsPictureFillSymbol]);return polygonSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.pa
 rseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol...");throw"...AgsAdapter.parseAgsSymbol.PictureFillSymbol...missing or invalid PictureFillSymbol..."+agsPictureFillSymbol;}},"TextSymbol":function(agsTextSymbol){if(_isDefined(agsTextSymbol)&&agsTextSymbol instanceof esri.symbol.TextSymbol){var textSymbolizer=new OpenLayers.Symbolizer.Text({});textSymbolizer.label=agsTextSymbol.text||textSymbolizer.label;textSymbolizer.fontFamily=agsTextSymbol.font.family||textSymbolizer.fontFamily;textSymbolizer.fontSize=agsTextSymbol.font.size||textSymbolizer.fontSize;textSymbolizer.fontWeight=agsTextSymbol.font.weight||textSymbolizer.fontWeight;textSymbolizer.fontStyle=agsTextSymbol.font.style||textSymbolizer.fontStyle;textSymbolizer.color=agsTextSymbol.color.toHex()||textSymbolizer.color;return textSymbolizer;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsSymbol.TextSymbol...missing or invalid TextSymbol...");throw"...AgsAdapter.parseAgsSymbol.TextSymbol...missi
 ng or invalid TextSymbol..."+agsTextSymbol;}}};this.parseAgsRenderer={"SimpleRenderer":function(agsSimpleRenderer){if(_isDefined(agsSimpleRenderer)&&agsSimpleRenderer instanceof esri.renderer.SimpleRenderer){var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[agsSimpleRenderer.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[agsSimpleRenderer.symbol]);var olRule=new OpenLayers.Rule({symbolizers:[olSymbolizer]});olRule.name=agsSimpleRenderer.label;olRule.title=agsSimpleRenderer.label;olRule.description=agsSimpleRenderer.description;var olStyle=new OpenLayers.Style(null,{rules:[olRule]});olStyle.name=agsSimpleRenderer.label;olStyle.title=agsSimpleRenderer.label;olStyle.description="An OpenLayers Style converted from an esri SimpleRenderer";return olStyle;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing or invalid esri.renderer.SimpleRenderer...");throw"...AgsAdapter.parseAgsRenderer.SimpleRenderer...missing
  or invalid esri.renderer.SimpleRenderer..."+agsSimpleRenderer;}},"ClassBreaksRenderer":function(agsClassBreaksRenderer){if(_isDefined(agsClassBreaksRenderer)&&agsClassBreaksRenderer instanceof esri.renderer.ClassBreaksRenderer){var filterProperty=agsClassBreaksRenderer.attributeField;if(agsClassBreaksRenderer.infos!=null&&agsClassBreaksRenderer.infos.length>0){var olRules=[];var agsDefaultSymbol=agsClassBreaksRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolizer=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultRule=new OpenLayers.Rule({symbolizers:[olDefaultSymbolizer],elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
+for(var i=0;i<agsClassBreaksRenderer.infos.length;i++){var info=agsClassBreaksRenderer.infos[i];var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN,property:filterProperty,lowerBoundary:info.minValue,upperBoundary:info.maxValue});var olRule=new OpenLayers.Rule({symbolizers:[olSymbolizer],filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;olRules.push(olRule);}
+var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name=agsClassBreaksRenderer.label;olStyle.title=agsClassBreaksRenderer.label;olStyle.description="An OpenLayers Style converted from an esri ClassBreaksRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer...");throw"...AgsAdapter.parseAgsRenderer.ClassBreaksRenderer...missing or invalid esri.renderer.ClassBreaksRenderer..."+agsClassBreaksRenderer;}},"UniqueValueRenderer":function(agsUniqueValueRenderer){if(_isDefined(agsUniqueValueRenderer)&&agsUniqueValueRenderer instanceof esri.renderer.UniqueValueRenderer){var filterProperty=agsUniqueValueRenderer.attributeField;if(agsUniqueValueRenderer.infos!=null&&agsUniqueValueRenderer.infos.length>0){var olRules=[];var agsDefaultSymbol=agsUniqueValueRenderer.defaultSymbol;if(agsDefaultSymbol!=null){var olDefaultSymbolize
 r=this.parseAgsSymbol[_AGS_OL_SYMBOL_PARSER_MAP[agsDefaultSymbol.type]].apply(this,[agsDefaultSymbol]);var olDefaultSymbolizers=[];olDefaultSymbolizers.push(olDefaultSymbolizer);var olDefaultRule=new OpenLayers.Rule({symbolizers:olDefaultSymbolizers,elseFilter:true});olDefaultRule.name="defaultRuleName";olDefaultRule.title="default rule title";olDefaultRule.description="default rule description";olRules.push(olDefaultRule);}
+for(var i=0;i<agsUniqueValueRenderer.infos.length;i++){var info=agsUniqueValueRenderer.infos[i];var olSymbolPasrserType=_AGS_OL_SYMBOL_PARSER_MAP[info.symbol.type];var olSymbolizer=this.parseAgsSymbol[olSymbolPasrserType].apply(this,[info.symbol]);var olFilter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:filterProperty,value:info.value});var olSymbolizers=[];olSymbolizers.push(olSymbolizer);var olRule=new OpenLayers.Rule({symbolizers:olSymbolizers,filter:olFilter});olRule.name=info.label;olRule.title=info.label;olRule.description=info.description;olRules.push(olRule);}
+var olStyle=new OpenLayers.Style(null,{rules:olRules});olStyle.name=agsUniqueValueRenderer.label;olStyle.title=agsUniqueValueRenderer.label;olStyle.description="An OpenLayers Style converted from an esri UniqueValueRenderer";return olStyle;}else{return new OpenLayers.Style(null,{});}}else{OpenLayers.Console.error("...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer...");throw"...AgsAdapter.parseAgsRenderer.UniqueValueRenderer...missing or invalid esri.renderer.UniqueValueRenderer..."+agsUniqueValueRenderer;}},"TemporalRenderer":function(agsTemporalRenderer){}};this.parseAgsFeatureTemplate=function(agsFeatureTemplate){if(_isDefined(agsFeatureTemplate)&&agsFeatureTemplate.declaredClass=="esri.layers.FeatureTemplate"){var olFeatureTemplate={};if(agsFeatureTemplate.name!=null){olFeatureTemplate.name=agsFeatureTemplate.name;}
 if(agsFeatureTemplate.description!=null){olFeatureTemplate.description=agsFeatureTemplate.description;}
 olFeatureTemplate.prototype=this.parseNoGeometryAgsGraphic.apply(this,[agsFeatureTemplate.prototype]);return olFeatureTemplate;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate...");throw"...AgsAdapter.parseAgsFeatureTemplate...missing or invalid esri.layers.FeatureTemplate..."+agsFeatureTemplate;}};this.parseAgsFeatureTemplates=function(agsFeatureTemplates){var olFeatureTemplates=[];if(_isDefined(agsFeatureTemplates)&&agsFeatureTemplates instanceof Array){for(var i=0;i<agsFeatureTemplates.length;i++){try{var olFeatureTemplate=this.parseAgsFeatureTemplate.apply(this,[agsFeatureTemplates[i]]);olFeatureTemplates.push(olFeatureTemplate);}catch(e){OpenLayers.Console.error(e.toString());throw e;}}
 return olFeatureTemplates;}else{OpenLayers.Console.error("...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array...");throw"...AgsAdapter.parseAgsFeatureTemplates...invalid esri.layers.FeatureTemplate array..."+agsFeatureTemplates;}};this.parseAgsFeatureType=function(agsFeatureType){if(_isDefined(agsFeatureType)&&agsFeatureType.declaredClass=="esri.layers.FeatureType"){var olFeatureType={};if(agsFeatureType.name!=null){olFeatureType.name=agsFeatureType.name;}
@@ -2030,7 +2015,7 @@
 this.addFeatures(lines,options);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.SOURCE_NODE=-1;OpenLayers.Layer.PointTrack.TARGET_NODE=0;OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Protocol.WFS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.WFS.DEFAULTS);var cls=OpenLayers.Protocol.WFS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFS version: "+options.version;}
 return new cls(options);};OpenLayers.Protocol.WFS.fromWMSLayer=function(layer,options){var typeName,featurePrefix;var param=layer.params["LAYERS"];var parts=(OpenLayers.Util.isArray(param)?param[0]:param).split(":");if(parts.length>1){featurePrefix=parts[0];}
 typeName=parts.pop();var protocolOptions={url:layer.url,featureType:typeName,featurePrefix:featurePrefix,srsName:layer.projection&&layer.projection.getCode()||layer.map&&layer.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(options,protocolOptions));};OpenLayers.Protocol.WFS.DEFAULTS={"version":"1.0.0"};OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.markers.length;i<len;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged
 ||!this.drawn){for(var i=0,len=this.markers.length;i<len;i++){this.drawMarker(this.markers[i]);}
-this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
+this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity<1){marker.setOpacity(this.opacity);}
 if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);marker.erase();}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{if(!marker.isDrawn()){var markerImg=marker.draw(px);this.div.appendChild(markerImg);}else if(marker.icon){marker.icon.moveTo(px);}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0,len=this.markers.length;i<len;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
 return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Control.AgsControl=OpenLayers.Class(OpenLayers.Control,{url:"",layer:null,mode:"select",asynchronous:false,adapter:null,handlers:null,displayResults:true,taskParameters:{},taskCallbacks:null,_resultFeatures:null,resultFeatureStyles:{},_resultImages:null,resultImageOptions:{},_resultsParser:null,selectControl:null,geometryTypes:null,clickout:false,toggle:true,multiple:false,drawControl:null,drawCtrlHandler:OpenLayers.Handler.Polygon,drawCtrlHandlerOptions:{},initialize:function(url,layer,callbacks,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.url=url;if(layer&&layer instanceof OpenLayers.Layer.Vector){this.layer=layer;}else{this.layer=new OpenLayers.Layer.Vector("__internal__",{displayInLayerSwitcher:false,isBaseLayer:false});}
 if(callbacks){this.taskCallbacks=callbacks;}
@@ -2056,11 +2041,11 @@
 var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});if(this.asynchronous==false){var agsIdentifyTask=new esri.tasks.IdentifyTask(this.url);var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});var _onCompleteError=this.errback||null;try{var agsIdentifyParameters=this.adapter.encodeAgsIdentifyParameters(_taskParameters);}catch(e){throw e;}
 agsIdentifyTask.execute(agsIdentifyParameters,_onExecuteComplete,_onCompleteError);}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsIdentifyTask ...");throw"...'asynchronous' should always be set to 'false' for AgsIdentifyTask ...";}},CLASS_NAME:"OpenLayers.Control.AgsIdentifyTask"});OpenLayers.Control.Pan=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,direction:null,type:OpenLayers.Control.TYPE_BUTTON,initialize:function(direction,options){this.direction=direction;this.CLASS_NAME+=this.direction;OpenLayers.Control.prototype.initialize.apply(this,[options]);},trigger:function(){var getSlideFactor=OpenLayers.Function.bind(function(dim){return this.slideRatio?this.map.getSize()[dim]*this.slideRatio:this.slideFactor;},this);switch(this.direction){case OpenLayers.Control.Pan.NORTH:this.map.pan(0,-getSlideFactor("h"));break;case OpenLayers.Control.Pan.SOUTH:this.map.pan(0,getSlideFactor("h"));break;case OpenLayers.Contr
 ol.Pan.WEST:this.map.pan(-getSlideFactor("w"),0);break;case OpenLayers.Control.Pan.EAST:this.map.pan(getSlideFactor("w"),0);break;}},CLASS_NAME:"OpenLayers.Control.Pan"});OpenLayers.Control.Pan.NORTH="North";OpenLayers.Control.Pan.SOUTH="South";OpenLayers.Control.Pan.EAST="East";OpenLayers.Control.Pan.WEST="West";OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,noMagic:false,yx:{'EPSG:4326':true},initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);if(parseFloat(params.VERSION)>=1.3&&!params.EXCEPTIONS){params.EXCEPTIONS="INIMAGE";}
 newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
+if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){return(parseFloat(this.params.VERSION)>=1.3&&!!this.yx[this.map.getProjectionObject().getCode()]);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=
 this.map.getProjectionObject();var projectionCode=this.projection&&this.projection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=this.params.CRS||value;this.params.SRS=null;}else{this.params.SRS=this.params.SRS||value;this.params.CRS=null;}
 if(typeof this.params.TRANSPARENT=="boolean"){newParams.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE";}
 return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesnap","snap","unsnap"],DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype
 .EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.layer){this.setLayer(this.options.layer);}
+obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.layer){this.setLayer(this.options.layer);}
 var defaults=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(defaults,this.DEFAULTS);this.setTargets(this.options.targets);if(this.targets.length===0&&this.layer){this.addTargetLayer(this.layer);}
 this.geoToleranceCache={};},setLayer:function(layer){if(this.active){this.deactivate();this.layer=layer;this.activate();}else{this.layer=layer;}},setTargets:function(targets){this.targets=[];if(targets&&targets.length){var target;for(var i=0,len=targets.length;i<len;++i){target=targets[i];if(target instanceof OpenLayers.Layer.Vector){this.addTargetLayer(target);}else{this.addTarget(target);}}}},addTargetLayer:function(layer){this.addTarget({layer:layer});},addTarget:function(target){target=OpenLayers.Util.applyDefaults(target,this.defaults);target.nodeTolerance=target.nodeTolerance||target.tolerance;target.vertexTolerance=target.vertexTolerance||target.tolerance;target.edgeTolerance=target.edgeTolerance||target.tolerance;this.targets.push(target);},removeTargetLayer:function(layer){var target;for(var i=this.targets.length-1;i>=0;--i){target=this.targets[i];if(target.layer===layer){this.removeTarget(target);}}},removeTarget:function(target){return OpenLayers.Util.removeItem(t
 his.targets,target);},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(this.layer&&this.layer.events){this.layer.events.on({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.layer&&this.layer.events){this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
@@ -2068,7 +2053,7 @@
 if(snapped){var proceed=this.events.triggerEvent("beforesnap",{point:point,x:best.x,y:best.y,distance:best.dist,layer:best.target.layer,snapType:this.precedence[best.rank]});if(proceed!==false){point.x=best.x;point.y=best.y;this.point=point;this.events.triggerEvent("snap",{point:point,snapType:this.precedence[best.rank],layer:best.target.layer,distance:best.dist});}else{snapped=false;}}
 if(this.point&&!snapped){point.x=loc.x;point.y=loc.y;this.point=null;this.events.triggerEvent("unsnap",{point:point});}},testTarget:function(target,loc){var resolution=this.layer.map.getResolution();if("minResolution"in target){if(resolution<target.minResolution){return null;}}
 if("maxResolution"in target){if(resolution>=target.maxResolution){return null;}}
-var tolerance={node:this.getGeoTolerance(target.nodeTolerance,resolution),vertex:this.getGeoTolerance(target.vertexTolerance,resolution),edge:this.getGeoTolerance(target.edgeTolerance,resolution)};var maxTolerance=Math.max(tolerance.node,tolerance.vertex,tolerance.edge);var result={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY};var eligible=false;var features=target.layer.features;var feature,type,vertices,vertex,closest,dist,found;var numTypes=this.precedence.length;var ll=new OpenLayers.LonLat(loc.x,loc.y);for(var i=0,len=features.length;i<len;++i){feature=features[i];if(feature!==this.feature&&!feature._sketch&&feature.state!==OpenLayers.State.DELETE&&(!target.filter||target.filter.evaluate(feature.attributes))){if(feature.atPoint(ll,maxTolerance,maxTolerance)){for(var j=0,stop=Math.min(result.rank+1,numTypes);j<stop;++j){type=this.precedence[j];if(target[type]){if(type==="edge"){closest=feature.geometry.distanceTo(loc,{details:true});dist=closest.distance;i
 f(dist<=tolerance[type]&&dist<result.dist){result={rank:j,dist:dist,x:closest.x0,y:closest.y0};eligible=true;break;}}else{vertices=feature.geometry.getVertices(type==="node");found=false;for(var k=0,klen=vertices.length;k<klen;++k){vertex=vertices[k];dist=vertex.distanceTo(loc);if(dist<=tolerance[type]&&(j<result.rank||(j===result.rank&&dist<result.dist))){result={rank:j,dist:dist,x:vertex.x,y:vertex.y};eligible=true;found=true;}}
+var tolerance={node:this.getGeoTolerance(target.nodeTolerance,resolution),vertex:this.getGeoTolerance(target.vertexTolerance,resolution),edge:this.getGeoTolerance(target.edgeTolerance,resolution)};var maxTolerance=Math.max(tolerance.node,tolerance.vertex,tolerance.edge);var result={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY};var eligible=false;var features=target.layer.features;var feature,type,vertices,vertex,closest,dist,found;var numTypes=this.precedence.length;var ll=new OpenLayers.LonLat(loc.x,loc.y);for(var i=0,len=features.length;i<len;++i){feature=features[i];if(feature!==this.feature&&!feature._sketch&&feature.state!==OpenLayers.State.DELETE&&(!target.filter||target.filter.evaluate(feature))){if(feature.atPoint(ll,maxTolerance,maxTolerance)){for(var j=0,stop=Math.min(result.rank+1,numTypes);j<stop;++j){type=this.precedence[j];if(target[type]){if(type==="edge"){closest=feature.geometry.distanceTo(loc,{details:true});dist=closest.distance;if(dist<=tol
 if(found){break;}}}}}}}
 return eligible?result:null;},getGeoTolerance:function(tolerance,resolution){if(resolution!==this.resolution){this.resolution=resolution;this.geoToleranceCache={};}
 var geoTolerance=this.geoToleranceCache[tolerance];if(geoTolerance===undefined){geoTolerance=tolerance*resolution;this.geoToleranceCache[tolerance]=geoTolerance;}
@@ -2096,8 +2081,8 @@
 if(!_taskParameters['distance']){OpenLayers.Console.error("...'distance' missing or invalid...");throw"...'distance' missing or invalid...";}
 var agsLocation=null;agsLocation=this.adapter.encodeAgsLocation(_taskParameters['location']);agsLocator.locationToAddress(agsLocation,_taskParameters['distance'],_onExecuteComplete,_onCompleteError);}else{if(!_taskParameters['address']){OpenLayers.Console.error("...'address' missing or invalid...");throw"...'address' missing or invalid...";}
 if(!_taskParameters['outFields']){OpenLayers.Console.error("...'outFields' missing or invalid...");throw"...'outFields' missing or invalid...";}
-agsLocator.addressToLocations(_taskParameters['address'],_taskParameters['outFields'],_onExecuteComplete,_onCompleteError);}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator...");throw"...'asynchronous' should always be set to 'false' for AgsLocator...";}},setReverseGeocoding:function(reverseGeocoding){if(reverseGeocoding==true){this.reverseGeocoding=true;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidate'];}else{this.reverseGeocoding=false;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidates'];}},CLASS_NAME:"OpenLayers.Control.AgsLocator"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.geo
 metryName&&!options.featureNS){this.geometryName=null;}
-if(!options.format){this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
+agsLocator.addressToLocations(_taskParameters['address'],_taskParameters['outFields'],_onExecuteComplete,_onCompleteError);}}else{OpenLayers.Console.error("...'asynchronous' should always be set to 'false' for AgsLocator...");throw"...'asynchronous' should always be set to 'false' for AgsLocator...";}},setReverseGeocoding:function(reverseGeocoding){if(reverseGeocoding==true){this.reverseGeocoding=true;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidate'];}else{this.reverseGeocoding=false;this._resultsParser.parser=this.adapter.parseAgsResults['addressCandidates'];}},CLASS_NAME:"OpenLayers.Control.AgsLocator"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.for
+if(!options.geometryName&&parseFloat(this.format.version)>1.0){this.setGeometryName(null);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
 this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",options)]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),params:options.params,headers:options.headers,data:data});return response;},setFeatureType:function(featureType){this.featureType=featureType;this.format.featureType=featureType;},setGeometryName:function(geometryName){this.geometryName=geometryName;this.format.geometryName=geometryName;},handleRead:function(response,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);if(options.callb
 ack){var request=response.priv;if(request.status>=200&&request.status<300){var result=this.parseResponse(request,options.readOptions);if(result&&result.success!==false){if(options.readOptions&&options.readOptions.output=="object"){OpenLayers.Util.extend(response,result);}else{response.features=result;}
 response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;response.error=result;}}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
 options.callback.call(options.scope,response);}},parseResponse:function(request,options){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
@@ -2148,14 +2133,14 @@
 break;case"featureselected":if(evt.feature.lockId&&evt.feature.lockId!=""){evt.feature.style=this._lockedStyle.createSymbolizer(evt.feature);}
 break;default:break;}},createFeatureIdFilter:function(features){var fids=[];for(var i=0;i<features.length;i++){if(features[i].fid){fids.push(features[i].fid);}}
 var filter=new OpenLayers.Filter.FeatureId({fids:fids});return filter;},createBBOXFilter:function(bounds){},setStyleMap:function(styleMap){if(styleMap){this._defaultStyle=styleMap.styles['default']||this._defaultStyle;this._selectStyle=styleMap.styles['select']||this._selectStyle;this._lockedStyle=styleMap.styles['locked']||this._lockedStyle;}},CLASS_NAME:"OpenLayers.Strategy.Lock"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});thi
 s.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,updateDimensions:function(){var mapExtent=this.map.getExtent();var renderExtent=this.map.getMaxExtent();this.setExtent(renderExtent,true);var res=this.getResolution();var div=this.rendererRoot.parentNode;var layerLeft=parseFloat(div.parentNode.style.left);var layerTop=parseFloat(div.parentNode.style.top);div.style.left=((renderExtent.left-mapExtent.left)/res-layerLeft)+"px";div.style.top=((mapExtent.top-renderExtent.top)/res-layerTop)+"px";},setSize:function(){this.map.getExtent()&&this.updateDimensions();},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Renderer.NG=OpenLayers.Class(OpenLayers.Renderer.Elements,{labelNodeType:null,updateDimensions:function(zoomChanged){var mapExtent=this.map.getExtent();var renderExtent=mapExtent.scale(3);this.setExtent(renderExtent,true);var res=this.getResolution();var div=this.rendererRoot.parentNode;var layerLeft=parseFloat(div.parentNode.style.left);var layerTop=parseFloat(div.parentNode.style.top);div.style.left=((renderExtent.left-mapExtent.left)/res-layerLeft)+"px";div.style.top=((mapExtent.top-renderExtent.top)/res-layerTop)+"px";},setSize:function(){this.map.getExtent()&&this.updateDimensions();},drawFeature:function(feature,style){if(style==null){style=feature.style;}
 if(feature.geometry){var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(rendered!==false&&style.label){var location=feature.geometry.getCentroid();this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
 return rendered;}},drawText:function(featureId,style,location){var label;if(typeof featureId!=="string"){label=featureId;}else{label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,this.labelNodeType);label._featureId=featureId;}
 label._style=style;label._x=location.x;label._y=location.y;if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
 if(label.parentNode!==this.textRoot){this.textRoot.appendChild(label);}
 return label;},CLASS_NAME:"OpenLayers.Renderer.NG"});OpenLayers.Renderer.SVG2=OpenLayers.Class(OpenLayers.Renderer.NG,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",symbolMetrics:null,labelNodeType:"g",initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},updateDimensions:function(){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var res=this.getResolution();var width=this.extent.getWidth();var height=this.extent.getHeight();var extentString=[this.extent.left,-this.extent.top,width,height].join(" ");this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.rendererRoot.setAttributeNS(null,"width",width/res);this.rendererRoot.setAttributeNS(null,"height",height/res);var i,len;var nodes=this.vectorRoot.childNodes;for(i=0,len=nodes.length;i<len;++i){this.setStyle(nodes[i]);}
-var textNodes=this.textRoot.childNodes;var label;for(i=0,len=textNodes.length;i<len;++i){label=textNodes[i];this.drawText(label,label._style,new OpenLayers.Geometry.Point(label._x,label._y));}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},updateDimensions:function(zoomChanged){OpenLayers.Renderer.NG.prototype.updateDimensions.apply(this,arguments);var res=this.getResolution();var width=this.extent.getWidth();var height=this.extent.getHeight();var extentString=[this.extent.left,-this.extent.top,width,height].join(" ");this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.rendererRoot.setAttributeNS(null,"width",width/res);this.rendererRoot.setAttributeNS(null,"height",height/res);if(zoomChanged===true){var i,len;var nodes=this.vectorRoot.childNodes;for(i=0,len=nodes.length;i<len;++i){this.setStyle(nodes[i]);}
+var textNodes=this.textRoot.childNodes;var label;for(i=0,len=textNodes.length;i<len;++i){label=textNodes[i];this.drawText(label,label._style,new OpenLayers.Geometry.Point(label._x,label._y));}}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
 break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
 return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var resolution=this.getResolution();var r=node._radius;var widthFactor=resolution;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}
 if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
@@ -2382,11 +2367,12 @@
 wPadding-extraX;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
 return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){if(this.div.parentNode==null){this.div.style.display="none";document.body.appendChild(this.div);}
 contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;if(this.div.parentNode==document.body){document.body.removeChild(this.div);this.div.style.display="";}}
-return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
+return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"touchend",OpenLayers.Function.bindAsEventListener(closePopup,this));OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
 if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
 if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
 if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Control.ScaleLine=OpenLayers.Class(Op
 enLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:false,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);function onTouchstart(evt){OpenLayers.Event.stop(evt,true);}
+this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,"touchstart":onTouchstart,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geod
 this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
 this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
 return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
@@ -2398,7 +2384,7 @@
 this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},erase:function(){if(this.imageDiv!=null&&this.imageDiv.parentNode!=null){OpenLayers.Element.remove(this.imageDiv);}},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
 if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
 var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},isDrawn:function(){var isDrawn=(this.imageDiv&&this.imageDiv.parentNode&&(this.imageDiv.parentNode.nodeType!=11));return isDrawn;},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
-this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},erase:function(){if(this.icon!=null){this.icon.erase();}},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
+this.events=new OpenLayers.Events(this,this.icon.imageDiv);},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},erase:function(){if(this.icon!=null){this.icon.erase();}},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
 this.lonlat=this.map.getLonLatFromLayerPx(px);},isDrawn:function(){var isDrawn=(this.icon&&this.icon.isDrawn());return isDrawn;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
 return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
 if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
@@ -2467,13 +2453,7 @@
 this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
 var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
 if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
-url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
-return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
-{x=((x%limit)+limit)%limit;}
-return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.st
 yle.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dr
 agHandler.start.clone();}
+this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;t
 his.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.zoomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{
 result=this.dragHandler.start.clone();}
 this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
 return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
 return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax
 =center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
@@ -2482,7 +2462,7 @@
 this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
 this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
 this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
-this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
 this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
 return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
 return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
@@ -2504,10 +2484,21 @@
 return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
 this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
 var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(
 newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"]
 ,multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:false,featureAdded:fun
 ction(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
 var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
 redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);if(this.defaultControl===null){this.defaultControl=this.controls[0];}
-return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rg
 b.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
+this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},insertXY:function(x,y){if(this.handler&&this.handler.line){this.handler.insertXY(x,y);}},insertDeltaXY:function(dx,dy){if(this.handler&&this.handler.line){this.handler.insertDeltaXY(dx,dy);}},insertDirectionLength:function(direction,length){if(this.handler&&this.handler.line){this.handler.insertDirectionLength(direction,length);}},insertDeflectionLength:function(deflection,length){if(this.handler&&this.handler.line){this.handler.insertDeflectionLength(deflection,length);}},undo:function(){return this.handler.undo&&this.handler.undo();},redo:function(){return this.handler.
 redo&&this.handler.redo();},finishSketch:function(){this.handler.finishGeometry();},cancel:function(){this.handler.cancel();},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{citeCompliant:false,initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{displayClass:'olControlDrawFeaturePoint',handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{displayClass:'olControlDrawFeaturePath',handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{displayClass:'olControlDrawFeaturePolygon',handlerOptions:{citeCompliant:this.citeCompliant}})];this.addControls(controls);},draw:function(){var div=OpenLayers.
+return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_feature',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
+return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
+var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
+return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};var j;var jlen=featureNode.attributes.length;if(jlen>0){for(j=0;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}}else{var nodes=featureNode.childNodes;for(j=0,jlen=nodes.length;j<jlen;++j){var node=nodes[j];if(node.nodeType!=3){attributes[node.getAttribute("name")]=node.getAttribute("value");}}}
+response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
+return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
+tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
+return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;if(grandchildren.length==0){attributes[name]=null}else if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
+return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
+var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
+return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((thi
 s.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
 shortHexCode.charAt(i));}}
 if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
 var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=OpenLayers.Element.getStyle(OpenLayers.Util.getElement(elem),"backgroundColor");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
@@ -2544,7 +2535,7 @@
 if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
 var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
 return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.Anc
 horedBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"
 OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Strategy.Save=OpenLayers.Class(OpenLayers.Strategy,{EVENT_TYPES:["start","success","fail"],events:null,auto:false,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.auto){if(typeof this.auto==="number"){this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),this.auto*1000);}else{this.layer.events.on({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
+if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"
 OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Strategy.Save=OpenLayers.Class(OpenLayers.Strategy,{events:null,auto:false,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);this.events=new OpenLayers.Events(this);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.auto){if(typeof this.auto==="number"){this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),this.auto*1000);}else{this.layer.events.on({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){if(this.auto){if(typeof this.auto==="number"){window.clearInterval(this.timer);}else{this.layer.events.un({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
 return deactivated;},triggerSave:function(event){var feature=event.feature;if(feature.state===OpenLayers.State.INSERT||feature.state===OpenLayers.State.UPDATE||feature.state===OpenLayers.State.DELETE){this.save([event.feature]);}},save:function(features){if(!features){features=this.layer.features;}
 this.events.triggerEvent("start",{features:features});var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var len=features.length;var clones=new Array(len);var orig,clone;for(var i=0;i<len;++i){orig=features[i];clone=orig.clone();clone.fid=orig.fid;clone.state=orig.state;if(orig.url){clone.url=orig.url;}
@@ -2564,19 +2555,7 @@
 this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:this.createFilter(),callback:this.merge,scope:this},options));},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
 return filter;},merge:function(resp){this.layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
 this.layer.addFeatures(features);}
-this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Tile.Google=OpenLayers.Class(OpenLayers.Tile,{node:null,initialize:function(layer,position,bounds,options){OpenLayers.Tile.prototype.initialize.apply(this,[layer,position,bounds,null,null,options]);},destroy:function(){this.node&&this.clear();this.node=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Google(this.layer,this.position,this.bounds);}
-OpenLayers.Util.applyDefaults(obj,this);obj.node=null;return obj;},draw:function(){var layerType=OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.layer.type];if(layerType&&OpenLayers.Tile.prototype.draw.apply(this,arguments)){var xyz=this.layer.getXYZ(this.bounds);var point=new google.maps.Point(xyz.x,xyz.y);var tempTile;if(this.layer.type===google.maps.MapTypeId.HYBRID){tempTile=layerType.getTile(point,xyz.z,document);}
-this.node=layerType.getTile(point,xyz.z,document);this.isLoading=true;this.events.triggerEvent("loadstart");this.layer.div.appendChild(this.node);OpenLayers.Util.modifyDOMElement(this.node,null,this.position,null,"absolute");window.setTimeout(OpenLayers.Function.bind(function(){this.isLoading=false;this.events&&this.events.triggerEvent("loadend");if(tempTile){layerType.releaseTile(tempTile);}},this),0);}
-return true;},clear:function(){if(this.node){this.node.parentNode&&this.node.parentNode.removeChild(this.node);OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.layer.type].releaseTile(this.node);}},CLASS_NAME:"OpenLayers.Tile.Google"});OpenLayers.Layer.GoogleNG=OpenLayers.Class(OpenLayers.Layer.XYZ,{SUPPORTED_TRANSITIONS:[],serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338,0.07464553542435169,0.037322767712175846],attributionTemplate:'<span class="olGoogleAttribution ${mapType}">'+'<div><a title="Click to see this area on Google Maps" '+'target="_blank" href="http://maps.google.com/maps?'+'ll=${center}&z=${zoom}&t=${t}"><img w
 idth="62" height="24" '+'src="http://maps.gstatic.com/mapfiles/google_white.png"/></a>'+'</div>${mapData}<a style="white-space: nowrap" target="_blank" '+'href="http://www.google.com/help/terms_maps.html">'+'Terms of Use</a></span>',mapTypes:{"roadmap":"m","satellite":"k","hybrid":"h","terrain":"p"},type:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({sphericalMercator:true},options);if(!options.type){options.type=google.maps.MapTypeId.ROADMAP;}
-var newArgs=[options.name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);if(!OpenLayers.Layer.GoogleNG.mapObject){OpenLayers.Layer.GoogleNG.mapObject=new google.maps.Map(document.createElement("div"));}
-if(OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type]){this.initLayer();}else{google.maps.event.addListenerOnce(OpenLayers.Layer.GoogleNG.mapObject,"idle",OpenLayers.Function.bind(this.initLayer,this));}},initLayer:function(){var mapType=OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type];if(!this.name){this.setName("Google "+mapType.name);}
-var minZoom=mapType.minZoom||0;this.addOptions({maxResolution:Math.min(this.serverResolutions[minZoom],this.maxResolution),zoomOffset:minZoom,numZoomLevels:Math.min(mapType.maxZoom+1-minZoom,this.numZoomLevels)},true);},addTile:function(bounds,position){return new OpenLayers.Tile.Google(this,position,bounds,this.tileOptions);},updateAttribution:function(copyrights){var myCopyrights;if(this.type==google.maps.MapTypeId.HYBRID){var candidates=[].concat(copyrights["h"],copyrights["k"],copyrights["m"]);myCopyrights=[];for(var i=candidates.length-1;i>=0;--i){if(OpenLayers.Util.indexOf(candidates,myCopyrights)==-1){myCopyrights.push(candidates[i]);}}}else{myCopyrights=copyrights[this.mapTypes[this.type]];}
-var mapData=myCopyrights.length==0?"":"Map Data &copy;"+new Date().getFullYear()+" "+
-myCopyrights.join(", ")+" - ";var center=this.map.getCenter();center&&center.transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var size=this.map.getSize();this.attribution=OpenLayers.String.format(this.attributionTemplate,{t:this.mapTypes[this.type],zoom:this.map.getZoom(),center:center.lat+","+center.lon,mapType:this.type,mapData:mapData});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.events.register("moveend",this,OpenLayers.Layer.GoogleNG.loadCopyrights);},removeMap:function(){OpenLayers.Layer.XYZ.prototype.removeMap.apply(this,arguments);this.events.unregister("moveend",this,OpenLayers.Layer.GoogleNG.loadCopyrights);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.GoogleNG(this.options);}
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.GoogleNG"});OpenLayers.Layer.GoogleNG.mapObject=null;OpenLayers.Layer.GoogleNG.loadCopyrights=function(){var me=OpenLayers.Layer.GoogleNG.loadCopyrights;if(me.numLoadingScripts==undefined){me.loadingScripts=[];me.numLoadingScripts=0;me.copyrights={"m":[],"k":[],"h":[],"p":[]};me.origGAddCopyright=window.GAddCopyright;me.origGVerify=window.GVerify;me.origGAppFeatures=window.GAppFeatures;window.GAddCopyright=function(){var copyright=arguments[7];var category=me.copyrights[arguments[0]];if(OpenLayers.Util.indexOf(category,copyright)==-1){copyright&&category.push(copyright);}};window.GVerify=OpenLayers.Function.True;window.GAppFeatures=OpenLayers.Function.bind(function(){me.numLoadingScripts--;if(me.numLoadingScripts==0){var script;for(var i=me.loadingScripts.length-1;i>=0;--i){script=me.loadingScripts[i][0];me.loadingScripts[i][1].updateAttribution(me.copyrights);script.parentNo
 de.removeChild(script);}
-window.GAddCopyright=me.origGAddCopyright;delete me.origGAddCopyright;window.GVerify=me.origGVerify;delete me.origGVerify;window.GAppFeatures=me.origGAppFeatures;delete me.origGAppFeatures;delete me.loadingScripts;delete me.numLoadingScripts;delete me.copyrights;}},this);}
-var mapProj=this.map.getProjectionObject();var llProj=new OpenLayers.Projection("EPSG:4326");var center=this.map.getCenter().transform(mapProj,llProj);var extent=this.map.getExtent().transform(mapProj,llProj);var params={spn:extent.getHeight()+","+extent.getWidth(),z:this.map.getZoom(),t:this.mapTypes[this.type],vp:center.lat+","+center.lon};var url="http://maps.google.com/maps?"+
-OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;me.numLoadingScripts++;me.loadingScripts.push([script,this]);document.getElementsByTagName("head")[0].appendChild(script);};OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Mat
 h.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.
 VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":true},createLayer:function(capabilities,config){var layer;var required={layer:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
+this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=
 (this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":true},createLayer:function(capabilities,config){var layer;var required={layer:true,
 var contents=capabilities.contents;var matrixSet=contents.tileMatrixSets[config.matrixSet];var layers=contents.layers;var layerDef;for(var i=0,ii=contents.layers.length;i<ii;++i){if(contents.layers[i].identifier===config.layer){layerDef=contents.layers[i];break;}}
 if(layerDef&&matrixSet){var style;for(var i=0,ii=layerDef.styles.length;i<ii;++i){style=layerDef.styles[i];if(style.isDefault){break;}}
 layer=new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(config,{url:capabilities.operationsMetadata.GetTile.dcp.http.get,name:layerDef.title,style:style.identifier,matrixIds:matrixSet.matrixIds}));}
@@ -2603,7 +2582,7 @@
 this.mapObject=mapObject;this.setGMapVisibility(this.visibility);},repositionMapElements:function(){google.maps.event.trigger(this.mapObject,"resize");var div=this.mapObject.getDiv().firstChild;if(!div||div.childNodes.length<3){this.repositionTimer=window.setTimeout(OpenLayers.Function.bind(this.repositionMapElements,this),250);return false;}
 var cache=OpenLayers.Layer.Google.cache[this.map.id];var container=this.map.viewPortDiv;while(div.lastChild.style.display=="none"){container.appendChild(div.lastChild);}
 var termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright olLayerGoogleV3";termsOfUse.style.display="";cache.termsOfUse=termsOfUse;var poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";poweredBy.style.display="";cache.poweredBy=poweredBy;this.setGMapVisibility(this.visibility);},onMapResize:function(){if(this.visibility){google.maps.event.trigger(this.mapObject,"resize");}else{var cache=OpenLayers.Layer.Google.cache[this.map.id];if(!cache.resized){var layer=this;google.maps.event.addListenerOnce(this.mapObject,"tilesloaded",function(){google.maps.event.trigger(layer.mapObject,"resize");layer.moveTo(layer.map.getCenter(),layer.map.getZoom());delete cache.resized;});}
-cache.resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache&&!cache.resized){var type=this.type;var layers=this.map.layers;var layer;for(var i=layers.length-1;i>=0;--i){layer=layers[i];if(layer instanceof OpenLayers.Layer.Google&&layer.visibility===true&&layer.inRange===true){type=layer.type;visible=true;break;}}
+cache.resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var type=this.type;var layers=this.map.layers;var layer;for(var i=layers.length-1;i>=0;--i){layer=layers[i];if(layer instanceof OpenLayers.Layer.Google&&layer.visibility===true&&layer.inRange===true){type=layer.type;visible=true;break;}}
 var container=this.mapObject.getDiv();if(visible===true){this.mapObject.setMapTypeId(type);container.style.left="";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.left="";cache.termsOfUse.style.display="";cache.poweredBy.style.display="";}
 cache.displayed=this.id;}else{delete cache.displayed;container.style.left="-9999px";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.display="none";cache.termsOfUse.style.left="-9999px";cache.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getDiv();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new google.maps.LatLngBounds(new google.maps.LatLng(sw.lat,sw.lon),new google.maps.LatLng(ne.lat,ne.lon));}
 return moBounds;},getMapObjectLonLatFromMapObjectPixel:function(moPixel){var size=this.map.getSize();var lon=this.getLongitudeFromMapObjectLonLat(this.mapObject.center);var lat=this.getLatitudeFromMapObjectLonLat(this.mapObject.center);var res=this.map.getResolution();var delta_x=moPixel.x-(size.w/2);var delta_y=moPixel.y-(size.h/2);var lonlat=new OpenLayers.LonLat(lon+delta_x*res,lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}
@@ -2630,7 +2609,7 @@
 if(options.Constraint){this.writeNode("csw:Constraint",options.Constraint,node);}
 if(options.SortBy){this.writeNode("ogc:SortBy",options.SortBy,node);}
 return node;},"ElementName":function(options){var node=this.createElementNSPlus("csw:ElementName",{value:options.value});return node;},"ElementSetName":function(options){var node=this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:options.typeNames},value:options.value});return node;},"Constraint":function(options){var node=this.createElementNSPlus("csw:Constraint",{attributes:{version:options.version}});if(options.Filter){var format=new OpenLayers.Format.Filter({version:options.version});node.appendChild(format.write(options.Filter));}else if(options.CqlText){var child=this.createElementNSPlus("CqlText",{value:options.CqlText.value});node.appendChild(child);}
-return node;}},"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
+return node;}},"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
 if(!width){width=2;}
 this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
 return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:true,initialize:function(options){options=options||{};if(options.extractStyles!==false){options.defaultStyle={'externalGraphic':OpenLayers.Util.getImagesLocation()+"marker.png",'graphicWidth':21,'graphicHeight':25,'graphicXOffset':-10.5,'graphicYOffset':-12.5};}
@@ -2647,20 +2626,20 @@
 this.addMarker(marker);}
 this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
 if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.Drag.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
+OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,citeCompliant:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
+OpenLayers.Handler.Drag.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
 if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
 this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
+return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.layer.getLonLatFromViewPortPx(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
 if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
+this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.layer.getLonLatFromViewPortPx(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
 this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
 this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
 this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();if(this.start==this.last){this.callback("done",[evt.xy]);}},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
 this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
 for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures();}},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["selected"],clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLengt
 h:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})});}
+if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLength:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new O
 this.handler=new handler(this,this.callbacks,this.handlerOptions);},destroy:function(){for(var key in this.layerCache){delete this.layerCache[key];}
 for(var key in this.wfsCache){delete this.wfsCache[key];}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);},coupleLayerVisiblity:function(evt){this.setVisibility(evt.object.getVisibility());},createSelectionLayer:function(source){var selectionLayer;if(!this.layerCache[source.id]){selectionLayer=new OpenLayers.Layer.WMS(source.name,source.url,source.params,OpenLayers.Util.applyDefaults(this.layerOptions,source.getOptions()));this.layerCache[source.id]=selectionLayer;if(this.layerOptions.displayInLayerSwitcher===false){source.events.on({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});}
@@ -2703,7 +2682,7 @@
 +'/'+(newParams.tilerow%this.params.tileRowsPerFolder)
 +'_'+(newParams.tilecol%this.params.tileColumnsPerFolder)
 +'.'+this.params.format;if(this.params.querystring){tilePath+="?"+this.params.querystring;}
-requestString+=tilePath;return requestString;},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=origin.lat-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:['measure','measurepartial'],handlerOptions:null,callbacks:null,displaySystem:'metric'
 ,geodesic:false,displaySystemUnits:{geographic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.Measure.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
+requestString+=tilePath;return requestString;},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=origin.lat-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{handlerOptions:null,callbacks:null,displaySystem:'metric',geodesic:false,displaySystemUnits:{geogr
 aphic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
 this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new handler(this,this.callbacks,this.handlerOptions);},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},cancel:function(){this.cancelDelay();this.handler.cancel();},setImmediate:function(immediate){this.immediate=immediate;if(this.immediate){this.callbacks.modify=this.measureImmediate;}else{delete this.callbacks.modify;}},updateHandler:function(handler,options){var active=this.active;if(active){this.deactivate();}
 this.handler=new handler(this,this.callbacks,options);if(active){this.activate();}},measureComplete:function(geometry){this.cancelDelay();this.measure(geometry,"measure");},measurePartial:function(point,geometry){this.cancelDelay();geometry=geometry.clone();if(this.handler.freehandMode(this.handler.evt)){this.measure(geometry,"measurepartial");}else{this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(geometry,"measurepartial");},this),this.partialDelay);}},measureImmediate:function(point,feature,drawing){if(drawing&&this.delayedTrigger===null&&!this.handler.freehandMode(this.handler.evt)){this.measure(feature.geometry,"measurepartial");}},cancelDelay:function(){if(this.delayedTrigger!==null){window.clearTimeout(this.delayedTrigger);this.delayedTrigger=null;}},measure:function(geometry,eventType){var stat,order;if(geometry.CLASS_NAME.indexOf('LineString')>-1){stat=this.getBestLength(geometry);order=1;}else{stat=this.
 getBestArea(geometry);order=2;}
 this.events.triggerEvent(eventType,{measure:stat[0],units:stat[1],order:order,geometry:geometry});},getBestArea:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,area;for(var i=0,len=units.length;i<len;++i){unit=units[i];area=this.getArea(geometry,unit);if(area>1){break;}}
@@ -2718,24 +2697,23 @@
 node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));if(context.dimensions){node.appendChild(this.write_wmc_DimensionList(context));}
 node.appendChild(this.write_wmc_LayerExtension(context));},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(yx,this.yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
 if(data&&data.nodeType==9){data=data.documentElement;}
-var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChildNodes(node,tileMatr
 ixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
-if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
 MTSCapabilities.v1_0_0"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},"tr":{'offset':n
 ew OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLaye
 rs.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:
 new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,asynJobCompleteCallback:null,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;var addAndShowResults=this._bind
 Function(function(evt){this.cleanupResults();this.addResults(evt.results);this.showResults();},this);var _asynTaskCallbacks=[];_asynTaskCallbacks=_asynTaskCallbacks.concat(this.taskCallbacks);_asynTaskCallbacks=_asynTaskCallbacks.concat([addAndShowResults]);this.asynJobCompleteCallback=this._createCallbacks(this,_asynTaskCallbacks,{});this.events.on({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this);},destroy:function(){this.events.un({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[]);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_t
 askCallbacks,{});this._resultsParser={'parser':this.geoprocessingResultsParser,'context':this};var agsFeatureSet=this.adapter.encodeAgsFeatureSet(olFeatures,this.layer.map['projection'],{});var agsGeoprocessor=new esri.tasks.Geoprocessor(this.url);var geoprocessingParams=this.geoprocessingParamsEnocoder(agsFeatureSet,_taskParameters);if(this.asynchronous==false){var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});agsGeoprocessor.execute(geoprocessingParams,_onExecuteComplete);}else{var _onExecuteAsynComplete=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:agsGeoprocessor,});agsGeoprocessor.submitJob(geoprocessingParams,_onExecuteAsynComplete,null);}},geoprocessingParamsEnocoder:function(agsFeatureSet,tasksParameters){var geoprocessingParams=tasksParameters;return geoprocessingParams;},geoprocessingResultsParser:function(agsResults,options){var olResults={};return olResults;},CLASS_NAME:"OpenLayer
 s.Control.AgsGeoprocessor"});OpenLayers.Control.ModifyFeatureWithLock=OpenLayers.Class(OpenLayers.Control.ModifyFeature,{deleteFeatureCodes:null,initialize:function(layer,options){OpenLayers.Control.ModifyFeature.prototype.initialize.apply(this,[layer,options]);if(options){if(!options.deleteFeatureCodes){this.deleteFeatureCodes=[81];}else{this.deleteFeatureCodes=options.deleteFeatureCodes;}}
+var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];layer.boundingBox=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChi
 ldNodes(node,tileMatrixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
+if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
 new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.AgsGeoprocessor=OpenLayers.Class(OpenLayers.Control.AgsControl,{multiple:true,asynchronous:false,asynJobCompleteCallback:null,initialize:function(url,layer,callbacks,options){OpenLayers.Control.AgsControl.prototype.initialize.apply(this,[url,layer,callbacks,options]);this.events.addEventType("asynjobcomplete");this._bindFunction=OpenLayers.Util.AgsUtil.bindFunction;var addAndShowResults=this._bindFunction(function(evt){this.cleanupResults();this.addResults(evt.results);this.showRe
 sults();},this);var _asynTaskCallbacks=[];_asynTaskCallbacks=_asynTaskCallbacks.concat(this.taskCallbacks);_asynTaskCallbacks=_asynTaskCallbacks.concat([addAndShowResults]);this.asynJobCompleteCallback=this._createCallbacks(this,_asynTaskCallbacks,{});this.events.on({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});this.execute=this._bindFunction(this.execute,this);},destroy:function(){this.events.un({"asynjobcomplete":this.asynJobCompleteCallback,scope:this});OpenLayers.Control.AgsControl.prototype.destroy.apply(this,[]);},execute:function(olFeatures,taskParameters,callbacks){var _taskParameters=OpenLayers.Util.extend({},taskParameters);OpenLayers.Util.applyDefaults(_taskParameters,this.taskParameters);var _taskCallbacks=[];_taskCallbacks=_taskCallbacks.concat(this.taskCallbacks);_taskCallbacks=_taskCallbacks.concat(callbacks);var _singleTaskCallback=this._createCallbacks(this,_taskCallbacks,{});this._resultsParser={'parser':this.geoprocessingResultsParser,'conte
 xt':this};var agsFeatureSet=this.adapter.encodeAgsFeatureSet(olFeatures,this.layer.map['projection'],{});var agsGeoprocessor=new esri.tasks.Geoprocessor(this.url);var geoprocessingParams=this.geoprocessingParamsEnocoder(agsFeatureSet,_taskParameters);if(this.asynchronous==false){var _onExecuteComplete=this._createCallbacks(this,[this.onExecuteComplete],{callback:_singleTaskCallback});agsGeoprocessor.execute(geoprocessingParams,_onExecuteComplete);}else{var _onExecuteAsynComplete=this._createCallbacks(this,[this.onExecuteAsynComplete],{agsGeoprocessor:agsGeoprocessor,});agsGeoprocessor.submitJob(geoprocessingParams,_onExecuteAsynComplete,null);}},geoprocessingParamsEnocoder:function(agsFeatureSet,tasksParameters){var geoprocessingParams=tasksParameters;return geoprocessingParams;},geoprocessingResultsParser:function(agsResults,options){var olResults={};return olResults;},CLASS_NAME:"OpenLayers.Control.AgsGeoprocessor"});OpenLayers.Control.ModifyFeatureWithLock=OpenLayers.Clas
 this.layer.events.on({'transactionsucceeded':function(){this.deactivate();this.activate();},'transactionfailed':function(){this.deactivate();this.activate();},scope:this});},selectFeature:function(feature){this.feature=feature;if(feature.lockId&&feature.lockId!=""){if(this.mode==OpenLayers.Control.ModifyFeature.DELETE){OpenLayers.Console.log("...feature is locked...control in DELETE mode...it can only be deleted...");}else{this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);OpenLayers.Console.log("...feature is locked...so it can be modified...");}}else{OpenLayers.Console.log("...feature is not locked...so it can not be modified/deleted...");}},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
 if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){if(feature.lockId&&feature.lockId!=""){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);OpenLayers.Console.log("...feature is locked...drag start...");this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}else{OpenLayers.Console.log("...feature is not locked...drag not start...");}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.mode==OpenLayers.Control.ModifyFeatureWithLock.DELETE){if(this.feature&&OpenLayers.Util.indexOf(this.deleteFeatureCodes,code)!=-1){if(this.feature.lockId&&this.feature.lockId!=""){this.feature.state=OpenLayers.State.DELETE;this.layer.eraseFeatures([this.feature]);if(OpenLayers.Util.indexOf(this.layer.selectedFeatures,this.feature
 )!=-1){OpenLayers.Util.removeItem(this.layer.selectedFeatures,this.feature);}
-console.log("...delete feature at client side...");this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}else{console.log("...can not delete feature...feature must be locked first...");}}}else{if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}}},CLASS_NAME:"OpenLayers.Control.ModifyFeatureWithLock"});OpenLayers.Control.ModifyFeatureWithLock.RESHAPE=1;OpenLayers.Control.ModifyFeatureWithLock.RESIZE=2;OpenLayers.Control.ModifyFeatureWithLock.ROTATE=4;OpenLayers.Control.ModifyFeat
 ureWithLock.DRAG=8;OpenLayers.Control.ModifyFeatureWithLock.DELETE=16;OpenLayers.Tile.Image.IFrame={useIFrame:null,clear:function(){if(this.useIFrame){if(this.imgDiv){var iFrame=this.imgDiv.firstChild;OpenLayers.Event.stopObservingElement(iFrame);this.imgDiv.removeChild(iFrame);delete iFrame;}}else{OpenLayers.Tile.Image.prototype.clear.apply(this,arguments);}},renderTile:function(){if(OpenLayers.Tile.Image.prototype.renderTile.apply(this,arguments)&&this.useIFrame){var form=this.createRequestForm();this.imgDiv.appendChild(form);form.submit();this.imgDiv.removeChild(form);delete form;}
-return true;},initImgDiv:function(){this.useIFrame=this.maxGetUrlLength!==null&&!this.layer.async&&this.url.length>this.maxGetUrlLength;if(this.imgDiv!=null){var nodeName=this.imgDiv.nodeName.toLowerCase();if((this.useIFrame&&nodeName=="img")||(!this.useIFrame&&nodeName=="div")){this.removeImgDiv();this.imgDiv=null;}}
-if(this.useIFrame){if(this.imgDiv==null){var eventPane=document.createElement("div");if(OpenLayers.BROWSER_NAME=="msie"){eventPane.style.backgroundColor='#FFFFFF';eventPane.style.filter='chroma(color=#FFFFFF)';}
-OpenLayers.Util.modifyDOMElement(eventPane,null,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");this.imgDiv=document.createElement("div");this.imgDiv.appendChild(eventPane);OpenLayers.Util.modifyDOMElement(this.imgDiv,this.id,null,this.layer.getImageSize(),"relative");this.imgDiv.className='olTileImage';this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
-this.imgDiv.map=this.layer.map;}
-this.imgDiv.viewRequestID=this.layer.map.viewRequestID;}else{OpenLayers.Tile.Image.prototype.initImgDiv.apply(this,arguments);}},createIFrame:function(){var id=this.id+'_iFrame';var iframe;if(OpenLayers.BROWSER_NAME=="msie"){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
+console.log("...delete feature at client side...");this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}else{console.log("...can not delete feature...feature must be locked first...");}}}else{if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}}},CLASS_NAME:"OpenLayers.Control.ModifyFeatureWithLock"});OpenLayers.Control.ModifyFeatureWithLock.RESHAPE=1;OpenLayers.Control.ModifyFeatureWithLock.RESIZE=2;OpenLayers.Control.ModifyFeatureWithLock.ROTATE=4;OpenLayers.Control.ModifyFeat
 ureWithLock.DRAG=8;OpenLayers.Control.ModifyFeatureWithLock.DELETE=16;OpenLayers.Tile.Image.IFrame={useIFrame:null,updateBackBuffer:function(){this.url=this.layer.getURL(this.bounds);var usedIFrame=this.useIFrame;this.useIFrame=this.maxGetUrlLength!==null&&!this.layer.async&&this.url.length>this.maxGetUrlLength;var fromIFrame=usedIFrame&&!this.useIFrame;var toIFrame=!usedIFrame&&this.useIFrame;if(fromIFrame||toIFrame){this.clear();if(this.imgDiv&&this.imgDiv.parentNode===this.frame){this.frame.removeChild(this.imgDiv);}
+this.imgDiv=null;if(fromIFrame){this.frame.removeChild(this.frame.firstChild);this.resetBackBuffer();}}
+if(!this.useIFrame){OpenLayers.Tile.Image.prototype.updateBackBuffer.apply(this,arguments);}},createImage:function(){if(this.useIFrame===true){if(!this.frame.childNodes.length){var eventPane=document.createElement("div"),style=eventPane.style;style.position="absolute";style.width="100%";style.height="100%";style.zIndex=1;style.backgroundImage="url("+this.blankImageUrl+")";this.frame.appendChild(eventPane);}
+var id=this.id+'_iFrame',iframe;if(parseFloat(navigator.appVersion.split("MSIE")[1])<9){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
 else{iframe=document.createElement('iframe');iframe.style.backgroundColor='transparent';iframe.name=id;}
-iframe.id=id;iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';OpenLayers.Util.modifyDOMElement(iframe,id,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};OpenLayers.Event.observe(iframe,'load',OpenLayers.Function.bind(onload,this));return iframe;},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);this.imgDiv.insertBefore(this.createIFrame(),this.imgDiv.firstChild);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize();var params=OpenLayers.Util.getParameters(this.url);for(var par in params){var field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.appendChild(fi
 eld);}
-return form;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
+iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';iframe.style.position="absolute";iframe.style.width="100%";iframe.style.height="100%";if(this.layer.opacity<1){OpenLayers.Util.modifyDOMElement(iframe,null,null,null,null,null,null,this.layer.opacity);}
+this.frame.appendChild(iframe);this.imgDiv=iframe;return iframe;}else{return OpenLayers.Tile.Image.prototype.createImage.apply(this,arguments);}},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize(),params=OpenLayers.Util.getParameters(this.url),field;for(var par in params){field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.appendChild(field);}
+return form;},setImgSrc:function(url){if(this.useIFrame===true){if(url){var form=this.createRequestForm();this.frame.appendChild(this.imgDiv);this.frame.appendChild(form);form.submit();this.frame.removeChild(form);}else if(this.imgDiv.parentNode===this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv=null;}}else{OpenLayers.Tile.Image.prototype.setImgSrc.apply(this,arguments);}}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLay
 this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
 return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options
 ]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
 seFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(node,offeringList[id]);},"time":function(node,offering){offering.time={};this.readChildNodes(node,offering.time);},"procedure":function(node,offering){offering.procedures.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"observedProperty":function(node,offering){offering.observedProperties.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"featureOfInterest":function(node,offering){offering.featureOfInterestIds.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"responseFormat":function(node,offering){offering.responseFormats.push(this.getChildValue(node));},"resultModel":function(node,offering){offering.resultModels.push(this.getChildValue(node));},"responseMode":function(node,offering){offering.responseModes.push(this.getChildValue(node));;}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});OpenL
 ayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:false,pinching:false,last:null,start:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
 ayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:false,pinching:false,last:null,start:null,touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
 OpenLayers.Event.stop(evt);return propagate;},touchmove:function(evt){if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;OpenLayers.Event.stop(evt);}
 return true;},touchend:function(evt){if(this.started){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;}
 return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
@@ -2763,14 +2741,14 @@
 if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var xml=new OpenLayers.Format.XML();if(typeof doc=="string"){doc=xml.read(doc);}
 var resultFeatures=xml.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","featureMember");this.addResults(resultFeatures);}}
 if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["locationupdated","locationfailed","locationuncapable"],geolocation:navigator.geolocation,bind:true,watch:false,geolocationOptions:null,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);this.geolocationOptions={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
+this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{geolocation:navigator.geolocation,bind:true,watch:false,geolocationOptions:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
 if(OpenLayers.Control.prototype.activate.apply(this,arguments)){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);}else{this.getCurrentLocation();}
 return true;}
 return false;},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
 return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},geolocate:function(position){var center=new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());if(this.bind){this.map.setCenter(center);}
 this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},getCurrentLocation:function(){if(!this.active||this.watch){return false;}
 this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return true;},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:true,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="jpg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions());}
+if(this.params.FORMAT=="jpg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png";}}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions());}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var projWords=this.projection.getCode().split(":");var srid=projWords[projWords.length-1];var imageSize=this.getImageSize();var newParams={'BBOX':bounds.toBBOX(),'SIZE':imageSize.w+","+imageSize.h,'F':"image",'BBOXSR':srid,'IMAGESR':srid};if(this.layerDefs){var layerDefStrList=[];var layerID;for(layerID in this.layerDefs){if(this.layerDefs.hasOwnProperty(layerID)){if(this.layerDefs[layerID]){layerDefStrList.push(layerID);layerDefStrList.push(":");layerDefStrList.push(this.layerDefs[layerID]);layerDefStrList.push(";");}}}
 if(layerDefStrList.length>0){newParams['LAYERDEFS']=layerDefStrList.join("");}}
 var requestString=this.getFullRequestString(newParams);return requestString;},setLayerFilter:function(id,queryDef){if(!this.layerDefs){this.layerDefs={};}
@@ -2779,12 +2757,12 @@
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
 return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
+obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
 return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){this.clearTimer();this.callback('move',[evt]);}
 return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
 Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
 return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:false,click:true,single:true,clickout:true,toggle:false,clickTolerance:5,hover:false,box:false,maxFeatures:10,features:null,hoverFeature:null,handlerOptions:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,EVENT_TYPES:["featureselected","featuresselected","featureunselected","clickout","beforefeatureselected","beforefeaturesselected","hoverfeature","outfeature"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.GetFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);this.features={};this.handlers={};if(this.click){this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.selectClick},this.han
 dlerOptions.click||{});}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:false,click:true,single:true,clickout:true,toggle:false,clickTolerance:5,hover:false,box:false,maxFeatures:10,features:null,hoverFeature:null,handlerOptions:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,initialize:function(options){options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);this.features={};this.handlers={};if(this.click){this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.selectClick},this.handlerOptions.click||{});}
 if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},OpenLayers.Util.extend(this.handlerOptions.box,{boxDivClassName:"olHandlerBoxSelectFeature"}));}
 if(this.hover){this.handlers.hover=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.selectHover},OpenLayers.Util.extend(this.handlerOptions.hover,{'delay':250}));}},activate:function(){if(!this.active){for(var i in this.handlers){this.handlers[i].activate();}}
 return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){for(var i in this.handlers){this.handlers[i].deactivate();}}
@@ -2973,7 +2951,7 @@
 var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var pathitems=["m"];for(var i=0;i<symbol.length;i=i+2){var x=symbol[i];var y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);pathitems.push(x);pathitems.push(y);if(i==0){pathitems.push("l");}}
 pathitems.push("x e");var path=pathitems.join(" ");var diff=(symbolExtent.getWidth()-symbolExtent.getHeight())/2;if(diff>0){symbolExtent.bottom=symbolExtent.bottom-diff;symbolExtent.top=symbolExtent.top+diff;}else{symbolExtent.left=symbolExtent.left+diff;symbolExtent.right=symbolExtent.right-diff;}
 cache={path:path,size:symbolExtent.getWidth(),left:symbolExtent.left,bottom:symbolExtent.bottom};this.symbolCache[id]=cache;return cache;},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Renderer.VML.LABEL_SHIFT={"l":0,"c":.5,"r":1,"t":0,"m":.5,"b":1};OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unsh
 ift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMerca
 tor(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
-return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,requestEncoding:"KVP",drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:true,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","getfeatureinfo","exception"],pending:0,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOption
 s||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
+return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,requestEncoding:"KVP",drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:true,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,pending:0,initialize:function(options){options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
 if(this.drillDown===true){this.hover=false;}
 if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},getInfoForClick:function(evt){this.request(evt.xy,{});},getInfoForHover:function(evt){this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
 this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer;for(var i=candidates.length-1;i>=0;--i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMTS&&layer.requestEncoding===this.requestEncoding&&(!this.queryVisible||layer.getVisibility())){layers.push(layer);if(!this.drillDown||this.hover){break;}}}
@@ -2985,11 +2963,11 @@
 var raw=data;if(data&&data.nodeType==9){data=data.documentElement;}
 var capabilities={};this.readNode(data,capabilities);if(capabilities.service===undefined){var parser=new OpenLayers.Format.OGCExceptionReport();capabilities.error=parser.read(raw);}else{this.postProcessLayers(capabilities);}
 return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
-if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(var j=0;j<attributes.length;j++){key=attributes[j];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
+var i,len;if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(i=0,len=attributes.length;i<len;i++){key=attributes[i];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
 if(layer[key]==null){var intAttr=["cascaded","fixedWidth","fixedHeight"];var boolAttr=["queryable","opaque","noSubsets"];if(OpenLayers.Util.indexOf(intAttr,key)!=-1){layer[key]=0;}
 if(OpenLayers.Util.indexOf(boolAttr,key)!=-1){layer[key]=false;}}}}
-for(var j=0;j<complexAttr.length;j++){key=complexAttr[j];layer[key]=OpenLayers.Util.extend(layer[key],parentLayer[key]);}}
-for(var i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
+for(i=0,len=complexAttr.length;i<len;i++){key=complexAttr[i];layer[key]=OpenLayers.Util.applyDefaults(layer[key],parentLayer[key]);}}
+for(i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
 if(layer.name){capability.layers.push(layer);}},readers:{"wms":{"Service":function(node,obj){obj.service={};this.readChildNodes(node,obj.service);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj["abstract"]=this.getChildValue(node);},"BoundingBox":function(node,obj){var bbox={};bbox.bbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];var res={x:parseFloat(node.getAttribute("resx")),y:parseFloat(node.getAttribute("resy"))};if(!(isNaN(res.x)&&isNaN(res.y))){bbox.res=res;}
 return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
 ,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(Ope
 nLayers.Util.isArray(obj.formats)){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){obj.get={};this.readChildNodes(node,obj.get);if(!obj.href){obj.href=obj.get.href;}},"Post":function(node,obj){obj.post={};this.readChildNodes(node,obj.post);if(!obj.href){obj.href=obj.get.href;}},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNod
 e&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(attrNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(n
 ode,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={width:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"
 Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChildValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.
 putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var userSymbols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenL
 ayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2
 ,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,layerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("Graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[ne
 w OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher});}
 return this.div;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.addLayer(this.gratLayer);this.map.events.register('moveend',this,this.update);this.update();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('moveend',this,this.update);this.map.removeLayer(this.gratLayer);return true;}else{return false;}},update:function(){var mapBounds=this.map.getExtent();if(!mapBounds){return;}
@@ -3098,8 +3076,8 @@
 deactivated=true;}}
 return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Protocol.Script=OpenLayers.Class(OpenLayers.Protocol,{url:null,params:null,callback:null,scope:null,format:null,callbackKey:"callback",callbackPrefix:"",pendingRequests:null,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.pendingRequests={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.format){this.format=new OpenLayers.Format.GeoJSON();}
 if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var format=new OpenLayers.Format.QueryStringFilter({srsInBBOX:this.srsInBBOX});this.filterToParams=function(filter,params){return format.write(filter,params);}}},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.applyDefaults(options,this.options);options.params=OpenLayers.Util.applyDefaults(options.params,this.options.params);if(options.filter&&this.filterToParams){options.params=this.filterToParams(options.filter,options.params);}
-var response=new OpenLayers.Protocol.Response({requestType:"read"});var request=this.createRequest(options.url,options.params,OpenLayers.Function.bind(function(data){response.data=data;this.handleRead(response,options);},this));response.priv=request;return response;},createRequest:function(url,params,callback){var id=OpenLayers.Protocol.Script.register(callback);var name="OpenLayers.Protocol.Script.getCallback("+id+")";params=OpenLayers.Util.extend({},params);params[this.callbackKey]=this.callbackPrefix+name;url=OpenLayers.Util.urlAppend(url,OpenLayers.Util.getParameterString(params));var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id="OpenLayers_Protocol_Script_"+id;this.pendingRequests[script.id]=script;var head=document.getElementsByTagName("head")[0];head.appendChild(script);return script;},destroyRequest:function(script){OpenLayers.Protocol.Script.unregister(script.id.split("_").pop());delete this.pendingRequests[script.id
 ];if(script.parentNode){script.parentNode.removeChild(script);}},handleRead:function(response,options){this.handleResponse(response,options);},handleResponse:function(response,options){if(options.callback){if(response.data){response.features=this.parseFeatures(response.data);response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
-this.destroyRequest(response.priv);options.callback.call(options.scope,response);}},parseFeatures:function(data){return this.format.read(data);},abort:function(response){if(response){this.destroyRequest(response.priv);}else{for(var key in this.pendingRequests){this.destroyRequest(this.pendingRequests[key]);}}},destroy:function(){this.abort();delete this.params;delete this.format;OpenLayers.Protocol.prototype.destroy.apply(this);},CLASS_NAME:"OpenLayers.Protocol.Script"});(function(){var o=OpenLayers.Protocol.Script;var counter=0;var registry={};o.register=function(callback){var id=++counter;registry[id]=callback;return id;};o.unregister=function(id){delete registry[id];};o.getCallback=function(id){var callback=registry[id];o.unregister(id);return callback;};})();OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[
 ];newArguments.push(name,url,params,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesetfeature","setfeature","beforetransform","transform","transformcomplete"],geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){this.EVENT_TYPES=OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.ini
 tialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
+var response=new OpenLayers.Protocol.Response({requestType:"read"});var request=this.createRequest(options.url,options.params,OpenLayers.Function.bind(function(data){response.data=data;this.handleRead(response,options);},this));response.priv=request;return response;},createRequest:function(url,params,callback){var id=OpenLayers.Protocol.Script.register(callback);var name="OpenLayers.Protocol.Script.registry["+id+"]";params=OpenLayers.Util.extend({},params);params[this.callbackKey]=this.callbackPrefix+name;url=OpenLayers.Util.urlAppend(url,OpenLayers.Util.getParameterString(params));var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id="OpenLayers_Protocol_Script_"+id;this.pendingRequests[script.id]=script;var head=document.getElementsByTagName("head")[0];head.appendChild(script);return script;},destroyRequest:function(script){OpenLayers.Protocol.Script.unregister(script.id.split("_").pop());delete this.pendingRequests[script.id];i
+this.destroyRequest(response.priv);options.callback.call(options.scope,response);}},parseFeatures:function(data){return this.format.read(data);},abort:function(response){if(response){this.destroyRequest(response.priv);}else{for(var key in this.pendingRequests){this.destroyRequest(this.pendingRequests[key]);}}},destroy:function(){this.abort();delete this.params;delete this.format;OpenLayers.Protocol.prototype.destroy.apply(this);},CLASS_NAME:"OpenLayers.Protocol.Script"});(function(){var o=OpenLayers.Protocol.Script;var counter=0;o.registry=[];o.register=function(callback){var id=++counter;o.registry[id]=function(){o.unregister(id);callback.apply(this,arguments);};return id;};o.unregister=function(id){delete o.registry[id];};})();OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,param
 s,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
 this.createBox();this.createControl();},activate:function(){var activated=false;if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragControl.activate();this.layer.addFeatures([this.box]);this.rotate&&this.layer.addFeatures(this.rotationHandles);this.layer.addFeatures(this.handles);activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.handles);this.rotate&&this.layer.removeFeatures(this.rotationHandles);this.layer.removeFeatures([this.box]);this.dragControl.deactivate();deactivated=true;}
 if(deactivated){this.unsetFeature();}
@@ -3118,15 +3096,15 @@
 this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles();},destroy:function(){var geom;for(var i=0;i<8;++i){geom=this.box.geometry.components[i];geom._handle.destroy();geom._handle=null;geom._rotationHandle&&geom._rotationHandle.destroy();geom._rotationHandle=null;}
 this.box.destroy();this.box=null;this.layer=null;this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.TransformFeature"});OpenLayers.Layer.ArcGISCache=OpenLayers.Class(OpenLayers.Layer.XYZ,{url:null,tileOrigin:null,tileSize:new OpenLayers.Size(256,256),useArcGISServer:true,type:'png',useScales:false,overrideDPI:false,initialize:function(name,url,options){OpenLayers.Layer.XYZ.prototype.initialize.apply(this,arguments);if(this.resolutions){this.serverResolutions=this.resolutions;this.maxExtent=this.getMaxExtentForResolution(this.resolutions[0]);}
 if(this.layerInfo){var info=this.layerInfo;var startingTileExtent=new OpenLayers.Bounds(info.fullExtent.xmin,info.fullExtent.ymin,info.fullExtent.xmax,info.fullExtent.ymax);this.projection='EPSG:'+info.spatialReference.wkid;this.sphericalMercator=(info.spatialReference.wkid==102100);this.units=(info.units=="esriFeet")?'ft':'m';if(!!info.tileInfo){this.tileSize=new OpenLayers.Size(info.tileInfo.width||info.tileInfo.cols,info.tileInfo.height||info.tileInfo.rows);this.tileOrigin=new OpenLayers.LonLat(info.tileInfo.origin.x,info.tileInfo.origin.y);var upperLeft=new OpenLayers.Geometry.Point(startingTileExtent.left,startingTileExtent.top);var bottomRight=new OpenLayers.Geometry.Point(startingTileExtent.right,startingTileExtent.bottom);if(this.useScales){this.scales=[];}else{this.resolutions=[];}
-this.lods=[];for(var key in info.tileInfo.lods){var lod=info.tileInfo.lods[key];if(this.useScales){this.scales.push(lod.scale);}else{this.resolutions.push(lod.resolution);}
-var start=this.getContainingTileCoords(upperLeft,lod.resolution);lod.startTileCol=start.x;lod.startTileRow=start.y;var end=this.getContainingTileCoords(bottomRight,lod.resolution);lod.endTileCol=end.x;lod.endTileRow=end.y;this.lods.push(lod);}
+this.lods=[];for(var key in info.tileInfo.lods){if(info.tileInfo.lods.hasOwnProperty(key)){var lod=info.tileInfo.lods[key];if(this.useScales){this.scales.push(lod.scale);}else{this.resolutions.push(lod.resolution);}
+var start=this.getContainingTileCoords(upperLeft,lod.resolution);lod.startTileCol=start.x;lod.startTileRow=start.y;var end=this.getContainingTileCoords(bottomRight,lod.resolution);lod.endTileCol=end.x;lod.endTileRow=end.y;this.lods.push(lod);}}
 this.maxExtent=this.calculateMaxExtentWithLOD(this.lods[0]);this.serverResolutions=this.resolutions;if(this.overrideDPI&&info.tileInfo.dpi){OpenLayers.DOTS_PER_INCH=info.tileInfo.dpi;}}}},getContainingTileCoords:function(point,res){return new OpenLayers.Pixel(Math.max(Math.floor((point.x-this.tileOrigin.lon)/(this.tileSize.w*res)),0),Math.max(Math.floor((this.tileOrigin.lat-point.y)/(this.tileSize.h*res)),0));},calculateMaxExtentWithLOD:function(lod){var numTileCols=(lod.endTileCol-lod.startTileCol)+1;var numTileRows=(lod.endTileRow-lod.startTileRow)+1;var minX=this.tileOrigin.lon+(lod.startTileCol*this.tileSize.w*lod.resolution);var maxX=minX+(numTileCols*this.tileSize.w*lod.resolution);var maxY=this.tileOrigin.lat-(lod.startTileRow*this.tileSize.h*lod.resolution);var minY=maxY-(numTileRows*this.tileSize.h*lod.resolution);return new OpenLayers.Bounds(minX,minY,maxX,maxY);},calculateMaxExtentWithExtent:function(extent,res){var upperLeft=new OpenLayers.Geometry.Point(extent.l
 eft,extent.top);var bottomRight=new OpenLayers.Geometry.Point(extent.right,extent.bottom);var start=this.getContainingTileCoords(upperLeft,res);var end=this.getContainingTileCoords(bottomRight,res);var lod={resolution:res,startTileCol:start.x,startTileRow:start.y,endTileCol:end.x,endTileRow:end.y};return this.calculateMaxExtentWithLOD(lod);},getUpperLeftTileCoord:function(res){var upperLeft=new OpenLayers.Geometry.Point(this.maxExtent.left,this.maxExtent.top);return this.getContainingTileCoords(upperLeft,res);},getLowerRightTileCoord:function(res){var bottomRight=new OpenLayers.Geometry.Point(this.maxExtent.right,this.maxExtent.bottom);return this.getContainingTileCoords(bottomRight,res);},getMaxExtentForResolution:function(res){var start=this.getUpperLeftTileCoord(res);var end=this.getLowerRightTileCoord(res);var numTileCols=(end.x-start.x)+1;var numTileRows=(end.y-start.y)+1;var minX=this.tileOrigin.lon+(start.x*this.tileSize.w*res);var maxX=minX+(numTileCols*this.tileSize
 .w*res);var maxY=this.tileOrigin.lat-(start.y*this.tileSize.h*res);var minY=maxY-(numTileRows*this.tileSize.h*res);return new OpenLayers.Bounds(minX,minY,maxX,maxY);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGISCache(this.name,this.url,this.options);}
 return OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);},getMaxExtent:function(){var resolution=this.map.getResolution();return this.maxExtent=this.getMaxExtentForResolution(resolution);},getTileOrigin:function(){var extent=this.getMaxExtent();return new OpenLayers.LonLat(extent.left,extent.bottom);},getURL:function(bounds){var res=this.getResolution();var originTileX=(this.tileOrigin.lon+(res*this.tileSize.w/2));var originTileY=(this.tileOrigin.lat-(res*this.tileSize.h/2));var center=bounds.getCenterLonLat();var point={x:center.lon,y:center.lat};var x=(Math.round(Math.abs((center.lon-originTileX)/(res*this.tileSize.w))));var y=(Math.round(Math.abs((originTileY-center.lat)/(res*this.tileSize.h))));var z=this.map.getZoom();if(this.lods){var lod=this.lods[this.map.getZoom()];if((x<lod.startTileCol||x>lod.endTileCol)||(y<lod.startTileRow||y>lod.endTileRow)){return null;}}
 else{var start=this.getUpperLeftTileCoord(res);var end=this.getLowerRightTileCoord(res);if((x<start.x||x>=end.x)||(y<start.y||y>=end.y)){return null;}}
 var url=this.url;var s=''+x+y+z;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(s,url);}
 if(this.useArcGISServer){url=url+'/tile/${z}/${y}/${x}';}else{x='C'+this.zeroPad(x,8,16);y='R'+this.zeroPad(y,8,16);z='L'+this.zeroPad(z,2,16);url=url+'/${z}/${y}/${x}.'+this.type;}
 url=OpenLayers.String.format(url,{'x':x,'y':y,'z':z});return url;},zeroPad:function(num,len,radix){var str=num.toString(radix||10);while(str.length<len){str="0"+str;}
-return str;},CLASS_NAME:'OpenLayers.Layer.ArcGISCache'});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",output:"features",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","nogetfeatureinfo","getfeatureinfo"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
+return str;},CLASS_NAME:'OpenLayers.Layer.ArcGISCache'});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",output:"features",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,initialize:function(options){options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
 if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{'delay':250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},activate:function(){if(!this.active){this.handler.activate();}
 return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},getInfoForClick:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(evt.xy,{});},getInfoForHover:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer,url;for(var i=0,len=candidates.length;i<len;++i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||layer.getVisibility())){url=OpenLayers.Util.isArray(layer.url)?layer.url[0]:layer.url;if(this.drillDown===false&&!this.url){this.url=url;}
@@ -3156,7 +3134,7 @@
 var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);updateNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
 valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
 var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);deleteNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesplit","split","aftersplit"],layer:null,source:null,sourceOptions:null,tolerance:null,edge:true,deferDelete:false,mutual:true,targetFilter:null,sourceFilter:null,handler:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options
 =options||{};if(this.options.source){this.setSource(this.options.source);}},setSource:function(layer){if(this.active){this.deactivate();if(this.handler){this.handler.destroy();delete this.handler;}
+var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);deleteNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{layer:null,source:null,sourceOptions:null,tolerance:null,edge:true,deferDelete:false,mutual:true,targetFilter:null,sourceFilter:null,handler:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.source){this.setSource(this.options.source);}},setSource:function(layer){if(this.active){this.deactivate()
 this.source=layer;this.activate();}else{this.source=layer;}},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(!this.source){if(!this.handler){this.handler=new OpenLayers.Handler.Path(this,{done:function(geometry){this.onSketchComplete({feature:new OpenLayers.Feature.Vector(geometry)});}},{layerOptions:this.sourceOptions});}
 this.handler.activate();}else if(this.source.events){this.source.events.on({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});}}
 return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.source&&this.source.events){this.layer.events.un({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});}}
Modified: sandbox/august/trunk/playground/index.html
--- sandbox/august/trunk/playground/index.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/index.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -37,12 +37,17 @@
 			<tr><td><a href="wmts/wmts-ags-epsg3857.html"><b>wmts/wmts-ags-epsg3857.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-ags-epsg3857-load-capa.html"><b>wmts/wmts-ags-epsg3857-load-capa.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-ags-wgs84.html"><b>wmts/wmts-ags-wgs84.html</b></a></td></tr>
-			<tr><td><a href="wmts/wmts-ags-customized-tilingschema.html"><b>wmts/wmts-ags-customized-tilingschema.html</b></a></td></tr>
+			<tr><td><a href="wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html"><b>wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html</b></a></td></tr>
+			<tr><td><a href="wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html"><b>wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html</b></a></td></tr>
+			<tr><td><a href="wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html"><b>wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-ags-customized-tilingschema-nowkid.html"><b>wmts/wmts-ags-customized-tilingschema-nowkid.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html"><b>wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-geowebcache-epsg3857.html"><b>wmts/wmts-geowebcache-epsg3857.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-geowebcache-wgs84.html"><b>wmts/wmts-geowebcache-wgs84.html</b></a></td></tr>
 			<tr><td><a href="wmts/wmts-geowebcache-customized-tilingschema.html"><b>wmts/wmts-geowebcache-customized-tilingschema.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-2.5-wmts-ags-epsg3857.html"><b>wmts/jsapi-2.5-wmts-ags-epsg3857.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-2.5-wmts-ags-wgs84.html"><b>wmts/jsapi-2.5-wmts-ags-wgs84.html</b></a></td></tr>
+			<tr><td><a href="wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html"><b>wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-wgs84.html"><b>wmts/jsapi-wmts-wgs84.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-ags-wgs84.html"><b>wmts/jsapi-wmts-ags-wgs84.html</b></a></td></tr>
 			<tr><td><a href="wmts/jsapi-wmts-epsg3857.html"><b>wmts/jsapi-wmts-epsg3857.html</b></a></td></tr>
Modified: sandbox/august/trunk/playground/mapquest/mapquest-osm.html
--- sandbox/august/trunk/playground/mapquest/mapquest-osm.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/mapquest/mapquest-osm.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -5,8 +5,11 @@
         <link rel="stylesheet" href="../../theme/default/style.css" type="text/css">
         <link rel="stylesheet" href="../../theme/default/google.css" type="text/css">
         <link rel="stylesheet" href="../style.css" type="text/css">
-        <script src="http://maps.google.com/maps/api/js?sensor=false"></script>
+        <script src="http://maps.google.com/maps/api/js?sensor=false"></script>
         <script src="../../lib/OpenLayers.js"></script>
+        <script src="../../OpenLayers.js"></script>
         <script src="mapquest-osm.js"></script>
     </head>
     <body onload="init()">
Added: sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html
--- sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-customized-tilingschema.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,32 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
+<html>
+	<head>
+    	<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+    	<title>jsapi-2.5-wmts-ags-customized-tilingschema</title>
+    	<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
+    	<script type="text/javascript" src="http://jhuang7/localjsapi/js/dojo/dojo/dojo.js" djConfig="parseOnLoad:true"></script>
+    	<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
+    	<script type="text/javascript">
+      		dojo.require("esri.map");
+      		dojo.require("esri.layers.wmts");
+      		function init() {
+        		esri.config.defaults.io.proxyUrl = "../../util/ags-proxy.jsp";
+        		var map = new esri.Map("map");
+        		var wmtsLayer = new esri.layers.WMTSLayer(
+        			"http://sazabiii:6080/arcgis/rest/services/wmts.regression/portland_wmts/MapServer/WMTS"
+        		map.addLayer(wmtsLayer);
+      		dojo.addOnLoad(init);
+    	</script>
+  	</head>
+  	<body class="claro">
+    	<div id="map" style="width:1024px;height:512px;">
+    	</div>
+ 	</body>
+</html>
Added: sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-epsg3857.html
--- sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-epsg3857.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-epsg3857.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,33 @@
+<html>
+	<head>
+    	<title>jsapi-2.5-wmts-ags-epsg3857.html</title>
+      		function init() {
+        			//"http://sazabiii:6080/arcgis/rest/services/wmts.regression/world_wmts/MapServer/WMTS"
+        			"http://zeon/resources/capabilities/wmts/"
+    	</script>
+  	</head>
+    	</div>
+ 	</body>
+</html>
Added: sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-wgs84.html
--- sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-wgs84.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/jsapi-2.5-wmts-ags-wgs84.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,32 @@
+<html>
+	<head>
+    	<title>jsapi-2.5-wmts-ags-wgs84.html</title>
+      		function init() {
+        			"http://sazabiii:6080/arcgis/rest/services/wmts.regression/bluemarble_4326_wmts/ImageServer/WMTS"
+    	</script>
+  	</head>
+    	</div>
+ 	</body>
+</html>
Deleted: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,11 +0,0 @@
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml">
-	<head>
-		<title>OpenLayers WMTS Example</title>
-		<script type="text/javascript" src="http://august-openlayers.appspot.com/openlayers/trunk+/OpenLayers.js"></script>
-		<script type="text/javascript" src="wmts-ags-customized-tilingschema-2.js"></script>
-	</head>
-	<body onload="init();">
-		<div id="map" style="width:1024px;height:512px;margin-top:5px;margin-left:5px;background-color:#ffffff;border:1px solid #ccc;"></div>
-	</body>
-</html>
Deleted: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-2.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,121 +0,0 @@
-var map = null;
-function init() {
-	OpenLayers.ProxyHost= function(url) {
-		return "/openlayers-trunk/ApacheProxyServlet?url=" + url;
-	var lon = 471437.46290;
-	var lat = 4475957.35010;
-	var zoom = 0;
-	var options = {
-		//panMethod: null, // set 'panMethod' to null to disable animated panning
-		controls: [
-		    new OpenLayers.Control.LayerSwitcher(),
-		    new OpenLayers.Control.PanZoomBar(),
-       		new OpenLayers.Control.Navigation(),
-       		new OpenLayers.Control.MousePosition()
-       	projection: "EPSG:900913",
-        units: "m",
-        maxResolution: 8000000*0.3048/(96*12),
-        numZoomLevels: 6,
-        maxExtent: new OpenLayers.Bounds(-434069.08184709644, 4409037.227927545, 1524060.9791107727, 4967959.789016491)
-	map = new OpenLayers.Map('map', options);
-	var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/geologico/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
-	var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/geologico/MapServer/WMTS/tile/";
-	OpenLayers.loadURL(
-		wmtsCapaUrl,
-       	null,	// RESTful WMTS, no kvp request parameters
-        this,
-       	function(request) {	// parse WMTS capabilities XML and create WMTS layer
-			var format = new OpenLayers.Format.WMTSCapabilities();
-			var capabilities = format.read(request.responseXML || request.responseText);
-		    //try {
-		    	//var wmtsTileResUrl = capabilities.operationsMetadata.GetTile.dcp.http.get;
-		    	//if(!wmtsTileResUrl || wmtsTileResUrl=="") {
-		    		//throw "";
-		    //} catch(e) {
-		    	//OpenLayers.Console.error("...invalid WMTS tile resources endpoint url in capabilities...");
-		    var layers = capabilities.contents.layers;
-		    var tileMatrixSets = capabilities.contents.tileMatrixSets;
-			var agsWmtsLayer = new OpenLayers.Layer.WMTS({
-				// general Grid layer options
-				name: 			"Geol%C3%B3gico",
-				url:			wmtsTileResUrl,
-				isBaseLayer: 	true,
-				singleTile: 	false,
-				// WMTS layer options
-				// you can choose different layers
-				//layer: 			"sazabiii.bluemarble",
-				layer: 			layers[0].identifier,
-				style: 			layers[0].styles[0].identifier,
-				matrixSet: 		layers[0].tileMatrixSetLinks[0].tileMatrixSet,
-				format: 		layers[0].formats[0],
-				requestEncoding: "REST",
-				matrixIds: tileMatrixSets[layers[0].tileMatrixSetLinks[0].tileMatrixSet].matrixIds,
-				// optional
-				tileFullExtent: new OpenLayers.Bounds(-434069.08184709644, 4409037.227927545, 1524060.9791107727, 4967959.789016491),
-				// optional
-				tileOrigin: new OpenLayers.LonLat(-5121200.0, 9998400.0)
-			agsWmtsLayer.setOpacity(1);
-			//agsWmtsLayer.setVisibility(false);
-			map.addLayer(agsWmtsLayer);
-			map.setCenter(
-				new OpenLayers.LonLat(lon, lat),
-				zoom
-	// add a WMTS by manually configure the tileMatrixSet and matrixIds
-	// in this case you don't need to load and parse capabilities file
-	var _tileMatrixSet = "default028mm";
-	var _matrixIds = [];
-    for (var j=0; j<20; ++j) {
-        _matrixIds[j] = "" + j + "";
-		name: 			"portland wmts",
-		layer: 			"geologico",
-		style: 			"default",
-		matrixSet: 		_tileMatrixSet,
-		format: 		"image/png",
-		matrixIds: _matrixIds,
-		tileSize: new OpenLayers.Size(256, 256),
-	map.setCenter(
-		zoom
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,17 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+	<head>
+		<title>OpenLayers (GeoWebCache) WMTS Example</title>
+		<link rel="stylesheet" href="../../theme/default/style.css" type="text/css"/>
+		<link rel="stylesheet" href="../style.css" type="text/css" />
+		<script type="text/javascript" src="../../lib/Firebug/firebug.js"></script>
+		<script type="text/javascript" src="../../OpenLayers.js"></script>
+		<script type="text/javascript" src="../../lib/OpenLayers.js"></script>
+		<script type="text/javascript" src="wmts-ags-customized-tilingschema-ft-equal-scales.js"></script>
+	</head>
+	<body onload="init();">
+		<div id="map" class="mediummap"></div>
+	</body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.js	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-equal-scales.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,71 @@
+var map = null;
+function init() {
+	OpenLayers.ProxyHost= function(url) {
+		return "/openlayers-trunk/ApacheProxyServlet?url=" + url;
+    // Portland
+    //var lon = -122.838493;
+	//var lat = 45.432976;
+	//var zoom = 9;
+	// Portland in EPSG:2913
+	var lon = 7647130.2520;
+	var lat = 669087.0178;
+	var zoom = 0;
+	var options = {
+		//panMethod: null, // set 'panMethod' to null to disable animated panning
+		controls: [
+		    new OpenLayers.Control.LayerSwitcher(),
+		    new OpenLayers.Control.PanZoomBar(),
+       		new OpenLayers.Control.Navigation(),
+       		new OpenLayers.Control.MousePosition()
+       	projection: "EPSG:102726",
+        units: "ft",
+        maxResolution: 512000/(96*12),
+        numZoomLevels: 5,
+        maxExtent: new OpenLayers.Bounds(7558171.823664263, 586846.5623224229, 7850468.5058020055, 813426.7833736688)
+	map = new OpenLayers.Map('map', options);
+	var url = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/portland_wmts/MapServer/WMTS/tile";
+	// add a WMTS by manually configure the tileMatrixSet and matrixIds
+	// in this case you don't need to load and parse capabilities file
+	var _tileMatrixSet = "EsriTileMatrix";
+	var _matrixIds = [];
+    for (var j=0; j<20; ++j) {
+        _matrixIds[j] = "" + j + "";
+    var agsPortlandWmtsLayer = new OpenLayers.Layer.WMTS({
+		// general Grid layer options
+		name: 			"portland wmts",
+		url:			url,
+		isBaseLayer: 	true,
+		singleTile: 	false,
+		// WMTS layer options
+		layer: 			"Layers",
+		style: 			"EsriStyle",
+		matrixSet: 		_tileMatrixSet,
+		format: 		"image/png",
+		requestEncoding: "REST",
+		matrixIds: _matrixIds,
+		tileSize: new OpenLayers.Size(256, 256),
+		// optional
+		tileFullExtent: new OpenLayers.Bounds(7558171.823664263, 586846.5623224229, 7850468.5058020055, 813426.7833736688),
+		// optional
+		tileOrigin: new OpenLayers.LonLat(7558171.823664263, 813426.7833736688)
+	//agsPortlandWmtsLayer.setOpacity(0.72);
+	//agsPortlandWmtsLayer.setVisibility(false);
+	map.addLayer(agsPortlandWmtsLayer);
+	map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,15 @@
+	<head>
+		<title>OpenLayers ArcGIS Server WMTS Example</title>
+		<script type="text/javascript" src="wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.js"></script>
+	</head>
+		<div id="map" style="width:1024px;height:512px;margin-top:5px;margin-left:5px;background-color:#ffffff;border:1px solid #ccc;"></div>
+	</body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.js	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales-load-capa.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,95 @@
+var map = null;
+function init() {
+    // Portland in EPSG:900913
+	var lon = -13670033.332100281;
+	var lat = 5687187.589710401;
+	var zoom = 0;
+	var options = {
+		controls: [
+       	projection: "EPSG:900913",
+        units: "m",
+        maxResolution: 160000*0.3048/(96*12),
+        // !!! IMPORTANT Settings !!!
+        //   since the tiling schema for this WMTS is special such that the resolution of next level is not 2x
+        //   as the previous level, so without loading the capa file you will have to provide the full list
+        //   resolutions, otherwise it would derive resolutions for all levels from the top max one by keeping dividing by 2.
+        // !!! TODO: by loading the capabilities xml, WMTS layer should adjust its resolutions based on the selected tiling schemas
+        resolutions:[
+            160000*0.3048/(96*12),
+            120000*0.3048/(96*12),
+            100000*0.3048/(96*12),
+            50000*0.3048/(96*12),
+            20000*0.3048/(96*12)
+        numZoomLevels: 5,
+        maxExtent: new OpenLayers.Bounds(-13670033.332100281, 5687187.589710401, -13644816.568066753, 5709075.931087084)
+	var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/hillshade_wmts/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
+	var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/hillshade_wmts/MapServer/WMTS/tile/";
+	OpenLayers.loadURL(
+		wmtsCapaUrl,
+       	null,	// RESTful WMTS, no kvp request parameters
+        this,
+       	function(request) {	// parse WMTS capabilities XML and create WMTS layer
+			var format = new OpenLayers.Format.WMTSCapabilities();
+			var capabilities = format.read(request.responseXML || request.responseText);
+		    /*try {
+		    	var wmtsTileResUrl = capabilities.operationsMetadata.GetTile.dcp.http.get;
+		    	if(!wmtsTileResUrl || wmtsTileResUrl=="") {
+		    		throw "";
+		    } catch(e) {
+		    	OpenLayers.Console.error("...invalid WMTS tile resources endpoint url in capabilities...");
+		    var layers = capabilities.contents.layers;
+		    var tileMatrixSets = capabilities.contents.tileMatrixSets;
+			var agsWmtsLayer = new OpenLayers.Layer.WMTS({
+				name: 			"hillshade wmts",
+				url:			wmtsTileResUrl,
+				// you can choose different layers
+				//layer: 			"sazabiii.bluemarble",
+				layer: 			layers[0].identifier,
+				style: 			layers[0].styles[0].identifier,
+				matrixSet: 		layers[0].tileMatrixSetLinks[0].tileMatrixSet,
+				format: 		layers[0].formats[0],
+				matrixIds: tileMatrixSets[layers[0].tileMatrixSetLinks[0].tileMatrixSet].matrixIds,
+				// optional
+				tileFullExtent: new OpenLayers.Bounds(-13670033.332100281, 5687187.589710401, -13644816.568066753, 5709075.931087084),
+				// optional
+				tileOrigin: new OpenLayers.LonLat(-2.00377E7, 2.00377E7)
+			agsWmtsLayer.setOpacity(1);
+			//agsWmtsLayer.setVisibility(false);
+			map.addLayer(agsWmtsLayer);
+			map.setCenter(
+				new OpenLayers.LonLat(lon, lat),
+				zoom
+			OpenLayers.Console.debug(agsWmtsLayer.resolutions);
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,17 @@
+	<head>
+		<script type="text/javascript" src="wmts-ags-customized-tilingschema-ft-unequal-scales.js"></script>
+	</head>
+	</body>
+</html>
Added: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.js	                        (rev 0)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-ft-unequal-scales.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -0,0 +1,76 @@
+var map = null;
+function init() {
+	var zoom = 0;
+	var options = {
+		controls: [
+        units: "m",
+        resolutions:[
+        numZoomLevels: 5,
+	var url = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/hillshade_wmts/MapServer/WMTS/tile";
+	var _tileMatrixSet = "default028mm";
+    var agsHillshadeWmtsLayer = new OpenLayers.Layer.WMTS({
+		url:			url,
+		layer: 			"hillshade_wmts",
+		style: 			"default",
+		// optional
+		// optional
+	//agsHillshadeWmtsLayer.setOpacity(0.72);
+	//agsHillshadeWmtsLayer.setVisibility(false);
+	map.addLayer(agsHillshadeWmtsLayer);
+	OpenLayers.Console.debug(agsHillshadeWmtsLayer.resolutions);
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,8 +1,12 @@
 	<head>
 		<script type="text/javascript" src="wmts-ags-customized-tilingschema-nowkid-load-capa.js"></script>
 	</head>
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid-load-capa.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -28,8 +28,8 @@
+	var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/geologico_wmts/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
+	var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/geologico_wmts/MapServer/WMTS/tile/";
 	OpenLayers.loadURL(
 		wmtsCapaUrl,
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,10 +1,14 @@
 	<head>
 		<script type="text/javascript" src="wmts-ags-customized-tilingschema-nowkid.js"></script>
 	</head>
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema-nowkid.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -28,8 +28,8 @@
+	var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/geologico/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
+	var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/geologico/MapServer/WMTS/tile/";
 	OpenLayers.loadURL(
@@ -95,7 +95,7 @@
+		name: 			"geologico wmts",
 		isBaseLayer: 	true,
 		singleTile: 	false,
Deleted: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.html
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.html	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.html	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,15 +0,0 @@
-	<head>
-		<title>OpenLayers (GeoWebCache) WMTS Example</title>
-		<link rel="stylesheet" href="../../theme/default/style.css" type="text/css"/>
-		<link rel="stylesheet" href="../style.css" type="text/css" />
-		<script type="text/javascript" src="../../lib/Firebug/firebug.js"></script>
-		<script type="text/javascript" src="../../lib/OpenLayers.js"></script>
-		<script type="text/javascript" src="wmts-ags-customized-tilingschema.js"></script>
-	</head>
-		<div id="map" class="mediummap"></div>
-	</body>
-</html>
Deleted: sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-customized-tilingschema.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,253 +0,0 @@
-var map = null;
-function init() {
-    // Portland
-    //var lon = -122.838493;
-	//var lat = 45.432976;
-	//var zoom = 9;
-	// Portland in EPSG:2913
-	var lon = 7647130.2520;
-	var lat = 669087.0178;
-	var zoom = 0;
-	var options = {
-		controls: [
-       	projection: "EPSG:102726",
-        units: "ft",
-        maxResolution: 512000/(96*12),
-        numZoomLevels: 5,
-        maxExtent: new OpenLayers.Bounds(7558171.823664263, 586846.5623224229, 7850468.5058020055, 813426.7833736688)
-	var url = "http://sazabiii:6080/arcgis/rest/services/portland_wmts/MapServer/WMTS/tile";
-	var _tileMatrixSet = "EsriTileMatrix";
-    var agsPortlandWmtsLayer = new OpenLayers.Layer.WMTS({
-		url:			url,
-		layer: 			"Layers",
-		style: 			"EsriStyle",
-		// optional
-		tileFullExtent: new OpenLayers.Bounds(7558171.823664263, 586846.5623224229, 7850468.5058020055, 813426.7833736688),
-		// optional
-		tileOrigin: new OpenLayers.LonLat(7558171.823664263, 813426.7833736688)
-	//agsPortlandWmtsLayer.setOpacity(0.72);
-	//agsPortlandWmtsLayer.setVisibility(false);
-	map.addLayer(agsPortlandWmtsLayer);
-	map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
-		url,
-			request: "GetCapabilities",
-			service: "WMTS",
-			version: "1.0.0"
-        this,
-			// add the WMS layer as base layer, WMTS and AgsTiled are overlay on top to see if match
-			// GeoWebCacge WMTS layer actually points to the same WMS at back-end
-			var agsWmsLayer = new OpenLayers.Layer.WMS(
-		        "arcgisserver wms",
-		        "http://sazabiii/arcgis/services/playground/portland2913/MapServer/WMSServer?",
-		            layers: '1,2,3,5,6,7,8,10,11,12,13,15,16,17,18,19,20,21,22,24,25,26,27,28,29',
-		            styles: "",
-		            transparency: false
-		            buffer: 0,
-		            //tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828)
-			//agsWmsLayer.setOpacity(0.72);
-			//agsWmsLayer.setVisibility(false);
-			//map.addLayer(agsWmsLayer);
-			// parse WMTS capabilities and add a WMTS layer in the same map
-			var tileMatrixSet = "sazabiii.portland.epsg2913";
-			// collect identifiers of tileMatrix from a tileMatrixSet
-			var matrixIds = [];
-			var numOfTileMatrixSet = capabilities.contents.tileMatrixSets[tileMatrixSet].matrixIds.length;
-		    for (var i=0; i<numOfTileMatrixSet; ++i) {
-		        matrixIds[i] = capabilities.contents.tileMatrixSets[tileMatrixSet].matrixIds[i].identifier;
-				name: 			"geowebcache wmts",
-				url:			url,
-				isBaseLayer: 	false,
-				layer: 			"sazabiii.portland",
-				style: 			"_null",
-				matrixSet: 		tileMatrixSet,
-				requestEncoding: "KVP",
-				matrixIds: matrixIds,
-				// optional
-				tileFullExtent: new OpenLayers.Bounds(7241196.8729, 128656.7859, 9265592.9584, 981999.6828),
-				// optional
-				tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828)
-			agsPortlandWmtsLayer.setOpacity(0.72);
-			agsPortlandWmtsLayer.setVisibility(false);
-			// add the AgsTiled layer from the same ArcGIS Server map service on which the base WMS layer is from
-			var agsTiledlayer = new OpenLayers.Layer.AgsTiled(
-				"ags tiled",
-				"http://sazabiii/ArcGIS/rest/services/playground/portland2913tiled/MapServer/tile/",
-					tileFormat:'png',
-					tileOrigin: new OpenLayers.LonLat(7241196.8729, 981999.6828),
-					buffer: 0,
-					singleTile: false
-			agsTiledlayer.setOpacity(0.72);
-			agsTiledlayer.setVisibility(false);
-			//map.addLayer(agsTiledlayer);
-// the same map and layers but in EPSG:2838 which is basically EPSG:2913 in meter instead of feet
-var map = null;
-function init() {
-    // Portland
-	//var zoom = 9;
-	//var lon = 7647130.2520;
-	//var lat = 669087.0178;
-	//var zoom = 0;
-	// Portland in EPSG:2838
-	var lon = 7647130.2520*0.3048;
-	var lat = 669087.0178*0.3048;
-	var zoom = 3;
-	var options = {
-		controls: [
-       	projection: "EPSG:2838",
-        units: "m",
-        maxResolution: (0.3048*2048000)/(96*12),
-        numZoomLevels: 11,	// default allowed zoom levels is 16 so change it to 20
-        maxExtent: new OpenLayers.Bounds(2207116.806860, 39214.588342, 2824152.733720, 299313.503317)
-	var url = "http://sazabiii:8080/geowebcache.10012010.snapshot/service/wmts";
-		url,
-			service: "WMTS",
-			version: "1.0.0"
-        this,
-			var tileMatrixSet = "sazabiii.portland.epsg2838";
-			var gwcWmtsLayer = new OpenLayers.Layer.WMTS({
-				url:			url,
-				style: 			"_null",
-				// optional
-				tileFullExtent: new OpenLayers.Bounds(2207116.806860, 39214.588342, 2824152.733720, 299313.503317),
-				// optional
-				tileOrigin: new OpenLayers.LonLat(2207116.806860, 299313.503317)
-			//gwcWmtsLayer.setOpacity(0.8);
-			map.addLayer(gwcWmtsLayer);
Modified: sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857-load-capa.js
--- sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857-load-capa.js	2011-10-03 06:37:11 UTC (rev 12426)
+++ sandbox/august/trunk/playground/wmts/wmts-ags-epsg3857-load-capa.js	2011-10-06 22:42:05 UTC (rev 12427)
@@ -1,7 +1,8 @@
 var map = null;
-var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/world_wmts/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
-var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/world_wmts/MapServer/WMTS/tile/";
+var wmtsCapaUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/world_wmts/MapServer/WMTS/1.0.0/WMTSCapabilities.xml";
+var wmtsTileResUrl = "http://sazabiii:6080/arcgis/rest/services/wmts.regression/world_wmts/MapServer/WMTS/tile/";
 function init() {
More information about the Commits mailing list
